The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Thread Tools Display Modes
Old 06-21-2007, 09:45 PM   #751
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (16)
FYI?
I just got a Cert not valid, when heading to checkout, at the store!
Blue ZX3 is offline   Reply With Quote
Sponsored Links
Old 06-21-2007, 09:46 PM   #752
BiGGy's Avatar
Vehicle: 02 Mitsubishi Magna VR-X
My Photos: (110)
Quote: Originally Posted by greenman100 View Post
We need more info about the LCD.
boot - needs one relay
hazards - needs one relay
temperature readings - needs one temp sensor for each
number plate - need more info
Quote: Originally Posted by turbocad6 View Post
hey biggie, for the lcd, if your going with ccfl's then the inverters sometimes need pwm for dimming, but dimming inverters can usually be gotten that will only need a variable resistance to control brightness, if your going with led's like mine then you can use a dimming power supply for them that also just needs a variable resistance for brightness. you will probably want to build a circiut that has the lcd come on half bright until the brain comes up & takes over, I'm sure we could help you work it out
LCD brightness will be LED matrix like Turbos setup. Hooked into a dimming PSU. I haven’t ordered the LED kit yet but im getting real close to. 15.4 wxga is on its way. The kit comes with a dimming PSU, I don’t have any pics or info of the PSU but ive been told its a variable knob style external dimming control. Ive attached some pics of the LEDs. I don’t know anything about resistance or that stuff I don’t even have the tools to make PCBs. A good friend of mine is a electrician with 40 years under his belt he said he will help me out, but I gotta know what I want before I tell him, you know? Or if Fusion(or turbocad) can make a pcb to do this then ill buy it. I could give you multimeter reading if you need them?
Number plate attached to a servo or two, it flips down hiding the numbers, and back up again when i choose. Could be some sort of cable system going to the boot lid. Now I think about it this isn’t practical so I won’t worry about this one initially.
Mitsubishi Magna VR-X - Whitsundays, Australia
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
*768 X 1024 Narrow RR Skin
http://bigs.omfg.net.au/
BiGGy is offline   Reply With Quote
Old 06-21-2007, 10:15 PM   #753
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
the power supplies will be a variable resistor, either a 3k or a 5k maybe.
you will use a photoresistor to sense the light level, you then have to set up in the skin file how you want it to react to the light level, you'll do most of your setup at your keyboard once it's wired up.
sensor1 is the photosensor, output 1 is a variable resistance, this is all defined with your keyboard, you don't have to "know" how to do it,really no one "knows" how to do it except the badger , but you will have an example of how it's done provided by him, you will then type in your numbers & parameters instead of the examples... it's not hard if your willing to just spend some time with this really
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 06-21-2007, 10:17 PM   #754
turbocad6's Avatar
My Photos: (71)
also, the only circuit board you'll need will be the fusion brain, you don't need another board made, everything will wire straight up to this board.
Old 06-21-2007, 10:36 PM   #755
BiGGy's Avatar
My Photos: (110)
just the confidence speech I needed turbo. I will buy one of these when ive got it setup on a bench ready to play with with LEDs running etc. Any chance on postage quote to Australia?
Old 06-21-2007, 11:21 PM   #756
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
yeah, you can switch skins(pages) but I don't think they can be 2 different sizes & I think that all "pages" use the same background image too, plus I think it starts up on the default page, embeading the app with different sizes could be a problem too,
that's a lotta relays
Well I can change that. I can make the size changeable via a button if needed. I am not really sure how you could embed that though... Im sure you'll figure something out. Let me know if this is something you want.
Is a well kept secret right now. I am trying to get all the documentation, but you can thank turbo for making the software so dynamic and free that I am having a hard time getting myself to finish it! So many options!!!!
I'll get to it... Worse than eating broccoli.
Flat rate shipping via USPS to Australia and then through your local government mail courrier is $20. Or you can choose FedEx/UPS/DHL (DHL not yet, but maybe later) whatever. We aren't picky.
If you go to the store and start to checkout, it will take you to the shipping page, where it will calculate the shipping to your address. Or you can try to get a rough estimate by using the shipping zip code of 80906 in Colorado Springs, CO, USA.
Old 06-22-2007, 12:50 AM   #757
turbocad6's Avatar
My Photos: (71)
well, to run this in cf then it'll be fine as-is, the skinning there is not versitale enough to add car control buttons throughout the skin, your program is never more than a few clicks away though & it's cool, but in rr it would be cool to add buttons and/or labels throughout the different skins of the front end, but doing this with a dll involves an insane amount of work to achieve anywhere near the amount of functionality of your program I would think
my thought with rr is to have a small mini control panel that could be in a certain location, & it can be there on multple pages throughout the skin. it can be a window with various sensor readings, buttons, etc. this should be achievable now & is probably the better way of using this in rr to me than reinventing the program, that should be cool. these may also wind up being skins that can be done, as mini modules if you can picture it.
it would Really be cool if at that point you could also hit a button & "switch" to a full(er) skin view, this right now isn't possible as far as I know. I was thinking it would only be possible if there were another instance that could run & be called by rr, but then I have no clue if that could be done or how crazy it would be to do that, I mean it couldn't be another instance of the same program obviously, it'd have to be like a module that reads the skin file but has it's own set of graphics & appears as another embeaded program... how crazy is that? is there another way?
now don't stay up all weekend rewriting the friggin thing please, it was just a thought
Old 06-22-2007, 12:55 AM   #758
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
I don't know...sounds mental picture wise, like a cool idea/look.
Old 06-22-2007, 12:59 AM   #759
2k1Toaster's Avatar
My Photos: (1)
So multiple windows that you could minimize/embed as you choose?
Hmm... Doable, but tricky. If that is something that could be helpful, then sure why not. I'll start drawing up some ideas how to implement that.
Old 06-22-2007, 01:10 AM   #760
turbocad6's Avatar
My Photos: (71)
your crazy, get through phaze 1 first, that can come after. right now lets get what we got solid & documented, let's get some installs going & some skins done, you have to eat your brocolli first
as much as I know that'll be so cool, don't spred yourself to thin either unless you can come up with a way to do it without going too nuts.
Sponsored Links
Old 06-22-2007, 01:27 AM   #761
turbocad6's Avatar
My Photos: (71)
oh man, no answer, I know what that means
Old 06-22-2007, 01:38 AM   #762
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
Yah....too Late....he's off to
Deadicated customer service, I TELL YOU!!
Old 06-22-2007, 01:55 AM   #763
2k1Toaster's Avatar
My Photos: (1)
I have no life.
Well I enjoy this sort of stuff. School isn't much of a challenge here, so voila, the Fusion was born! And since I am on summer break, I still have my 2 jobs, but my 3rd is now this, in the wee morning hours!
Correct again. I think I figured out the best way to do this in my head. Now I gotta try it! But first I am going to take some pictures of the kagillion kg box that came today with all the goodies.
We try!
Old 06-22-2007, 01:59 AM   #764
BiGGy's Avatar
My Photos: (110)
a single button in the corner of RR and brain software switching from each other would be good, like alt-tab style.
Old 06-22-2007, 02:01 AM   #765
2k1Toaster's Avatar
My Photos: (1)
Well actually the entire thing is embeddable so just like your gps opens up in RR, this will do the same sort of thing as the install is right now.
Sponsored Links
vB code is On
Trackbacks are Off
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 19 05-20-2008 08:05 AM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 02:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 03:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 09:52 AM
Sponsored Links
