Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 07-13-2007, 01:14 PM   #931
The_Rocket's Avatar
Not reading settings?
Just installed and tried out everything but I've got some issues.
- When trying to use a formula in one of the temp inputs it doesn't seem to read the settings in the skin file. CELCIUS and FAHRENHEIT doesn't seem to do anything either..
- The skin editor does not save skin files.
2000 Ford Focus - Worklog
The_Rocket is offline   Reply With Quote
Old 07-13-2007, 01:26 PM   #932
Fusion Brain Creator
Are you using the newest version of our skin editor? (Version 0.3)
http://www.fusioncontrolcentre.com/F...g/software.php
greenman100 is offline   Reply With Quote
Old 07-13-2007, 01:29 PM   #933
The_Rocket's Avatar
Yes. Newest version of all software.
Old 07-13-2007, 01:43 PM   #934
I have used Version 0.2 of the skin editor with the newest version of the software.
Can you post part or all of your skin file?
This is more up Nick's alley, as he wrote the skin software, but perhaps I will be able to spot something.
Old 07-13-2007, 01:52 PM   #935
The_Rocket's Avatar
Here is the code for the input:
Code:
#STARTNEW# #NAME#Temp #TYPE#TEMPERATURE #SUFFIX# #PREFIX# #SETTINGS#((($t$ - .4) * 1000) / 19.53) #VIDPID#vid_04d8&pid_000c #SIZE#100,144 #LOCATION#80,80 #SHOWTEXT#true #PAGE#0 #DECIMALS#1 #PORT#6 #TXTCOLOUR#LightGray #BORDERSIZE#0 #FONT#Arial;12;Regular #PLOTLENGTH#100 #ENABLEHIGHSWITCH#false #ENABLELOWSWITCH#false #LOWKEYSEQUENCE# #HIGHKEYSEQUENCE# #HIGHTHRESHHOLD#0 #LOWTHRESHHOLD#0 #ENDNEW#
The skin designer is datet 9 July 2007 and is 272 Kb large.
Old 07-13-2007, 02:00 PM   #936
The_Rocket's Avatar
Entire skin file and output.
Old 07-13-2007, 02:10 PM   #937
The_Rocket's Avatar
Saw I was missing the
Code:
|t=VINC[!]
but this didn't help.
Old 07-13-2007, 02:17 PM   #938
Code:
#STARTNEW# #NAME#Temp2 #TYPE#TEMPERATURE #SETTINGS#((((($t$ - .4) * 1000) / 19.53) * 1.8) + 32)|t=VINC[!] #VIDPID#vid_04d8&pid_000c #SIZE#105,94 #LOCATION#121,0 #SHOWTEXT#true #TXTCOLOUR#LightGray #PAGE#0 #PORT#1 #BORDERSIZE#0 #PLOTLENGTH#100 #ENDNEW#
Works for me.
Old 07-13-2007, 02:17 PM   #939
Also, are your outputs working?
Old 07-13-2007, 02:22 PM   #940
The_Rocket's Avatar
All the analog output leds turn on and off. Tried your skin settings and still get the output in the 0.000 format with a reading of 0.782. Strange
Tried another port but same result.
Old 07-13-2007, 02:28 PM   #941
The_Rocket's Avatar
Just downloaded the 1.5 version and overwrote the 1.5.1 version of the .exe and everything worked fine.
Old 07-13-2007, 02:29 PM   #942
The LEDs are Digital outputs.
Make sure that if you're using my skin code, your thermometer is plugged in to port 1, which is the second port on the header, like this:
[Side of board] 9 8 7 6 5 4 3 2 1 0 [DIGITAL INPUTS]
Perhaps reading the user manual or uploading a picture of how you have everything hooked up would be beneficial.
Old 07-13-2007, 03:09 PM   #943
mp3gtr's Avatar
Mine has just cleared UK customs today!
mp3gtr is offline   Reply With Quote
Old 07-13-2007, 03:17 PM   #944
great, we will have Nick look at it.
Old 07-13-2007, 03:56 PM   #945
sporty_drew's Avatar
How can you put in multiple pages? I know there is a "page" button and line in the skin is this what controls it? I want to have a button on my main page (I have done) lead to a second page (will make if this is doable) that will have 3 buttons for outputs and one to get back to the main page. Is this doable? Thanks guys
1998 Camaro Worklog Pioneer P860MP, 3 JL 500/1's, JL 300/4, 3 12" Type R's, Diamond m611's
sporty_drew is offline   Reply With Quote
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 19 05-20-2008 08:05 AM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 02:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 03:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 09:52 AM
