Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 07-21-2007, 02:33 AM   #961
Fusion Brain Creator
greenman100 is on a distinguished road
Quote: Originally Posted by Arrow View Post
Hey guys. Mine came in today... Woo! But... Didn't get the USB cable with it...
This is probably a mistake - I'll check and most likely get a USB cable sent out on Monday.
greenman100 is offline   Reply With Quote
Old 07-22-2007, 09:58 AM   #962
neil_ross is an unknown quantity at this point
afternoon!
wow what a piece of kit! ive asked a couple of questions on another thread but thought i would ask here too, is it possible to have a skin for this that displays all the info (rpm, speed, temps etc etc) as analouge dials on the screen? like obd2 software?
EDIT: Other Post
Quote: Originally Posted by neil_ross View Post
Hi im fairly new to this forum, joined a while ago but havnt posted much yet!
can i just say this bit of kit looks amazing! my brain is going crazy thinking of the endless possibilities!!
it would be good to see:
oil temp
water temp
air flow
fuel flow
tyre temps
brake temps
speed
rpm ( with a shift light!)
police radar detector - for um detecting traffic accident areas!
oh and how could tyre pressure be done?
i presume this isnt for obd2 only?
the main reason i ever started looking at car pc's was to have all the obd2 info on screen but then found out my car was pre obd2 so this would finish my install off perfectly! just what ive been looking for!!
neil_ross is offline   Reply With Quote
Old 07-22-2007, 11:14 AM   #963
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
oil temp
water temp
air flow
fuel flow
tyre temps
brake temps
speed
This is completely independant from OBDII. Absolutely nothing to do with it.
anything that has a sensor on your car, can be interfaced with the Fusion Brain very easily. If it is a 3-wire sensor then pretty much directly, and if 2-wire sensors, then we will sell an adapter to make it work with the FB.
Anything that can be read on a car can be read through the Brain, the only limitation is price.
Oil & Rad Temp: They already have sensors so this is an easy integration oce you find the correct wires on your car.
Air & Fuel Flow: I am not really sure. Maybe Tim knows.
Tire & Brake Temps: The tire could be an IR thermometer, and the brake maybe as well.
Tire Pressure: Some cars I know have tire pressure sensors, so all you would need is the sensor from that.
Speed & RPMs: Well speed sensor can be found at the wheels and tach wire can be found usually by the engine. The tach wire can be used with a frequency to voltage converter. And you can trip an output with the voltage from an analogue, so you can use that as a shift light. If the voltage is at x where x cooresponds to a rpm, then turn output #y on else turn output y off.
As for the radar detector, you can interface it with the PC if you know something that the radar detector does when it detects a signal. Like lights up an led or something.
Old 07-22-2007, 11:26 AM   #964
oh my god this is soo cool!!! i feel like a school kid thats just discovered porn!!! LOL
so i could just buy a cheap radar detector that light up an led but replace the led with 2 cables that go to one of the input sensors?
i havnt got a clue about programing etc but i am an electrician so im half way there to being able to do a fair bit of stuff, if i connect an existing oil temp sensor to one of the inputs how will the pc know to read temp and not psi or something, do you know what i mean?
oh and could you tell me how much it would be shipped to the uk in pounds sterling?
thanks for the quick reply!
Old 07-22-2007, 11:46 AM   #965
2k1Toaster's Avatar
Well shipping to the UK is now a flat rate of $25 so like 12.5GBP. My post office is absolute crap and they charged me more than the $20 we originally had, so I increased it to $25 to be sure. If I can figure out why it is more for me to ship, and fix it, then I will lower it again.
And the software is now all formula based. It reads in a voltage no matter what. So a resistive sensor (2-wire) needs a resistor network to spit out voltage (3-wire) instead of resistance. I figure sinceyou said electrician I can say resistive and voltage instead of 2-wire and 3-wire.
So you need to figure out the coorelation between the output of the sensor and the actual values that are to be read. For instance it may be the voltage outputed multiplied by 1.5 or something and that will be how many PSI the timer is at. This is all configured in the skin.
As for the radar detector, yes pretty much. An led that lights up is the easiest. It could be 1 led or a led bar-graph. Since you are familiar with electronics you may be able to build a simple circuit to take the speaker outputs for the chirp and convert it from a beep beep to a on signal when beeping and off when not beeping. Shoudlnt be too hard.
Old 07-22-2007, 12:07 PM   #966
electrician - as in big industrial cable, panels etc.
electronics - still learning!!! lol
do you do a pre-assembled 2 wire to 3 wire converter? or is it fairly simple?
ive just downloaded the software so i will have a look at that, is it possible to have the information displayed as a load of analouge dials? i was wondering if its possible to use some obd type software to display the brain fusion data if you know what i mean!
Old 07-22-2007, 12:18 PM   #967
2k1Toaster's Avatar
We have not actually made the 2-3 wire converter yet. It is really simple. We are going to try and get one done so it makes everything easier.
And yes you can make guages. Using the same style as I used with the animated bar graph display as well as the animated thermometer. Just make an image of a dial, and then rotate the needle and save in as many steps as you want. So 1 image would be of the dial with the needle all the way at 0. The next would be the dial with the needle a little higher, and the next with the needle a little higher again and so forth. So yes it can be done.
Old 07-22-2007, 04:47 PM   #968
cool! i have started making a skin but ive just had a plan that might make it all a bit quicker! watch this space! lol
another question: when you use an exsiting temp sensor, (for instance one that monitors engine bay temps), how will it be possible for the brain to know what temps go with what voltage? if you dont know the temp as there is no current temp guage for that, you wont know what to tell it to display.
sorry if i dont make much sense but its hard to put a point accross when you dont know what your talking about!
Old 07-22-2007, 05:07 PM   #969
2k1Toaster's Avatar
All that information should be documented somewhere. It will be specific perhaps to your make/model/year or maybe make/model/generation or maybe just make who knows. So you would have to get your hands on the datasheet for it. Or when you find the sensor grab the manufacturer off of it and all the numbers and google.
Old 07-23-2007, 02:41 AM   #970
sporty_drew's Avatar
sporty_drew is on a distinguished road
2k1Toaster- Thanks again for help with the Pages, I got it to work perfect manually on both skins I've made. Now all i need to do is order my Brain
1998 Camaro Worklog Pioneer P860MP, 3 JL 500/1's, JL 300/4, 3 12" Type R's, Diamond m611's
sporty_drew is offline   Reply With Quote
Old 07-24-2007, 07:54 AM   #971
mp3gtr's Avatar
mp3gtr is an unknown quantity at this point
@neil_ross I've had mine arrive in the UK (thanks 2k1Toaster and greenman100) the nasty people at parcelforce worldwide will charge you a further £8.00 admin fee and you will have to pay the VAT on the import (unless you are VAT reg'd)
mp3gtr is offline   Reply With Quote
Old 07-24-2007, 01:09 PM   #972
cheers mate! the cheeky buggers!!
im not gonna order mine untill i find a spec sheet for all my sensors on the car with out put values on etc.
Old 07-24-2007, 07:39 PM   #973
kostyanj is an unknown quantity at this point
This is def my next purchase for my car. I'm just a little intimidated considering I'm not an electrician or an engineer. Do you guys still have units in stock? Any new sensors coming out on the horizon that we should know about?
www.computer-forums.net
kostyanj is offline   Reply With Quote
Old 07-25-2007, 09:18 AM   #974
we have about half our stock left (50 units).
No new sensors on the horizon besides air pressure, 0-150PSI
Old 07-25-2007, 12:18 PM   #975
will you be getting more when they go?
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 21 02-06-2009 11:33 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 03:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
