Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 08-02-2007, 09:31 PM   #1006
FC3S's Avatar
FC3S can only hope to improve
Quote: Originally Posted by helllordkb View Post
most of those ideas sound good, except , having the auto-lock I CANT STAND
. dont want it
if it autolocks above like 15km/h, and unlocks below 15km/h, then whats the problem, u like opening ur door at 50km/h?
anyway, u could just not use it
FC3S is offline   Reply With Quote
Old 08-06-2007, 02:14 PM   #1007
pim
pim is on a distinguished road
I would buy this board for a single specific application:
A Sony steering wheel adapter to Streetdeck input plugin.
I have this Connect2 adapter that translates the factory specific steering wheel commands to the Sony wire resistance protocol. The analog input of the Fusion Brain should be able to decode the Sony protocol and generate input events to Streetdeck.
I believe something similar exists for RoadRunner in combination with the Velleman kit.
Doable? I'd pay for someone writing the plugin.
Thanks,
Pim
pim is offline   Reply With Quote
Old 08-07-2007, 05:18 PM   #1008
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
There is now a new version of the software available on the website. It added the rotation feature as well as some others. The skin designer is also updated. You can find them both here:
http://www.fusioncontrolcentre.com/F...g/software.php
Old 08-07-2007, 05:20 PM   #1009
2k1Toaster's Avatar
Thanks,
Pim
Yes that is very doable. It would require you to change the resistive output to a voltage input scaled between 0 and 5 volts which is doable.
Old 08-07-2007, 05:24 PM   #1010
P3D4T0R's Avatar
P3D4T0R is an unknown quantity at this point
I get an unexpected end of archive on both the zip and the rar download of the skin designer
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
P3D4T0R is offline   Reply With Quote
Old 08-07-2007, 05:26 PM   #1011
2k1Toaster's Avatar
Just the skin designer?
I'll re-upload them now
Old 08-07-2007, 05:33 PM   #1012
2k1Toaster's Avatar
Ok, I was able to reupload, then download and open, so they should work now. My connection has been flaky the past few days, so that might account for the file corruption.
Old 08-07-2007, 05:33 PM   #1013
P3D4T0R's Avatar
Looks good now, thanks
Old 08-07-2007, 09:30 PM   #1014
ginigma is an unknown quantity at this point
Thumbs up
WooHoo. Finally powered up my Brain tonight and tested it with the lame skin I made. I’m using it in a Home Automation environment, not a CarPC. I don’t have anything connected to the outputs yet, but the LEDs light up. I have a couple thermometers I connected to the analog inputs and tested that and it works. Yay!
I’m really waiting for the COM interface so I can connect it to my HA software package. I haven’t tested the latest software. Still running 1.5.1. I’ll upgrade later this week.
ginigma is offline   Reply With Quote
Old 08-07-2007, 09:57 PM   #1015
kostyanj is an unknown quantity at this point
What are you planning on using that for? What are your final plans?
www.computer-forums.net
kostyanj is offline   Reply With Quote
Old 08-07-2007, 10:13 PM   #1016
I’ll be using it with the rest of my Home Automation system, which controls lighting, irrigation, etc. Initially I will be using the Brain for the following:
  • Monitoring my garage doors: My main HA software (PowerHome) will poll the Brain (via a COM interface) to see if the doors are open. This is based on a dry contact switch (open/closed). I will write a rule for something like if it’s after 6PM and a door is open, flash the keypad lights that are right by the entryway door. As I’m walking by, or when I pass by at night to go to bed, I will see that the doors are open and I can close them. (I don’t want to close them automatically in case there is something (car) in the way.
  • Monitoring places for water (by my water heaters and washing machine): pretty much same as above. If water is detected, PH will send me a text message on my cell phone.
  • Monitoring occupancy: Use the Ultrasonic sensors and Temperature sensors to monitor if anyone is on the room. If not, turn off the HVAC in that part of the house. Possibly will use the outputs for this, to control the furnace.
And I’m sure a whole slew of other things!
For my lighting and irrigation control, I am currently using Insteon. There’s a company that makes an Insteon compatible I/O controller, but it only has 2 inputs and 4 outputs (or vice versa) and costs $135. The Fusion Brain is less expensive and provides way more I/O ports and flexibility. Ok, I’ll have to write some software for it, but that’s Ok.
Old 08-11-2007, 05:31 AM   #1017
ghosty is an unknown quantity at this point
If i want to get down to the nity grity program end of things what do i need to learn?
Would it be VB.net or something else?
ghosty is offline   Reply With Quote
Old 08-11-2007, 01:36 PM   #1018
2k1Toaster's Avatar
It is is C#.NET and the source files as well as entire "project package" is releases on the website for Visual Studio 2005
Old 08-12-2007, 05:08 AM   #1019
loginfailed's Avatar
loginfailed is an unknown quantity at this point
Can this fusion brain do this?
http://forums.fluxmedia.net/showpost...9&postcount=10
Take a positive input and send out a keyboard command the once the positive input goes away, send out another different keyboard command?
loginfailed is offline   Reply With Quote
Old 08-12-2007, 05:18 AM   #1020
2k1Toaster's Avatar
Yes absolutely. Very simple to setup and can be done 2 ways as well. As long as you know the Centrafuse hotkey.
Spread the word over on the flux forums for us!
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 21 02-06-2009 11:33 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 03:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
