Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 04-08-2007, 08:26 PM   #91
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Quote: Originally Posted by Ruffy View Post
poop i wasent selected as a beta tester.
POOP I SAY!
Sorry. We only have 6 board coming now to test them out. 1 for me, 1 for Tim, and 4 for betas.
and @ redian: I have no clue what this is: !
But maybe it can be our mascot!
Old 04-09-2007, 04:44 AM   #92
2k1Toaster's Avatar
Ok. I am putting the final "flare" on the software, and would like some input.
What do you want the software to do based on conditions from the inputs?
Right now button presses to applications, as well as change the state of an output are possible, but what else do you guys want?
The button press pretty much encompasses everything, but I thought I could get some opinions.
Here is your chance to chime in!
Old 04-09-2007, 04:50 AM   #93
h3rk will become famous soon enough
Maybe timers. Like time delay relays. If you press a button it will stay on for X seconds or or wont activate for X seconds. outputs are tied to on_click events? What about triggering outputs to activate upon inputs, or combination of input and button, which could be mapped with software.
h3rk is offline   Reply With Quote
Old 04-09-2007, 04:51 AM   #94
2k1Toaster's Avatar
I should also add, anything special in particular about the software maybe?
As of now it can be skinned, log analoge input data and be externally controlled to put it simply. Of course the skinning includes options from changing the font on the buttons to the images to running hidden in the system tray.
So suggestions?
Old 04-09-2007, 04:53 AM   #95
P3D4T0R's Avatar
P3D4T0R is an unknown quantity at this point
Open source? A way to hack the firmware?
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
P3D4T0R is offline   Reply With Quote
Old 04-09-2007, 04:57 AM   #96
Trigger-able (alarm-like) events based on analog setpoint levels. For example, if battery voltage is low it could start the vehicle and recharge for either a prescribed time or voltage, assuming other prerequisites are met. Something that would allow a user to set something like that (or similar process) up. It'd be nice if the hardware had a wake-on-lan output for that however.
But that takes some smarts (PIC-smarts, not badger smarts) Is there a controller?
Last edited by h3rk; 04-09-2007 at 05:01 AM.. Reason: added 2nd paragroph/ sentence.
Old 04-09-2007, 05:02 AM   #97
2k1Toaster's Avatar
Done. You can make it an "animation" with only 1 frame which would be on, and then have that frame repeat x amount of times. Each frame/iteration takes t seconds. t is user settable variable between 250ms and 1s which is the update frequency of the PIC. So if you want it on for 10 seconds then set 10/t is the number of iterations needed.
Is this too complicated for people? I figured it would be very easy once people understand it...
You mean the digital input is fooled into thinking that the button is being pressed for x seconds when it is really only being pressed momentarily? This could cause havoc in my eyes. Why out of curiosity?
Not sure what you mean. Of course when you push the button for the digital output an onclick event is triggered and it changes the output next refresh cycle (250ms to 1s).
The temperature, photocell, and potentiometer can all do this. I dont see a need for the accelerometer other than to flash "Slow the F down crazy man" after like 10g's.
Interesting... Definately implementable... What would the benefit of this be though? That would mean a button only works if the analog input is within specs... So no volume control while the accelerometer reads more than x g's? I dunno.
Good ideas. And I am not critisizing, I just want to see where the ideas lead. I am always interested in ideas!
It will be open source.
Hack the firmware? If you want, we shall add!
But everything is done software side which is completely open source once we get it up and running.
the PC must be on in order for the device to function. That way you dont have to shut it down when you leave. Neither of these are doable in the way you might want.
If the PC is on, car is off, then yes it could theoretically start the car, but the PC will drain the battery by being on, so sort of a viscious circle!
And the PIC makes no descisions such as interpretting a WOL signal. It only gets and sets the inputs and outputs and sends it to the PC to figure out. Sorry.
Old 04-09-2007, 05:20 AM   #98
Right on!
If the 'tied' output turns on with one press. The timer would cause it to turn off after set time. Possible use would be an actuator. It would prevent someone from having to use limit switches on their rocker-panel rocket launchers.
Sweet.
Safety interlocks. "you cant do this because you're not going Fast Enough" would be more my taste.
All of my ideas can't be top-notch, but I have my moments. But I think you may know I'm not advertising all of them...yet. But you get to the good ones by blurting out all of the bad ones and getting them outta the way.
..I was thinking more like sending...
But I understand, making smart I/O's with universal use in mind isn't the same.
Oh and by the way I'd like to reserve a place in line for when they become available to the rest of us, if I may.
Old 04-09-2007, 06:55 AM   #99
P3D4T0R's Avatar
Sweet... Thank you.
I was wondering for the outputs if there could be a "save state" and/or "default state" option. What I mean is when the computer is powered off the board will keep whatever state it was in but also be able to return to its default state if wanted. I dont know if that made sense, if it didn't ill fix it later.
Old 04-09-2007, 07:11 AM   #100
I like that idea. The each output could have two attributes like:
.state.default=1
.state.last=0
Old 04-09-2007, 09:42 AM   #101
speedy_parker's Avatar
speedy_parker is an unknown quantity at this point
from h3rk:
This is looking great! Thanks for all the work guys.
speedy_parker is offline   Reply With Quote
Old 04-09-2007, 09:45 AM   #102
greenman100 is on a distinguished road
.state.default=1
.state.last=0
Already implemented.
greenman100 is offline   Reply With Quote
Old 04-09-2007, 09:45 AM   #103
Quote: Originally Posted by speedy_parker View Post
from h3rk:
Oh great, someone must have caught me out on the town, in drag, and now thinks I'm a she.
Dammit, it was just one night
Old 04-09-2007, 10:49 AM   #104
from h3rk:
There will be 100 available immediately. There is no need for worry as to stock.
Old 04-09-2007, 12:12 PM   #105
2k1Toaster's Avatar
Right on!
Already done!
Keep them coming!
Sweet... Thank you.
.state.default=1
.state.last=0
done.
Not the last state, but default state is saved as can be referred to by pushing the big 'ol default button on the screen. It is also the state that is loaded when the app starts. So if you want your lights on when the board comes on, but not your 3gillion dB bullhorn, you can set that.
You beat me to it!
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 21 02-06-2009 11:33 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 03:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
