Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 10-15-2007, 12:19 AM   #1066
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Quote: Originally Posted by h3rk View Post
How do I get the skin designer to let me do anything without a fusion brain and/or driver installed?
Edit: And I'm not sure how to access the debug console in FCC. Open something in VS?
The skin designer (1.9b) and all above works with no Brain attached. Just do like normal, click the "+" to add a brain, it will tell you none found, then pop up a box. Sice nothing is connected the main area in the popup will be blank. Click the add manual button (bottom left) and enter the VID/PID/IID you want, (or just use default and change once the brain is actually connected). Then it will all work.
And to access the debug console in the program, it is done while the program is running. Click about 1px to 3px from the very top of the application. Then within a few seconds, hold down Control, Shift, and the Alt key on the left side of the keyboard. While holding all 3 down, type in D E B U G and a debug window will popup.
Old 10-15-2007, 12:28 AM   #1067
h3rk will become famous soon enough
Ok I got to that point before, I didn't realize I had to select that brain once it appeared and push, 'send back selected brain'. I'm off and rolling now, and you have some more stuff for your documentation.
Thanks!
h3rk is offline   Reply With Quote
Old 10-26-2007, 05:19 PM   #1068
greenman100 is on a distinguished road
Quote: Originally Posted by FalconX View Post
When G-meter is expected to be available? Any time schedule?
couple weeks
greenman100 is offline   Reply With Quote
Old 11-22-2007, 02:33 AM   #1069
2k1Toaster's Avatar
It is available now.
Old 11-22-2007, 02:34 AM   #1070
2k1Toaster's Avatar
Ok, here is the beginnings of Fusion Control Centre Uber Edition: http://www.mp3car.com/vbulletin/soft...ml#post1144574
I need people to start making skins and reporting back on what is happening if you get errors.
Old 11-26-2007, 01:18 AM   #1071
Arrow's Avatar
Arrow is on a distinguished road
Is it within the current capabilities of the software to have a timer that runs for about 10 minutes, then based on the time in milliseconds, trigger about 300 events during that time? I want to have a start button, that starts the timer, then the events all happen in the order and time that I defined them.
Arrow is offline   Reply With Quote
Old 11-26-2007, 11:01 AM   #1072
FLAC is for flaccid
parksgm's Avatar
parksgm will become famous soon enough
Hmm...what are you planning? Sounds interesting (and complicated).
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 11-26-2007, 11:37 AM   #1073
LYHTSPD is on a distinguished road
I would bet that he is working on a Rube Goldberg machine. He is in West Lafayette, IN so my money is on that he is a Purdue student. I graduated from Purdue as well!!
I always thought that the RG machines were supposed to be all mechanically activated stuff.
LYHTSPD is offline   Reply With Quote
Old 11-26-2007, 05:49 PM   #1074
Arrow's Avatar
I originally posted it here, but I decided to start it's own thread because I don't want to clog this thread up with stuff about my project. See here for what I want to do.
Old 01-07-2008, 05:00 AM   #1075
pyro6314 is an unknown quantity at this point
hey 2k1Toaster, The links on your flash header in your webpage dont work in firefox. just letting you know.
Since here seems to be the place, How is the development coming on the Street Deck Addon? Anyone doing any work on HVAC controls. I was thinking touch sliders for fan and temp control, snap to slider for blower selection, and buttons for others. I have an RSX and would love this feature as I plan to put gauges in place of the old HVAC controls. I am pretty useless as far as the programming but can do the electrical digging in vehicles.
pyro6314 is offline   Reply With Quote
Old 01-07-2008, 06:22 AM   #1076
The top-header links work for me in firefox(2.0.0.11). However, on a few pages the new schwag pic comes up as a broken link.
There's a thread for new website errors here, but I'd thought I'd reply here so you'll likely see it.
I'm working on HVAC controls, check out the modernity thread and my Automatic AC controls thread
In case you found this thread through a search, there is a whole subforum for the Brain to thumb through here.
Old 01-07-2008, 04:45 PM   #1077
Wow, Im really behind the times. Guess I have a ton of reading to do. Thanks
Old 01-08-2008, 12:20 AM   #1078
2k1Toaster's Avatar
Just to let you know as well, it works in FireFox 1.5 as well.
The flash uses "unsafe" linking so for instance IE blocks it until you click it, but who cares about IE. So if your security settings or something are high, then it could block it.
Old 01-13-2008, 01:12 PM   #1079
novorado is an unknown quantity at this point
Well we havent tried the application running under WINE. I don't see why it shouldn't work. It will be open source, so no active decompiler restrictions or anything. Right now the software is still in testing and developement as well, and when the first version is complete, it will be a free download on our "yet-to-be-determined" website.
--Nick
A great product indeed. It is especially interesting if we can use it in Linux environment for frontend that we are currently developing (which as well supports commercial and RoadRunner skinning). Is there any developer documentation available (I guess source code on windows is open), is there are any plans for linux kernel support? Thanks.
C52B3901A0B3248C2BB13302DAB0F3E6
novorado is offline   Reply With Quote
Old 01-13-2008, 05:28 PM   #1080
2k1Toaster's Avatar
I wont be doing any linux support myself, but you are welcome to port it or whatever you want. You can use the dlls, the drivers, whatever you need. I am focusing on XP and Vista though.
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 21 02-06-2009 11:33 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 03:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
