Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 08-04-2008, 02:22 PM   #1096
SPElectronics is an unknown quantity at this point
Hi 2k1Toaster, do you happen to offer the Fusion Brain in "kit" form? I mean, just the blank pcb and parts, for those of us that like to do our own assembly? I'm an electronics repair tech, and sell my own various boards and misc., so I always prefer to do my own assembly whenever possible, especially if it saves me $$.
SPElectronics is offline   Reply With Quote
Old 01-22-2009, 11:00 AM   #1097
partgypsy is an unknown quantity at this point
How to calibrate engine sensors
I'm interested in using Fusion Brain on older (pre-computer) engines. Currently the sensors send volt or ohm values to analogue gauges on the dash. Does set-up involve calibrating to match the readings on the existing gauges? If so, then there would be no increase in accuracy. Is there another way of calibrating to ensure greater accuracy? For example a table of values for a sensor showing: " 46 ohms = 40 lbs oil pressure" or whatever.
partgypsy is offline   Reply With Quote
Old 01-23-2009, 01:20 PM   #1098
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
If you want to calibrate it then you need to find what it is supposed to be from whoever makes it. If you get an accurate table of values, then you find a best fit line that goes through them and put that function into MDX and it works.
Old 02-03-2009, 12:11 PM   #1099
GadgetBandit's Avatar
GadgetBandit is an unknown quantity at this point
Greenman100,
on 3/6/08, you posted an Air Ride skin. Could you send the xml to me? It'd teach me how to increment/ decrement a temperature setting.
Thanks,
GadgetBandit
GadgetBandit is offline   Reply With Quote
Old 02-19-2009, 07:31 PM   #1100
White_Comet is an unknown quantity at this point
I'm new to the mp3car forum and will be building my first carputer for my 1987 Mazda RX-7 in the next few months. Since I have some VERY specialized functions in mind, I was going to get a USB relay board and USB servo controller, but the Fusion Brain blows then out of the water with its sheer user-defined expandability. Brilliant work and an A+ to everyone that contributed to it. It's definitely going to be my birthday present to me
Has the servo control been implemented yet? I read all 74 pages in this thread today and have not found a definitive answer. Also, how is the linux version of the software coming along? I abandoned Windows last November due to OS-killing malware in favor of Ubuntu 8.04 and am planning on using linux in my carputer. Overall, the Fusion Brain looks like an incredible piece of hardware and it just wouldn't be right if it wasn't supported in Linux, the software that wrote the book on open-source!
White_Comet is offline   Reply With Quote
Old 02-19-2009, 10:21 PM   #1101
2k1Toaster's Avatar
You might want to check out the eyeR module as well that clips onto the Fusion Brain. (We do not make it fyi).
Linux short answer: We don't but someone just made a library for it (at least with Ubuntu)
Here's the Linux scoop though... I cannot find a driver that is stable on Windows that will work with Linux. In all honestly, Windows is still used the most hands down above anything else. It has the most support and the most usage. So when we tried a driver that was stable on Linux, it turned out it was not stable on XP or Vista and had a lot of locking problems. If I use a driver that is 100% with Windows, I lose Linux support but the majority of our customers are then happy. So it is a can't please everyone thing, and it makes sense to support that which is most supported, Windows.
But like I said someone just came out with a Linux library just recently (past week or so). So you may want to check into that. But all the +'s of MDX cant be used as it is not Linux compatible.
Old 03-07-2009, 06:57 AM   #1102
ausloki is an unknown quantity at this point
Network interface
I have seen some small footprint NIC's available these days. How hard would it me to add one to the fusion series?
A small control circuit could then be written to use something like an snmb mib library to poll for data or even switch ports on and off.
I have several old online UPS circuits that don't have smart interfaces just a bunch of LED outputs to indicate different states. Something like the fusion with a network interface would be ideal.
ausloki is offline   Reply With Quote
Old 08-16-2009, 03:14 PM   #1103
ellislake is an unknown quantity at this point
can i use this in conjunction with a motor so it wil turn a motor a certain amount of times,because i have all my ac controls and stuff which are elctrical but i have one manually operated one which i want to reomve from the dash and hav it comtrolled by the pc.also how would i use this software to select a different function on my ac unit,ie i can turn a knob round and it puts heat up and turn it left and it lowers temperature etc.how would i use this software to do that so i can reomve the knob from my dash,thanks this osftware is excellant from what i have read about it,hardware seems neat and small aswell which is brilliant well done guys
ellislake is offline   Reply With Quote
Old 08-16-2009, 03:17 PM   #1104
2k1Toaster's Avatar
Everything is doable, but hvac is a lot of work.
Old 08-17-2009, 04:38 PM   #1105
sorry your post has lost me,how would ur product work, for what i want it for ???
Old 08-17-2009, 04:48 PM   #1106
2k1Toaster's Avatar
everything is controlled through an output port, and feedback/sensors are given through input ports. That's it. Wiring is different for every car between HVAC and FB. Software wise, it can be as simple or complex as you would like.
Old 08-17-2009, 04:55 PM   #1107
trader007 can only hope to improve
if you do hook your pc up to your hvac controls, i would definitely wire them to have a manual backup mode- some relay you can activate that will turn the controls back to physical knobs... just like with remote starters, if you dont give yourself a safety net youre just asking for trouble.
i honestly think tying in HVAC controls is a bit overkill.
trader007 is offline   Reply With Quote
Old 08-18-2009, 02:42 PM   #1108
ok well to be honest if im going to do it i wanna completely get rid of the heating control module or hide it and use the pc,to be honest if the fusian brain goes wrong ill just replace it same with pc,so not fussed about having some sort of manual control i always take risks with my car and its ok so far.lol
cheers
still not sure how the input sensors would work on the brain
Old 08-18-2009, 02:45 PM   #1109
what does HVAC and FB mean.what do they stand for exactly. it may help me to understand ur product.i can see how it would be used to control my window motors as i jsut hook it up to the switches their already and once power is sent threw it will turn on the switch,im assuming the fusian brain would have to be connected to a relay which puts power to the window motors or does fusian brain have a high power output already ?
??????? thanks
Old 08-18-2009, 02:51 PM   #1110
sporty_drew's Avatar
sporty_drew is on a distinguished road
??????? thanks
HVAC- Heating, ventilating, and air conditioning.
FB- Fusion Brain
It uses relays for switching power.
1998 Camaro Worklog Pioneer P860MP, 3 JL 500/1's, JL 300/4, 3 12" Type R's, Diamond m611's
sporty_drew is offline   Reply With Quote
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 21 02-06-2009 11:33 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 03:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
