Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Fusion Brain
Old 08-18-2009, 02:53 PM   #1111
ellislake is an unknown quantity at this point
Quote: Originally Posted by sporty_drew View Post
HVAC- Heating, ventilating, and air conditioning.
FB- Fusion Brain
It uses relays for switching power.
lol thanks,
do u understand how fb can control a knob that i turn to increase or decrease my temperature in the car ?
cheers
ellislake is offline   Reply With Quote
Old 08-18-2009, 02:58 PM   #1112
sporty_drew's Avatar
sporty_drew is on a distinguished road
Have you checked out the Fusion Brain website? They have a lot of good information. How you will go about hooking it up to the car depends on your car.
1998 Camaro Worklog Pioneer P860MP, 3 JL 500/1's, JL 300/4, 3 12" Type R's, Diamond m611's
sporty_drew is offline   Reply With Quote
Old 08-18-2009, 03:00 PM   #1113
canbus elctrical system.
car : seat leon mk2 ill look on their website, think ihave b4 but wasnt clear.
i do not alot about electronics but just cant get any simple answeres from fb guys
Old 08-18-2009, 07:29 PM   #1114
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Well I don't know what your electrical knowledge is. You are trying to tackle THE HARDEST possible automation that can be done in a car maybe apart from auto-pilot. And what makes it hard is that everyone is different.
I don't mean they are all different as in laptops. Sure they are all "different", but underneath they all have the same parts just in different locations and grades of quality.
HVAC systems are completely different. Take a tech that worked on X brand of car's HVAC his whole life and give him Y brand of car's HVAC, and most usually nothing will be familiar.
Everything that clicks or pushes switches electricity somewhere to turn something on or off. A relay connected to a digital output does the same thing. You have to figure out where to put it. It is impossible for me to say "cut the red wire and put the relay between it and the flux capacitor". Every car is different. You should be familiar with electronics or at least have the patience to try it out before you attempt this. Every knob or dial that doesnt turn things on or off, but changes something that is already on, would be controlled by relays or PWM through MOSFETs. Anything you want as feedback like temperature or anything you want to display such as status of things, would connect to an input.
Old 08-18-2009, 08:48 PM   #1115
trader007 can only hope to improve
i just dont really follow the benefits. any late model car has climate control, and works off a temp guage already. you will never make a pc setup thats as easy to use or as nearly reliable as an OEM system... im trying really hard to see the benefits of controlling your hvac with the carpc i just cant grasp the idea
trader007 is offline   Reply With Quote
Old 08-18-2009, 10:03 PM   #1116
greenman100 is on a distinguished road
Some people want to put a screen where the controls are.
greenman100 is offline   Reply With Quote
Old 10-06-2009, 10:26 PM   #1117
DANNYDOTNET's Avatar
DANNYDOTNET is an unknown quantity at this point
Like on a mobo can you make a fusion brain with a 4pin usb connector?
Good Luck
Follow me on twitter @Danny117
DANNYDOTNET is offline   Reply With Quote
Old 10-06-2009, 10:50 PM   #1118
I've got one with dual zone automatic temperature but it doesn't do anything by voice. So instead of saying "turn up the heat" I have to go through the agony of pressing the temp button on the steering wheel.
Good Luck
Old 10-06-2009, 11:17 PM   #1119
good point. it was dumb to say, its cool to even attempt this.
Old 11-06-2009, 02:03 PM   #1120
sgtpepperaut is an unknown quantity at this point
anyone know what voltage the digital input/outputs ports accept on a V4 board? not quite sure how to deal with them.
any help appreciated
thx phil
sgtpepperaut is offline   Reply With Quote
Old 11-06-2009, 03:42 PM   #1121
2k1Toaster's Avatar
thx phil
The Digital Output ports give out the same voltage as what is supplied. So if you power it with a 12v system, you get 12v out at roughly 400mA to 500mA.
The Analogue Inputs (Can be used for digital too) can accept a maximum of 5v and a minimum of 0v.
Old 11-06-2009, 07:41 PM   #1122
i seee,
and the digital ins are "on" when voltage is greater than 0?
so lets say i want to create and indicator that displays if my headlights are on....i connect the POS 12 to a (one) digital input port?
also im trying to hook up my "radio detector" to my ride runner. I was thinking of running cables from the LEDs that come on when a signal is detected to the fusion brain and make it trigger a skin saying "kA band detected" etc.... just a tough.
on a side note...
i showed the board to my electrical engineering professor today... he was quite fascinated and said "i need one of them little gadgets!"... he was asking about sampling rate and A/D conversion accuracy ...i pointed him to your website...
Old 11-07-2009, 12:21 AM   #1123
2k1Toaster's Avatar
i seee,
on a side note...
If you have a Version 4, then you dont have any digital inputs. But what is digital? Its an analogue value that is usually at one of two values. Therefore, you can use the analogue inputs to measure on/off values. Best of both worlds.
If it was a digital input on Version 3, then anything between 0v and 0.7-0.8v is considered a 0. Anything between 4.2-4.3 and 5v, is considered a 1. Anything inbetween is undetermined, and can have random values.
Also dont connect anything that outputs more than 5v. So your 12v signal needs to be divided and hopefully isolated, then connect it to an input.
The LED indicators will work well. Those values shouldnt be too large, but again always use your multimeter before the magic electronics smoke escape.
The sampling rate is actually quite high, but most of it is thrown away. We used a methodology of the PC gets data when it asks for it. Resolution is 10bit.
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 21 02-06-2009 11:33 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 03:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
