Go Back   MP3Car.com > Mp3Car Technical > GPS > Garmin Mobile PC
Old 10-07-2008, 08:46 PM   #16
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
Good news
All previous versions of Garmin Mobile PC were unable to use virtual com port created by Franson GPS Gate. The current version of GMPC 5.00.50 is able to work with GPS Gate
Bad new
The current Garmin Mobile PC version 5.00.50 has the intersection search feature broken. Hopefully Garmin will fix this soon.
Garmin Mobile PC
Marvin Hlavac is offline   Reply With Quote
Old 10-10-2008, 03:43 AM   #17
angelinalove is an unknown quantity at this point
thanks for info I was also wondering with same problem.
Mario kart wii
angelinalove is offline   Reply With Quote
Old 10-10-2008, 02:47 PM   #18
Sicarius is on a distinguished road
Quote: Originally Posted by Marvin Hlavac View Post
Good news
I just use the Xport application posted elsewhere on the forums.
Oddly enough GMPC won't work directly with the serial port created by the USB driver for my GPS device but works perfectly with the virtual port created by Xport.
Sicarius is offline   Reply With Quote
Old 10-10-2008, 02:55 PM   #19
Then let me take a wild guess: You must be using a Garmin USB GPS receiver(?).
Garmin Mobile PC
Old 10-13-2008, 02:38 AM   #20
Nope, a Wintec G-Rays I (WBT300).
Old 10-20-2008, 03:07 PM   #21
snoopbiscuit is an unknown quantity at this point
Using GMPC with Microsoft USB GPS
Hi,
Does anyone have any experience or knowledge with using the Microsoft/Map-Point GPS with GMPC?
I am wondering if I will be able to use it since I already have it or if I should buy the GMPC with the included USB Device. Any comments or suggestions greatly appreciated.
snoopbiscuit is offline   Reply With Quote
Old 10-20-2008, 06:33 PM   #22
All of the Microsoft GPS receivers, the old GPS-360, the newer GPS-500, and even the upcoming u-Blox USB GPS stick, work just fine with Garmin Mobile PC.
Garmin Mobile PC
Old 10-20-2008, 06:38 PM   #23
Thanks Marvin. I have the GPS-500 right now, and I am probably going to buy GMPC to go with it. Only thing, I just read that if I do not use their GPS reciever, then I can only register the software on one comp. Well, I am testing on different box, so does that mean that I won't be able to port the software over to the production unit when the time comes?
Old 10-29-2008, 01:33 AM   #24
Kosti is on a distinguished road
Quick Question:
When launching GMPC, it takes ages to come up on my desktop PC and I find the NAV very average performance compared with say Destinator 6.
I'm using the latest version of GMPC 5.00.50 with 2009 MAP for Australia, How can I get this to improve? Is it because my MAP is large 115Meg?
I've only started playing with Garmin so it's possible I've not unlocked it the rightway or something, any help on getting this to load faster?
Kosti is offline   Reply With Quote
Old 10-31-2008, 09:49 AM   #25
Kawa13 is an unknown quantity at this point
Mapsource 6.14 & Garmin Mobile PC problem
Hi everybody. When I try to upload maps with mapsource ver (6.14.1) to my installed GarminPCMobile ver (5.00.50) I get an error : problem of communication with the Garmin peripheral . Syntax of the file name, repertory or volume incorrect !
Has anybody an idea of what I'm doing wrong ?
Cards a for sure unlocked...
Thanks a lot in advance
Kind regards
Kawa13 is offline   Reply With Quote
Old 10-31-2008, 02:03 PM   #26
Kawa13, you are most likely not doing anything wrong at all. The issue is the Garmin's latest version of MapSource (6.14.1). Solution is to use v.6.13.4, as per information in: How to install MapSource to add maps to Mobile PC
Old 11-01-2008, 02:15 AM   #27
Minoritydan is an unknown quantity at this point
When you guys install Garmin and look in the device manager, where do you see the USB GPS Sensor?
Mine shows up under
Garmin Devices:
--Garmin USB Sensor
Not under Ports.
Is this correct?
I've noticed sometimes after I've been away a while the GPS will not have a signal at all and I will have to unplug the sensor to get it to work again.
Minoritydan is offline   Reply With Quote
Old 11-01-2008, 12:01 PM   #28
Thank you Marvin Hlavac, but the link does not seem to work... Any idea wher I could download this 6.13 Mapsource version ?
Old 11-01-2008, 12:11 PM   #29
To download older versions of Mapsource
Hi
Found it by myself !
http://www8.garmin.com/software/MapSource_6134.exe
change "6134" in previous or newer version for ex "6137" you like to download and there it is.....
Enjoy
Old 11-06-2008, 09:55 PM   #30
Quote: Originally Posted by Kosti View Post
Quick Question:
Any solution for the above?
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
