Go Back   MP3Car.com > Mp3Car Technical > GPS > Garmin Mobile PC
Old 03-07-2009, 01:11 PM   #76
Carz is an unknown quantity at this point
Quote: Originally Posted by Firebird2 View Post
Hey dudes,
I am running the latest GMPC and XPort. All is working great except when the system comes out of Suspend mode GMPC grabs Com Port3 which is the main port. XPort should be taking this and the GMPC should be on 5, Sygic on 6 and RR on 7.
Any ideas how I can set the port number in GMPC to 5.
Cheers
I've the same issue. The physical port should not be used by any application except XPort so that it can properly split the signals to other virtual ports.
Have you found a solution to make GMPC not so "smart" to autodetect ports?
Carz is offline   Reply With Quote
Old 06-12-2009, 12:00 PM   #77
phrasius is an unknown quantity at this point
Got this installed today with the City Navigator 2010.10 maps. Was previously using Sygic. Does anyone have any comments about the POI's with these maps? Are they better than the TeleAtlas that Sygic uses?
phrasius is offline   Reply With Quote
Old 06-15-2009, 09:06 AM   #78
zillacles is an unknown quantity at this point
Has anyone come up with a solution for attenuating volume when GMPC is speaking instructions?
zillacles is offline   Reply With Quote
Old 06-15-2009, 04:38 PM   #79
Sicarius is on a distinguished road
The only thing I have seen to do this is IndieVolume. I haven't tried it yet but I'll probably need it myself as my project nears completion.
Sicarius is offline   Reply With Quote
Old 06-15-2009, 04:47 PM   #80
Wow thanks for the link. I'll try it in a couple days after my last exam. I hope it works as it will be easier of the solution I was thinking of - using two different sound cards and manually muting :P
Old 06-17-2009, 07:09 PM   #81
Blues is an unknown quantity at this point
Windows Vista and 7 has a built-in Voume Mixer with per application volume control.
Not as advanced as IndeVolume though, becuase IndieVolume can add "exclusive" applications. When an application marked as "exclusive" plays a sound, IndieVolume automatically mutes all other applications.
Btw. this link is dead at the moment: http://www.indievolume.com
Blues is offline   Reply With Quote
Old 06-22-2009, 10:45 AM   #82
The link works fine for me? http://downforeveryoneorjustme.com/indievolume.com
Anyway I installed v3 in my car (XP Pro SP3 nlite'd) and when Garmin speaks it mutes Winamp, though it seems to cut out after the first word. I only got to play around with it for a few minutes, tomorrow I'll try the new version and see if it works any better. But at least it's getting somewhere.
Old 06-22-2009, 05:42 PM   #83
Works fine for me now too. But at the time I made the post it didn't work. Tried several times both Firefox and IE8, but no luck then.
Old 06-25-2009, 11:56 AM   #84
Have you tried out the program? Mine still cuts out after the first word but I haven't tried the latest version yet.
Old 06-29-2009, 05:41 PM   #85
Anyone using Centrafuse have better luck with GMPC and IndieVolume?
Old 06-30-2009, 09:40 AM   #86
I just tried the latest version in WinXP Pro SP3 with Riderunner using Winamp and GMPC. When Garmin speaks it does mute the sound but it only speaks for ~1sec then gets cut off and there is no sound until the music is unmuted. I tried running just Winamp and GMPC, does the same thing. Tried foobar2000, and WMP (playing a video as well). GMPC always gets cut off. Increasing/decreasing the delay time in IndieVolume didn't help either...
If it is able to be made to work I would buy it but it doesn't seem likely unless they fix it? Apparently it was a problem with nRoute in one of the old releases:
"IndieVolume 2.1.65.131
Date: June 28, 2007 Size: 1.35 MB
Changes since previous version:
- fixed bug IndieVolume was truncating sounds in Garmin nRoute"
Looking at this page they do mention that they do guarantee a 2 business day resolution if you have any problems. I'm thinking about buying it and seeing if they can fix it, does that sound like a good idea?
Unless someone else can give it a go and see if it does the same thing to them.
Old 07-02-2009, 07:57 AM   #87
mrbombastic is an unknown quantity at this point
I've tried indievolume(IV) with a different result. I got this to work running RR, when gmpc speaks it mute winamp, but at times IV give me an error and have to click continue before it works again. I email IV manufacture approx 1 weeks ago with error and a question about the ability to lower winamp volume instead of muting but have not heard from them yet. Also, for my setup when GMPC speaks i hear the full direction instruction. If they fix this error I'll buy the software.
mrbombastic is offline   Reply With Quote
Old 07-02-2009, 08:10 AM   #88
What do you mean by "indievolume(IV)" ? The latest one I can see on their site is IndieVolume 3.4.89.158. Also what version of Garmin are you running? I have version 5.00.60 which is the latest from the Garmin site as well. Oh and are you on XP?
I also emailed IndieVolume about my problem, and although it's only been a few days I haven't got a response either.Kinda sucks because it seems like the only software solution I can find
Old 07-08-2009, 08:04 PM   #89
Okay I'll be starting with a fresh install of Windows now that I completely FUBAR'ed my system, so hopefully can get IndieVolume to work.
Will update on this later during the week
Old 07-08-2009, 10:09 PM   #90
Well, I finally got to try Indievolume. I don't know if it's my USB sound card or what but when it's enabled, the sound from GMPC stutters very bad. I didn't get as far as trying it with some music in the background; it was so bad that that was a deal-breaker right there.
Damn. And I had such high hopes for it.
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
