please help me it would make me sooooo happy
OK I have now tested the IR2PC module on two computers other than my via epia 5000, it worked on both of them.
I did a few more tests on my via and realized a couple things. I downloaded the winamp plugin for the Ir2pc module from the web site...Then started up winamp, if the serial module is not connected to my computer when i start winamp it will say "unable to initialize IR2PC module" (since its not hooked to the computer at all) If i then hook the serial module to the serial port and restart winamp, it does not give me the "unable to initialize IR2PC module" ERROR message, so this must mean that the serial port is not bad, or defective, but just set up incorrectly.
I tried a couple cmos settings, but half of the stuff in cmos i dont entirely understand, The bios has been flashed to the latest bios version successfully. I am so stumped on this one... I cant really use some ideas guys... I am sooo confused. Thanks for any help you can provide.
EDIT: I have tried using the: FAST and FAIL SAFE bios settings, I am running Windows 98 on one drive, and just dos on the other, the module will not work in either dos or windows. but works fine on two different computers in both dos and windows
