The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 05-22-2007, 05:41 PM   #1
Vehicle: 2003 Chrysler PT Crusier GT
My Photos: (0)
Question long usb
hey everyone,
done some searching and reading but still have questions. has anyone run a passive 20-22 foot usb cable to a powered hub? and if so did you run into any problems? this is what i need to do and since i plan to have my main media drive connected to it i have to find the best solution to this. now the hub will have its own power running from a molex on the computer. just wondering if it would be better to do 2 shorter cables with another powered hub in between or use one of those active usb extensions?
thanks for any help
mike
2003 Steel Blue PT Cruiser GT Autostick, Mopar BOV, K&N FIPK, Dual Exhaust, Boost Gauge.
ICE: 2 12" Infinity 1230W, JBL BP1200.1, Infinity 6000CS, JBL P80.4, Sirius Starmate.
http://www.cardomain.com/ride/2314583
Mike12086 is offline   Reply With Quote
Sponsored Links
Old 05-22-2007, 05:54 PM   #2
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
16' is generally the longest unpowered recomended. All you can do is try it in the house first....but I'm going to guess it's going to be hit or miss if it does work.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 05-22-2007, 06:25 PM   #3
nobb's CarPC Specs
My Photos: (14)
If it doesnt work at home, chances are it wont work in the car. However, even if it does work at home, it might not work in the car since the car is a noisy place. I am running a DIY 7 meter long usb extension. By DIY, I mean I bought a bulk piece of cat5e (accidentally bought the non twisted kind) and soldered all the usb connectors myself. It worked fine for me, but results will vary.
nobb is offline   Reply With Quote
Old 05-22-2007, 06:35 PM   #4
My Photos: (0)
so do you think my better solution would be the active repeater cable or the short passive cable into active hub to passive cable into final active hub?
Old 05-22-2007, 07:10 PM   #5
nobb's CarPC Specs
My Photos: (14)
Is cost an issue? An active repeater cable will probably yield best results. My theory on adding a hub to the end(dont know if its true, but makes logical sense to me): Adding a hub to the end might actually make it worse, as there may be more information being transfered (more devices can be connected). All this information presents a greater opportunity for interference and may degrade the quality of the individual signals.
In summary, adding a hub to the end will either not change how much data loss you get, or increase data loss. If you are already losing data from a long usb cable, a hub wont make it better because the data is already lost once it reaches the hub. The only benefit I see to adding a hub at the end is that you can add more devices close to the driver, as well as boosting the usb voltage. But dont think data loss is a bad thing. Data is lost all the time (usb, internet)...but your hardware and software error correction will take care of that. Lost information will just be sent again.
Before you spend all your money into getting a repeater or a hub...maybe you should first try running the passive cable first. At ~6 meters (22 foot), you probably will be getting more data loss (especially if its unsheilded) vs running a normal usb cable. But other than slowing down the rate of data transfer, you probably wont notice anything due to error correction.
Old 05-22-2007, 08:30 PM   #6
My Photos: (0)
well this is what i need/have...there is about 20-22 ft between the compuer and up front where the hub will be. the hub will be a powered one that is connected to a 200 gb hard drive with all my media on it, the touchscreen, a bluetooth adaptor, game controllers, and gps eventually. so i figure either just one long cable or a extender/repeater would work...the only reason i'm worried about loss is because of the media drive.
Sponsored Links
vB code is On
Trackbacks are Off
Mini-ITX boards RedGTiVR6 General Hardware Discussion 88 01-10-2008 08:47 PM
Should i run a long usb cable for audio? Tim Lake Car Audio 7 05-15-2007 09:52 AM
Long RCA vs Long USB SKiTLz General Hardware Discussion 3 02-18-2007 03:57 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 02:52 PM
" HI-SPEED USB device is plugged into a non-HI-SPEED USB hub" Error - HELP!!! hd54321 General Hardware Discussion 15 05-04-2006 04:53 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
