Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-22-2007, 08:57 AM   #1
Timer Settings Lilliput TC1000 Computer
Hi all! My first post! Woot!
I've been running this carputer for several months now and the only problem that I have is that the power controller on it hard shuts down the computer after about 12 seconds, but hibernate takes about 15 seconds.
Is there a way to change the timer setting to take a bit longer for the power shutdown?
There doesn't seem to be anything in the BIOS, so I'm hoping it's not hard wired. Can anyone think of any other solutions, like shunting power to the ACC lead from a capacitor or something?
Any suggestions are appreciated.
Oh, as a side note, does anyone know exactly the memory type that I can buy to upgrade to 1GB?
Thanks again!
huhsler is offline   Reply With Quote
Old 06-24-2007, 09:08 AM   #2
TC1000 ram upgrade
Hi
You can use PC2700 1GB RAM ( 200 pin laptop ddr ram).
regards Primo
feniks is offline   Reply With Quote
Old 06-26-2007, 12:09 PM   #3
Actually, I just took my TC1000 apart and it was running a PC3200 DDR400 SODIMM (what a pain to remove, too!).
Still looking to change setting or speed up Hibernate. Thanks.
Old 07-21-2007, 08:02 PM   #4
bump. Any ideas anyone?
Old 02-27-2008, 07:08 PM   #5
bump bump! Just got back from Iraq and still have no answer to this. Thanks!
Old 03-21-2008, 10:54 PM   #6
gfmedia's Avatar
would also like to know, I still haven't found an answer...welcome home
gfmedia is offline   Reply With Quote
Old 03-25-2008, 11:18 AM   #7
HiJackZX1's Avatar
First off what type of Mobo and number 2, what power supply do you have? If its a M2-ATX there is a jumper on the PSU itself that you can set to how long it takes to hibernate or shut off the PC.... my OPUS 320 also has the feature. I am not sure on other PSUs'. If I am reading correct your PC is made by Lilliput, it may have a cr@ppy PSU to begin with. Maybe you should upgrade the PSU.
PS: from what i have read, it has a 20 second delay feature......
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is online now   Reply With Quote
Old 05-12-2008, 10:18 AM   #8
Does anyone knw where i could buy a Lilliput TC1000 case only?
mohamedali21 is offline   Reply With Quote
Lilliput TC1000 + GL702-TV/C/T combo secured-nor1 General Hardware Discussion 6 06-22-2006 11:46 PM
Lilliput to Opus & time settings nibix Power Supplies 1 06-29-2004 10:44 PM
How do you save Lilliput video settings? ML430 Input Devices 0 06-09-2004 11:37 PM
Lilliput forgetting settings? Magma LCD/Display 1 04-21-2004 09:52 AM
Lilliput vga settings junior LCD/Display 3 10-27-2003 04:25 PM
