Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 09-03-2002, 05:57 AM   #1
cproaudio's Avatar
cproaudio is on a distinguished road
Ultimate Car PC motherboard, P4 power, Firewire, USB2.0
http://www.tcommate.com.tw/EN/INFORM...78/P4BGA_E.htm
Here are the specs, only 2 inches longer than FV24 but doesnt have video out.
1. CPU
Supports Intel Pentium 4 1.3GHz ~ 2.4+GHz CPU with 400/533 Mhz FSB frequency
Supports 478 FCPGA2 pin-package P4
2. Chipset
Intel 82845G & ICH4
3. Main Memory:
2x184 pin DDR SDRAM DIMMs to support up to 2.0GB DDR SDRAM
3. Slots:
1 AGP (4X), 1 PCI slots, 1Riser Card (Option)
4. IDE:
Support two IDE channels & up to four IDE drivers
Support gUltra DMA 33/66/100h transfers up to 33/66/100MB/s
5. VGA:
Built in Intel SVGA Controller with 3D engine
6. Audio:
ACf97 Realtek 201A audio CODEC on board
7. LAN:
Support 10/100Mb full duplex LAN
Intel Pro/100 Fast Ethernet on board
8. USB
Support 4 USB ports (Rev.2.0)
9. IEEE 1394 Interface
VIA IEEE 1394 Controller with internal 1394 connector
10. I/O:
1 Floppy connector
1 Printer port
2 Serial ports
1 SIR connector
1 PS2 Keyboard connector (mini Din)
1 PS2 Mouse Connector (Mini Din)
1 game/midi port
1 line in
1 speaker out
1 microphone in
11. Power management:
ACPI & APM
Ring Remote wake up
RTC alarm
Software shutdown
Auto fan on & off
Power button
Wake on LAN ready
12. Award flash BIOS
Support ACPI function
Support NCR SCSI BIOS
Support Green & Soft-off function
Support LS120 Boot Up
Support Multiple Boot Up
13. Form factor:
Mini Flex-ATX form factor
17.0x 24.5 cm2
Ordering Option:
P4BGA: Mini-FlexATX mPGA478 Pentium 4 DDR
Motherboard with VGA, LAN, Audio,
IEEE 1394 and USB 2.0 Interfaces
(1 x AGP and 1 x PCI Expansive Riser Card
in Packing)
P4BGAP: Same as P4BGA but with 400 MHz FSB and
without AGP Interface
(2 x PCI Expansive Riser Card in Packing)
cproaudio is offline   Reply With Quote
Old 10-01-2002, 01:35 AM   #2
can_crusher
Do you have a source for these?
Ivan
can_crusher is offline   Reply With Quote
Old 10-01-2002, 02:23 AM   #3
MP3DUB's Avatar
MP3DUB is on a distinguished road
Ah, but its missing the one critical component if you want to use a composite lcd. There are a lot of similar boards out there, all having the same "flaw."
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
MP3DUB is offline   Reply With Quote
Old 10-01-2002, 02:18 PM   #4
cproaudio's Avatar
can_crusher
What do you mean by source?
MP3DUB
Can you kindly show me the links to a lot of other simular "boards" not barebones besides the shuttle ones?
The shuttle FV50 has only PCI slots and no USB2.0 but it does have S-Video out and 6ch audio out. I still havent seen a small LCD with S-Video in. I've heard a lot of people have problems with S-Video to composit video adaptor like it only show black and white or the color doesnt look right. Also doesnt the 845G have better 3d graphics than the SIS 650 and 651 video chips?
This board came out before the SS51 barebone was available.
The only other board that has all the features is the SS51, but its only available as barebone.
believe me, I would rather have the motherboard in the SS51 but its not available only as the motherboard
As for video out, you can buy a small scan converter for less than $50 that lets you adjust the size and position of the screen, unlike the built in video outs on the FV24, FV25, FV50 and the SS51. I know for a fact that people complaint about the black borders around the edge of the TV screen cuz I have the FV24 and no matter what I do, I cant get rid of the thick black border on the edge of the TV.
Old 10-01-2002, 10:10 PM   #5
can_crusher
Do you know where you can buy one of these and for how much?
Ivan
Old 10-02-2002, 12:12 PM   #6
MP3DUB's Avatar
Off hand, I can't give any examples, but when I was searching for a new matx socket a board the other month, I kept coming up with all sorts of p4 boards that fit my requirements, but had a hard time finding a socket a board with everything that I needed. But if you search around, you're bound to run into them.
-Nick
Old 10-02-2002, 12:21 PM   #7
m3rdpwr
Sapphire just released newer versions on the ATi IGP with ATi's south bridge. USB 2.0, 6 channel audio, blah, blah, blah...
http://www.sapphiretech.com/PRODUCT/PRODUCT-board.HTM
A3-M293 AMD
A4-M280 Intel
Search newegg.com for "sapphire a3" for the older version with USB v1, AC97 audio and vga/composite out for $72.
I'm going to see if the new distributor can get those to my old boss.
-Mario
m3rdpwr is offline   Reply With Quote
Old 10-02-2002, 12:22 PM   #8
Registered User
GuRuGoD's Avatar
GuRuGoD
i dont know about you guys, but i will probably wait for the EPIA-M from VIA. here's the spec sheet. I know its a 933 and not a P4, but hey its smaller and i will bet it takes a LOT less power. P4's are power hungry.
90% Done
60W DC-DC & shutdown controller
Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
All in a shiny White 2000 V6 Mustang
Click here to visit my NEW PhotoAlbum
GuRuGoD is offline   Reply With Quote
Old 10-02-2002, 12:26 PM   #9
m3rdpwr
I wonder how long it will take Shuttle to utilize the new mini-itx platform with the Appolo CLE266 with a ziff socket so I can stick my PIII Tulatin 1.26GHz 512K Cache CPU in...
-Mario
Old 10-02-2002, 12:40 PM   #10
cproaudio's Avatar
P-III 933Mhz too slow?
I dont know about you guys, but to me, my P3 933Mhz on the FV24 seems really slow compare to my P3 1Ghz home computer that I used to have. I think it's a chipset problem. The 1Ghz was a 440BX chipset. It's almost as fast as my P4 2Ghz running app. There is always hourglass when I switch apps like from Winamp to GPS or from GPS to OBD-II info on my car PC.
Old 10-02-2002, 12:42 PM   #11
cproaudio's Avatar
Quote:
Ivan
Sorry I dont know. You can email them
http://www.tcommate.com.tw/EN/index_en.htm
Old 10-02-2002, 03:21 PM   #12
MP3DUB's Avatar
Re: P-III 933Mhz too slow?
Quote:
The C3 is slower than a Celeron3 of similar speeds, which is inturn slower than a Pentium3 (which is inturn, as fast as a duron, which is inturn slower than an athlon ). And the 440BX was the most versatile (best) chipset EVAR (the i810,i815, and i820 were all abominations).
-Nick
Old 10-02-2002, 05:42 PM   #13
Charliey
The 440BX had the best memory speed, except for new DDR, and RDRAM.
When the chipsets came out after it, the KT133, and the i810/i820, they couldnt compete with the 440bx for memory bandwidth. With DDR though modern memory speeds have passed it.
Project AutoBoxen: Coming along, almost ready to hook up in the car.
Celeron 500, 192mb ram, 8gb hdd, other stuff.
'91 Mazda 626: Its free, so ill use it.
Charliey is offline   Reply With Quote
Old 10-02-2002, 06:40 PM   #14
m3rdpwr
You have to look at the whole PIII architecture.
It was once said that the PIII couldn't really take advantage of RDRAM or DDR...
-Mario
Old 10-03-2002, 04:12 AM   #15
cproaudio's Avatar
A3-M293 AMD
A4-M280 Intel
-Mario
The board im referring to is a mini Flex-ATX. It's smaller than the Flex-ATX that Asus offers. The Sapphiretech mobo are MicroATX which is larger than the standard FleX-ATX. There are tons of MicroATX that has verything built in. I am referring to mini Flex ATX boards. Thats why I was comparing the shuttle boards.
