Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-09-2007, 12:48 AM   #151
hennessey524 is an unknown quantity at this point
any word on whether the digitalfx skin is supported or not??? someone had mentioned that it was NOT supported earlier...
now, one more question...would it be possible to add a pci video card as the one in the llink below???
im a noob...and am admittedly confused. any help is greatly appreciated...
thanks!!!
http://www.geeks.com/details.asp?invtid=HM300L3-C3H
hennessey524 is offline   Reply With Quote
Old 11-09-2007, 01:50 AM   #152
anyone know if the digitalFX skin will work on this board? earlier in this thread, i believe someone had mentioned that it was NOT supported...but this person was not sure whether it was a mobo related issue, or something to do on the software side (ie. drivers, directX-3d stuff...etc..)
anyone tried this skin out using the d201gly??? any help would be appreciated.
thanks!
Old 11-09-2007, 09:33 AM   #153
Tensai's Avatar
Tensai is an unknown quantity at this point
I won't have time today, but I can load DFX2 tomorrow and let you know how it works.
I really don't see why it wouldn't work. Its handled everything else I've thrown at it with no problems at all. I'm guessing it probably couldn't do Crysis though...
Is it that it's fun? Or that it lets you forget yourself?
Tensai is offline   Reply With Quote
Old 11-09-2007, 10:33 AM   #154
TimmyM's Avatar
TimmyM is on a distinguished road
I've been running RR and DFX 2.5 for months with no problems.
I'm courious, how could a skin not run because of the motherboard? Is that even possible?
TimmyM is offline   Reply With Quote
Old 11-09-2007, 10:56 AM   #155
Tensai's Avatar
He was worried about DirectX and/or Flash support. The SiS graphics chipset on this board only supports DirectX 7. And some other people were concerned that the limited graphics capabilities might hinder flash animations etc.
But... just cause the chipset is DX7 doesn't mean it can't run DX9, it just won't support all of the latest versions of the shaders etc. And this board really handles flash without any problems.
So there's your answer Hennessey, it will run DFX just fine.
Old 11-09-2007, 11:22 AM   #156
vladcarpc's Avatar
vladcarpc is an unknown quantity at this point
I've been using RR and DigitalFX with this board, with WinAmp Visualizations and Destinator 6. Everything works excellent!
\/ |_ /\ [)
1995 Civic Sedan EX
CarPC status: [||||||||||||] 100% - Phase 1 Complete!
YouTube video - WorkLog
vladcarpc is offline   Reply With Quote
Old 11-09-2007, 12:32 PM   #157
sweeeeeeet! thanks guys.
Old 11-09-2007, 06:45 PM   #158
just ordered a d201gly2 earlier this afternoon. they are out there and relatively cheap. i wish they show up on the mp3car store as part of the integrated packages sometime soon...i feel bad broadcasting the name of the place that carries it...but i guess since the store doesn't even have them up yet...PM me, if interested in finding out where they can be found...
Old 11-21-2007, 05:46 AM   #159
Caso85 is an unknown quantity at this point
the INTEL d201gly2 support 800x480/600 resolutin?
Caso85 is offline   Reply With Quote
Old 11-21-2007, 11:15 AM   #160
-zip-'s Avatar
-zip- is on a distinguished road
Yes it does, question is, does your monitor TRUELY support 800x480. I have this board, supports it no problem, my lilliput is supposed to be native 800x480 but the screen is to wide and is a known problem. The SIS utility could be more robust to support H&W adjustment however.
I run at 800x600 just fine.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 11-21-2007, 12:26 PM   #161
vladcarpc's Avatar
The same issue here, Lilliput does not display 800x480 correctly, so I end up using 800x600...
\/ |_ /\ [)
1995 Civic Sedan EX
Old 11-22-2007, 11:28 AM   #162
GasPath is an unknown quantity at this point
Question: I have a 2gig stick of PC2 6400 running at 800Mhz (manually set in the bios). It is probably overkill, but all I had in my spare parts box at the time. I assume that in Hibernate, XP writes the memory to the HD and then reloads that image back to the memory when it comes out of hibernation. Do you think I would see a quicker reboot if I used 512mb instead of 2gb? Mine seems slower than some of the times posted here by others. I'm curious if 256mb would run. Just need the minimum for this project. Anyone tried something as low as 256?
Additionally, since the recent conversation regards the resolution, I run a VM70 and mine won't do 800X480 either. I can't expand the phase enough to fill the screen. 800X600 runs fine, but of course, all the vids and pics are elongated.
GasPath is offline   Reply With Quote
Old 11-22-2007, 01:28 PM   #163
Tensai's Avatar
Yes, less RAM will probably translate into quicker hibernate/resume times. However, with the 2GB stick you have a few options. Check out this article http://support.microsoft.com/kb/108393. You can set the maximum memory that XP can use to 512MB-1GB which will speed up the hibernate cycle. Then you could find a RAMDrive utility to use the remaining 1GB as a RAM based drive. Any files that are copied to the RAMDrive after bootup will take virtually no time to load the next time you access them.
Or... you could just downgrade the physical RAM in your system.
Old 11-22-2007, 01:59 PM   #164
vladcarpc's Avatar
When the machine is waking from hibernation it will read from disk and write back to memory, right? Let's say your PC has 2GB of RAM but is only using 300MB of it.
Will the hibernation file contain 300MB of data or 2000MB?
\/ |_ /\ [)
1995 Civic Sedan EX
Old 11-25-2007, 08:57 AM   #165
Tensai's Avatar
If you've specified in boot.ini that it is only allowed to use 300MB and that is why that's all it using, then the hibernation file will only be 300MB.
If you haven't specified anything and it is only by chance that its using only 300MB, then the hibernation file will be 2GB. That's why using more ram takes more time. It will take a lot longer to write the 2GB file to disk and read it back.
where can i get a mini ITX for cheap D_roc Newbie 2 09-24-2007 06:55 PM
Mac mini (Intel) and CNX-P2140 atl MacCar 9 08-19-2007 01:26 PM
Intel Itx board into C134 Craggy General Hardware Discussion 0 10-09-2006 07:06 PM
Mini ITX MB? HELP fondoo General Hardware Discussion 6 05-06-2004 09:46 PM
mini itx and xp oddcomp General Hardware Discussion 7 09-16-2002 04:20 PM
