Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-01-2007, 09:14 AM   #61
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
fyi- This board does NOT work with High-Density Ram modules.. which means i wasted 24 bucks on the ram from ebay i purchased.. but circuit city has a compatible 1GB module for 44 bucks! i dont feel so bad now !
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 10-01-2007, 08:02 PM   #62
vladcarpc's Avatar
vladcarpc is an unknown quantity at this point
This motherboard came with an IDE cable like this:
http://www.pcguide.com/ref/hdd/if/id...Cable80-c.html
(it has blue, gray black and connectors)
Can I use the old IDE cable I have???
The 2.5 HDD Adapter won't fit in this new IDE Cable (the connector of the new cable has 1 pin less, in the middle, that is blocking)
\/ |_ /\ [)
1995 Civic Sedan EX
CarPC status: [||||||||||||] 100% - Phase 1 Complete!
YouTube video - WorkLog
vladcarpc is offline   Reply With Quote
Old 10-01-2007, 08:06 PM   #63
TimmyM's Avatar
TimmyM is on a distinguished road
just look around you can find a cable that doesn't have that pin blocked or break the pin off the adapter, i've done that also.
I just got back from the store and bought a 18" round to replace the flat one I had so I know they are available.
TimmyM is offline   Reply With Quote
Old 10-01-2007, 09:32 PM   #64
Tensai's Avatar
Tensai is an unknown quantity at this point
If you're not up to breaking the pin off. Simply bending it out of the way will work equally well. I've done that before. But the nice round cables don't cost much.
Here is a round one (12") from TigerDirect for $4 + $7.50 shipping
http://www.tigerdirect.com/applicati...?EdpNo=1910188
Tensai is offline   Reply With Quote
Old 10-01-2007, 10:03 PM   #65
vladcarpc's Avatar
OK, I will see if I have one or buy that cable.
But is there a problem using the old IDE cable?
I am asking because I just did it and the Motherboard is not booting anymore. It was fine before.
Green light in the motherboard is lit, CPU fan is on, but monitor doesn't show anything... It doesn't have a speaker so no beeps.
I powered all off, removed the IDE cable, start but no luck...
Anything I should try now? I just removed all the cables, and took the bios battery out...
Please help...
\/ |_ /\ [)
1995 Civic Sedan EX
Old 10-02-2007, 07:58 AM   #66
vladcarpc's Avatar
Hello,
Left all unplugged during the night. This morning I connected power, kbd, memory and monitor.
Turn the board on, green light is on, Keyboard num caps scroll locks blink once, CPU fan is on, but no video....
Do you know if this board have a Speaker connection? Maybe its beeping something.
Help
\/ |_ /\ [)
1995 Civic Sedan EX
Old 10-02-2007, 09:10 AM   #67
Terminal flasher
check the position of your bios reset jumper. if its on pins 1-2 power down, move it to 2-3 and reboot. You'll get into the maintenence section of the bios. Check the error log for any available info.. then save the default bios setting. Power down, and move the pin back to 1-2. It should work then. This board is a little pushy when it comes to having every scenario correct to make it boot. I went thru a week of tryin to figure out various things that seemed to be wrong with it.
03 Acura RSX Coupe
Old 10-02-2007, 11:55 AM   #68
vladcarpc's Avatar
Hi, i tried with jumper in 2-3 position, turn on but still no video. Light on, CPU Fan on, ... I also tried without the jumper.
Extra testing:
I plugged my USB GPS and it turned on (so there are power in the usb port), I plugged a network cable and its lights blinked, so I dont understand what is going on...
I was thinking if that is a problem with my LCD monitor (boot resolution, maybe), so I changed to a 17" CRT monitor, but no luck.
I connected a led in the Power On led. It is lit when the board is on. I removed the DIMM, turn on and the power led is not continuously on, it blinks, probably the error code.
Sad.
\/ |_ /\ [)
1995 Civic Sedan EX
Old 10-02-2007, 01:09 PM   #69
Tensai's Avatar
That LED blinking should definitely be the error code. Look it up in the documentation. I don't remember if that document actually came with the board or not so you might have to download it from this page at intel.
I doubt that it was the IDE cable that caused it. Older cables should work just fine (although they might not get you the full ATA133 throughput). If there was a problem with the IDE then you should still see the logo/post screens and might even get a "Non System Disk" error.
I was getting similar symptoms from my VIA800 before I bought this board. All lights on, fans spinning, nothing else. I tried resetting the BIOS as per the instructions in the manual with no results at all. Eventually I took the BIOS battery out, and left the board unplugged for about 4-5 days. I tried it again the next week, just for kicks, didn't expect it to do anything. And it booted up as if nothing was ever wrong.
That may not be very helpful to you, but take it for what its worth.
Old 10-02-2007, 04:39 PM   #70
vladcarpc's Avatar
It is back alive!!! I changed the DIMM and it worked!!!
Maybe I screwed the previous DIMM with some static or whatever.
I'm happy again.
Well, let's continue the tests.
\/ |_ /\ [)
1995 Civic Sedan EX
Old 10-02-2007, 06:00 PM   #71
skybarge is an unknown quantity at this point
haha nice good on you glad to see it runs again
I used DDR2667 Corsair Ram 1GB managed to get it cheap too $47NZ(35USD)
Yeah all IDE cables are fine, I'm using one from my old motherboard, might even goto a single IDE cable and run a USB external CD-rom, just due to the way I'm mounting mine
I've had a quick search for the SIS S-video chip, I'm not sure if mine is on there, if it is, I'll be willing to solder a 7 pin S-video cable onto it, just to see if it shows up
Because it'd be nice to have an S-video to component cable then run a 14" flipdown component monitor in the back for passengers, while I keep my 7" touchscreen to myself up front
skybarge is offline   Reply With Quote
Old 10-03-2007, 09:39 AM   #72
b10hazard is on a distinguished road
I have this board, used it to build a NES PC.
Good luck with the s-video, your going to need it!!! I followed the traces on the board, and there are a lot of nessicary resistors and/or capasitors that arn't there.
oh, and go easy on the smilies!
b10hazard is offline   Reply With Quote
Old 10-03-2007, 02:53 PM   #73
vladcarpc's Avatar
Use HD via USB?
Hi,
I see that this board supports booting via USB.
I was wondering about using the HDD via USB, instead of using the IDE cable, just because its easier to remove (for instance, when need to take it out of the car to manage the files, add more music, etc..).
I dont know what is the performance of a HDD running on USB 2.0 x IDE.
\/ |_ /\ [)
1995 Civic Sedan EX
Old 10-03-2007, 02:57 PM   #74
Terminal flasher
the drive will definitely run slower (and the more GB the slower still).. but yes it worked.. i booted linux off my flash drive and it took a good 7 mins to load to desktop.
03 Acura RSX Coupe
Old 10-03-2007, 04:58 PM   #75
upspace is on a distinguished road
Quote: Originally Posted by upspace View Post
any ideas how to speed up bios "boot" time that is the time elapsed from power on to load windows / os?
i measured around 30-40 secs showing the intel splash screen before loading the os. i tried all settings in bios config program (deactivate unused floppy, hdd first boot order etc.) no impact!
is that normal to have such a choppy bios boot-strap?
upspace is offline   Reply With Quote
where can i get a mini ITX for cheap D_roc Newbie 2 09-24-2007 06:55 PM
Mac mini (Intel) and CNX-P2140 atl MacCar 9 08-19-2007 01:26 PM
Intel Itx board into C134 Craggy General Hardware Discussion 0 10-09-2006 07:06 PM
Mini ITX MB? HELP fondoo General Hardware Discussion 6 05-06-2004 09:46 PM
mini itx and xp oddcomp General Hardware Discussion 7 09-16-2002 04:20 PM
