10-03-2007, 05:08 PM
#76
Quote: Originally Posted by upspace
i measured around 30-40 secs showing the intel splash screen before loading the os. i tried all settings in bios config program (deactivate unused floppy, hdd first boot order etc.) no impact!
is that normal to have such a choppy bios boot-strap?
So far the intel logo screen is being displayed for around 4 seconds only... THe boot time seems normal.
I have only the 2.5" HDD and PS2 keyboard PS2 mouse attached. Default bios settings.
I am installing XP now.
\/ |_ /\ [)
1995 Civic Sedan EX
CarPC status: [ ||||||||||||] 100% - Phase 1 Complete!
YouTube video - WorkLog
10-03-2007, 06:05 PM
#77
800x480 confirmed
Hi,
I also tested 800x480, it works by default.
See screenshot below (taken with 800x480 resolution already set):
So far this board is excellent.
\/ |_ /\ [)
1995 Civic Sedan EX
10-03-2007, 06:19 PM
#78
Mine boots into XP and loads RR in about 45 sec. I have modified the BIOS slightly (only a couple of changes, but I can't remember what they were now), but I haven't done any flash updates or anything. I'm not sure why your system is taking so long.
EDIT: I timed everything last night. It sits at the Intel BIOS logo thing for almost 17 seconds. But the computer is still booted and ready to go in 40 sec from a cold start and 23 sec from hibernate. Good enough for me. I flashed the BIOS but still had no option to disable the boot logo.
10-04-2007, 01:30 AM
#79
Newer video drivers v3.82
Newer video drivers v3.82 2007-08-08 (Intel posts v3.80)
If you goto www.sis.com and click the download link
Place a check next to "I accept to the above" (After reading the agreement)
Click Agree
Highlight Windows XP
Highlight IGP Graphics Drivers
Highlight SiS66x/SiS76x & SiS671.SiS771
Click Go
File name:uvga3_382.zip
Select your location
Click Download
I noticed an improvement with Flash skins and .avi playback. I also tested that 800*480 still works.
06 Galaxy Gray Si #0308
CarPc Progress -
10%---------50%---------100%
-[XXXXXXXXXXXXXXXXXXXXXX]-
10-04-2007, 09:42 AM
#80
Terminal flasher
i have a 40 sec boot time to.. the boot seems to take less time now that i changed the bios splashscreen. Resume from hibernation takes maybe 15 seconds.. it actually takes rr longer to resume all my devices so i'd say 30 seconds total. WAY better than my last computer that would take 2 mins to boot and like 3 mins to resume!
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
10-04-2007, 10:00 AM
#81
Additional USB ports
The board come with 2 USB ports, and it supports 6, right?
So I need to buy USB connectors for the motherboard, is this easy to find (eg in Fry's)?
\/ |_ /\ [)
1995 Civic Sedan EX
10-04-2007, 10:33 AM
#82
Terminal flasher
yes it supports 6 with 2 sets of internal header pins. I found the usb headers at a local mom and pops for 6 bucks so they shouldnt be hard to find.
03 Acura RSX Coupe
10-04-2007, 10:34 AM
#83
They (the headers) should be easy to find almost anywhere, ebay, tigerdirect, frys. They usually don't cost more than a few dollars. Make sure they support two USB ports though. Sometimes they only come with one USB port, and that'd be a waste.
@Sonicxtacy2: What version of the BIOS are you using that you can disable the BIOS boot screen? I downloaded version 0103 from Intel last night and noticed no changes in BIOS options at all. Where do you find the option to disable the logo in the BIOS?
10-08-2007, 02:29 AM
#84
has anyone tried a PCI video card in this yet? Im thinking of going that route so I could use two headrest monitors. I've heard problems with XP booting with certain PCI video cards. I might go with the more expensive route of a pc-to-tv adaptor, that'll save the PCI slot for something else. Weighing my options.
10-08-2007, 09:02 AM
#85
Terminal flasher
you cant disable the image but u can change it to whatever you want.. so if you just wanted a black screen until windows loads u'd just add a black .bmp. This isnt an option from within the bios.. what you have to do is download the iflash version of the latest bios and download this bios image creator
http://www.intel.com/design/motherbd...k/download.htm
follow the instructions to change the bios splashscreen. then create the bios image and load it just like you loaded the 0103.
03 Acura RSX Coupe
10-08-2007, 09:09 AM
#86
Even with that, the post is way too long, or at least it is on my system.
10-08-2007, 02:15 PM
#87
the same here as posted previously. its a fantastic board for a car pc but having the bios post screen staying for 30-40 secs alone it takes ages to boot or de-hibernate (de-hibernate only takes 10 secs for 1 gb ram for me).
what is the trick with the bios to make post faster? bios upgrade (doubt), hardware issue (1gb ram check - how to disable, set to fast mode), 21/2 inch harddisk...
or is it the usb hub with 9 usb devices attached (gps mouse, wifi, dvb-t, touchscreen, usb keyboard, etc.) that tries to boot/recognize proprietary usb devices.
10-08-2007, 02:18 PM
#88
I am in the same boat you are in.
1Gb of RAM
USB hub with multiple items plugged in (wireless KB, GPS, camera, WiFi)
I have tried the "change post image to blank" suggestion but saw no improvement.
I, along with many others, would love to try any suggestions.
10-08-2007, 04:37 PM
#89
Terminal flasher
enter your bios and turn off any unneeded onboard devices ie serial ports, audio(if using external). Other than that i really dont know what to tell you to do. My bios image is here and gone within 2 seconds.. pretty much making it pointless for me to change the intel image to a honda logo lol. It COULD be the memory because this point seems pretty picky on the memory type you use. It definitely doesnt use high-density chips and for some reason got slower with another type of non-brand memory. I'm using a kingston RAM (44 bucks from Circuit City) and everything is lightning fast.
03 Acura RSX Coupe
10-08-2007, 05:03 PM
#90
I think that I have already disabled everything that I can but I will double check. For RAM I am using "MEM 1G|CORSAIR DII667 VS1GB667D2 R" from Newegg. What size RAM are you using?
| Thread Tools |
| Display Modes |
Linear Mode
