Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-08-2007, 06:09 PM   #91
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Quote: Originally Posted by drawboy View Post
I think that I have already disabled everything that I can but I will double check. For RAM I am using "MEM 1G|CORSAIR DII667 VS1GB667D2 R" from Newegg. What size RAM are you using?
1GB
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 10-08-2007, 09:39 PM   #92
Tensai's Avatar
Tensai is an unknown quantity at this point
I have crucial ddr2 667 1gb (http://www.buy.com/retail/product.asp?sku=201676508) If you follow that link, you can buy it from buy.com for $20 after a rebate, or $10 if you use google checkout. (That's 1GB for $10 + free shipping!!!) My post screen stays up for about 15 seconds, but I still get decent boot times.
Are you doing a memory check during boot up? You won't be able to see it because of that ******* boot screen. But a 1GB memory check might be able to waste 30 seconds of boot time .
Is it that it's fun? Or that it lets you forget yourself?
Tensai is offline   Reply With Quote
Old 10-08-2007, 09:45 PM   #93
wmpwi's Avatar
wmpwi is an unknown quantity at this point
I haven't selected a case for mine. What's everyone else using on this MB?
A computer lets you make more mistakes faster than any invention in human history
- with the possible exceptions of handguns and tequila.
wmpwi is offline   Reply With Quote
Old 10-09-2007, 09:17 AM   #94
Terminal flasher
only the best small case ever... pricey but perfect for my install. I got a 4 port slim internal hub and cut out a section of the vented side to add more usb's
http://store.mp3car.com/Morex_3677_M..._p/enc-022.htm
03 Acura RSX Coupe
Old 10-09-2007, 09:59 AM   #95
wmpwi's Avatar
That is nice. Looks like lots of room too. Is the PS that comes with it enough to handle everything, buy which I mean, all your stuff because it looks like your extremely close to the build I'm working on. I was afrade I was going to have to go with something more expensive.
Thanks.
Old 10-14-2007, 07:20 PM   #96
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
What options are available for replacing the heatsinks on this board?
The photos show a retainer type I have not seen before...
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 10-15-2007, 09:26 AM   #97
Terminal flasher
for those who have slow bios screens
might help.. might not.. but i had my usb thumb drive installed during boot over the weekend and the bios screen took FOREVER to pass. If you have any secondary or usb bootable devices make SURE that they are disabled in the bios for boot and make sure "boot from usb devices" is off as well. I'm willing to bet those with dvd drives and other usb stuff are having hangups from this.
03 Acura RSX Coupe
Old 10-15-2007, 02:41 PM   #98
wmpwi's Avatar
While I'm still trying to tweak it, mine is booting from zero to RR in less then 60 seconds and I'm running full XP Pro w/ touch screen, 1G mem, 40G HD, USB BU-353, and keyboard. But boot order is a good point since I had to learn it the hard way too. IF you don't disable the boot from USB, then at least move it down the order.
As long as I'm here, is there a difference between stand by and hibernate with this board. If there is, I can't seem to tell.
Old 10-15-2007, 08:47 PM   #99
TimmyM's Avatar
TimmyM is on a distinguished road
I dont think this board supports standby. A shame too.
TimmyM is offline   Reply With Quote
Old 10-15-2007, 10:48 PM   #100
wmpwi's Avatar
That's why I asked the question. I tried both and it seems to put it to sleep, but I'm not sure how to tell which is which. All I know is when I hit suspend or hibernate it shuts down the drive, the processor fan continues to run, and I can go back in a couple of hours and touch the screen and poof - comes back to life. I just have no idea which action it's actually doing.
Old 10-16-2007, 10:53 PM   #101
TimmyM's Avatar
that would be standby. with hibernation it would not have the fan running and touch screen wouldn't make it come back up. How do you have this set up?
Old 10-16-2007, 11:13 PM   #102
wmpwi's Avatar
Right now or at least when I did it I was running Centrafuse. It has a choice of standby and another for Hibernation. I tired both, but past that, I have no idea what routine it's calling up. I tired a both RR and SD and RR behaves like CF, hibernate = standby whereas SD has an option for standby but the option for hibernation is non-selectable. When I select hibernation in CD or RR, I see the windows screen say standby so I surmise that absent hibernation they call for standby. Mystery solved I guess.
Old 10-17-2007, 09:43 AM   #103
MMZonker is an unknown quantity at this point
I'm a noob to this and am looking at this board. Even though it doesn't support S3, if you use a m2-atx in its "recommended mode", it seems like it cuts both the 12 and 5 V power after the jumper selectable time period and then shouldn't drain your battery anyway. However you'll have to cold boot every time. Is that correct?
MMZonker is offline   Reply With Quote
Old 10-17-2007, 11:07 AM   #104
Terminal flasher
or you could just use hibernate and get back to music in 10 seconds with a 1GB stick of ram.
03 Acura RSX Coupe
Old 10-17-2007, 11:09 AM   #105
drawboy's Avatar
drawboy is an unknown quantity at this point
That's what I do now. Initially it would take about a minute to get out of POST but I disabled "USB Legacy" and I am running RR within 15 seconds of power on.
drawboy is offline   Reply With Quote
where can i get a mini ITX for cheap D_roc Newbie 2 09-24-2007 06:55 PM
Mac mini (Intel) and CNX-P2140 atl MacCar 9 08-19-2007 01:26 PM
Intel Itx board into C134 Craggy General Hardware Discussion 0 10-09-2006 07:06 PM
Mini ITX MB? HELP fondoo General Hardware Discussion 6 05-06-2004 09:46 PM
mini itx and xp oddcomp General Hardware Discussion 7 09-16-2002 04:20 PM
