The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 06-27-2007, 02:31 PM   #1
It's not really that small...No, seriously.
judoGTI's Avatar
Vehicle: '02 GTI
My Photos: (0)
Help me figure out what has my COM1 tied up?
I have serial car diagnostic software on my carPC. But about a month ago when I try to connect with it, it tells me the port is in use, and my diag software wont connect.
I havent installed anything else new on my PC.... Just all the sudden my PC has COM1 tied up even after boot.
I have the /NOSERIALMOUSE in the boot.ini so its not thinking is a serial mouse. I cant figure it out... Is there a DOS command of some sort that will tell me what has it tied up???
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Sponsored Links
Old 06-27-2007, 09:15 PM   #2
malkamus's CarPC Specs
Vehicle: 1997 Pontiac Grand Prix GTP
My Photos: (0)
I found this googling "what is using a com port
1) Start|Run|type msinfo32|OK. This opens the System Information window. In the left panel click Component and then Port. You may learn what is connected to COM1. Belarc Advisor or Everest may also tell you
http://www.belarc.com/free_download.html
http://www.majorgeeks.com/download.php?det=4181
2) This article, while quite old. has much info which is still valid
http://www.smartcomputing.com/editor...0205.asp&guid=
malkamus is offline   Reply With Quote
Old 06-27-2007, 09:50 PM   #3
Para Laura
thanatos106's CarPC Specs
thanatos106's Avatar
Vehicle: Xterra SE supercharged
My Photos: (0)
What FE are you using?
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 06-27-2007, 10:29 PM   #4
Vehicle: 2001 Mr Bishi Eve of lution VII
My Photos: (0)
have u enabled the port in ur Bios???
PSI70Y is offline   Reply With Quote
Old 06-28-2007, 01:06 PM   #5
judoGTI's Avatar
Vehicle: '02 GTI
My Photos: (0)
Thanks for the info everyone.
I also found a MS tool called ComDisable )installs from an MSI) that should let me list the ports, disable and enable each one, one at a time.
Thantos Im running Frodoplayer, but this app runs outside the frontend.
'02 GTI
Old 06-29-2007, 10:12 PM   #6
Para Laura
My Photos: (0)
Well this happened to me before and the problem is with the build in backing camera app... just go to settings and disable or change the port to a higher number.
also default for XM is port 3 but check that is no using COM 1 as well.
Thanatos.
Nissan Aux-in MOD
Sponsored Links
vB code is On
Trackbacks are Off
Help me figure out the 2 antenna jacks on my stock radio... hd54321 Car Audio 7 03-04-2008 10:16 PM
Help: System Hibernation Failed because of COM1 (GPS)? srcstc GPS 6 03-27-2006 04:52 PM
cant figure out the keys vicky_obee PowerVoice 3 06-18-2005 09:01 PM
Girder question, trying to figure out how to do things with small remote clean customs Input Devices 7 02-26-2005 06:09 AM
BU303 installation help needed. No Lock. No device detected on Com1 port wonderworm GPS 12 09-23-2004 02:00 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
