Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-31-2001, 02:26 PM   #1
pinkysqueaks
Post Using relays to send input to computer
I have been wondering how it would be possible to monitor some of my car's functions via my pc. The main things I am thinking about are the doors opening and changing gears. I figure there has to be some way to notify my computer that this is happening because opening the door or changing gears causes lights to light up. I am somewhat new to electronics, but I am thinking that I could use a relay to control this. Maybe watching whatever line lights up the light...and using a keyboard controller to send notification to the computer. Would this work?
Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
pinkysqueaks is offline   Reply With Quote
Advertisement Sponsored links
Old 07-31-2001, 02:29 PM   #2
Retired Admin
Aaron Cake's Avatar
Aaron Cake is on a distinguished road
Cool
Search.
Aaron Cake is offline   Reply With Quote
Old 07-31-2001, 02:34 PM   #3
pinkysqueaks
Post
I have.
Old 07-31-2001, 05:30 PM   #4
mpt
Registered User
mpt
Post
I dont understand what you are saying. You want the PC to control something when you open the door or change gear, or just monitoring?
mpt
mpt is offline   Reply With Quote
Old 07-31-2001, 06:49 PM   #5
Registered User
marsjell
Post
If I read your post correct, it's very easy to "read" everything you mentioned using relais. Simply let the items you want to monitor drive the relais, attach 1 dataline from your lpt port to all the relais (contact-in) and connect all the contact-outs from the relais to the data-in pins from your LPT port. Write a 1 to the specific dataline from the LPT port, and read out the data-ins....
It's that simple
If at first you don't succeed.........
destroy all evidence you tried
for info on t6369c LCD or Presslab's powersupply check:
http://www.namms.tk <=updated!!
marsjell is offline   Reply With Quote
Old 08-01-2001, 03:54 PM   #6
Retired Admin
Aaron Cake's Avatar
Cool
If you had searched, you would have found the long reply I wrote a few months ago about using industrial data acquisition boards, the parallel port, and VB. However, take a look at http://www.aaroncake.net/circuits/interfac.htm and then http://www.aaroncake.net/electronics/vblpt.htm . This isn't hard stuff to do, but it's a lot of effort to go through for something essentially pointless...
Old 08-01-2001, 04:01 PM   #7
pinkysqueaks
Post
Thank you for your kindness and encouragement. If you're going to be a moderator, why be so negative? It's not like this board gets a million posts a day.
Old 08-02-2001, 10:06 AM   #8
Retired Admin
Aaron Cake's Avatar
Cool
I was making a joke, I just forgot the .
Old 08-03-2001, 07:16 PM   #9
chippie123
Post
But for him it might be easier because he may be able to set up a circuit that sent a signal to his computer whenever a light went on on his dashboard
chippie123 is offline   Reply With Quote
Old 08-03-2001, 10:15 PM   #10
DarkWolf
Post
Check my post "My hardware/Software computer control system - Wish list/feedback - Easy power off" in this forum. I will be developing a system that in time (with the expended control handling) will be able to handle those possabilities. If you could give me an idea of what you want the computer to do when;
1: doors open
2: gears change (This will be hard to monitor)
3: etc
I'll add it to my list of things to ponder and we'll see what I can come up with after the 8 command handling version is beta tested and proved to work.
97 Firebird Formula Convertable - Project R/T
Project R/T SoundDomain Page
DarkWolf is offline   Reply With Quote
