Some guys on here will disagree with me, but you would be safe with 18AWG as well. If you are only going to draw 5A and only one device, you don't need fatter wires. If you think you might add amps or anything else back there later, go ahead with bigger wire now.
Whatever size wire you use, fuse it up by the battery so that if you ever get a short to ground, you will blow the fuse instead of setting the car on fire.
2005 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
