Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-08-2007, 03:50 AM   #31
nationapn's Avatar
nationapn is an unknown quantity at this point
MSI Industrial GM965 Core 2 Duo Mobile Mini-ITX Mainboard
This should interest quite a few people!
In the past few weeks, a new mini-ITX Socket P motherboard was introduced, which will make it much easier for upgrading with Intel's future processors (and it's cheaper for a socket P processor). I just purchased the Core 2 Duo T7300 from newegg, along with this MB from logicsupply.
Anyway, here are the details:
MS-9803 Specifications
Processor
Core 2 Duo Mobile (Merom)
Socket P (478 pin) 800 MHz FSB
Chipset
Intel GM965 Northbridge
ICH8M Southbridge
System Memory
2 DDR2 533/667 SDRAM sockets
Up to 4GB (recognizable...3.25GB) memory size
VGA
Built-in Intel Graphics with GMA X3100 Technology
Expansion Slots
1 PCI Express (x16)
1 PCI (32-bit)
1 PCI Express Mini Card
Onboard IDE
1 ATA 100 (40-pin)
Onboard Serial ATA
2 SATA II connectors
CompactFlash
CF slot on bottom
Onboard USB
8 USB 2.0
Onboard LAN
1 Intel 82566DC 10/100/1000
1 Intel 82573L 10/100/1000
Onboard Audio
ALC888 7.1/5.1 channel HD audio codec
Back Panel I/O
1 PS2 mouse port
1 PS2 keyboard port
1 VGA port
1 RS-232 COM port
2 LAN ports
4 USB 2.0 ports
6 Audio jacks: line-out, line-in, mic-in, rear surround-out, center-/subwoofer-out, S/PDIF-out (optical)
Onboard I/O Connectors
1 IDE slot
1 LVDS connector
1 DIO connector (16 GPIO)
1 RS-232 COM connector
1 Parallel port connector
1 S/PDIF connector
2 SATA connectors
1 TV-out connector
2 USB 2.0 connectors for 4 USB ports
1 Front panel connector
1 Amplifier connector (4-pin)
2 Fan connectors
ATX power connector
BIOS
Award BIOS 4Mb flash memory
System Monitoring & Management
Watchdog timer, CPU voltage monitoring, CPU temperature monitoring, Fan control, Wake on USB, Wake on LAN, Wake on Ring, System power management
Operating Temperature
0 ~ 55°C
Operating Humidity
0% ~ 85% (relative humidity; non-condensing)
Form Factor
Mini-ITX (17 cm x 17 cm)
nationapn is offline   Reply With Quote
Old 10-08-2007, 03:54 AM   #32
nationapn's Avatar
Here's a picture of it:
Old 10-08-2007, 06:48 AM   #33
mrbean_phillip is on a distinguished road
Nice looking board, with a good feaure-set. Thanx for the heads-up! My LV-677 could certainly have done with a few more onboard USB ports
mrbean_phillip is offline   Reply With Quote
Old 10-08-2007, 09:40 AM   #34
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Added the MSI Fuzzy 965
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 10-09-2007, 12:42 AM   #35
isamu is on a distinguished road
No PCMCIA slot?
isamu is offline   Reply With Quote
Old 10-09-2007, 01:04 AM   #36
nationapn's Avatar
No...That's the only drawback I could see. I guess that just keeps from being able to use a PCMCIA slot for extra USB 2.0 ports (but the board supports 8), a PCMCIA broadband modem, or a sound card.
The positives definitely outweighed the negatives for me, especially being a socket P. Also important to note are that the built-in audio and video are excellent, and there is a PCI-E slot built in, so it's not like expandability is impossible.
Old 10-09-2007, 01:16 AM   #37
Interesting. Will mp3.com be selling CarPCs with this mobo installed and if so, ETA?
I wonder if I could get XenarcDirect to put it in my SC-10...
Old 10-09-2007, 05:59 AM   #38
@ RedGTiVR6: You may want to add the new Commell LS-372 to your list, it is a very nice, and compact 3.5" Socket-P board.
It will be available mid-October, according to one industrial supplier in Australia.
Old 10-09-2007, 09:33 AM   #39
_
I'm going to try and keep this thread for mITX only. We can start another thread for other form factors if we have enough of them.
Jan Bennett
Old 10-25-2007, 09:01 AM   #40
pinocchio is an unknown quantity at this point
RedGTiVR6
On page one the Kino 9452 isn't a 755 socket, I'm pretty sure it's an M looking at the photo.
pinocchio is offline   Reply With Quote
Old 10-30-2007, 11:22 PM   #41
binar is an unknown quantity at this point
Newbie Question
Fellow Members,
If money is no object, which three mini boards (170mm x 170 mm) listed in this thread are the three best in terms of features offered, processing speed, and quality? I just want to focus looking at the 3 best boards in the list. Any opinions will be greatly appreciated. Thanks in advance.
binar is offline   Reply With Quote
Old 11-04-2007, 12:53 AM   #42
Imdbombboarder is an unknown quantity at this point
Are any of these even close to cheap lol, the Jetways are like $200+
Imdbombboarder is offline   Reply With Quote
Old 11-04-2007, 09:11 AM   #43
_
binar - you would be best served to do that research on your own. No one here knows what the best features are for you because they are specific to YOUR needs.
That's no different than asking what the best car is...best car for who and for what? It all depends on how you're going to use it and what you value in features.
Imdbombboarder -
These are small form factor industrial boards. Tooling costs and manufacturing costs are considerably more expensive than full size boards. These boards are also not made in the same quantity as others so these costs aren't as spread out over volumes.
There is the Intel Little Valley board which you can find on the store for right under $70.00: http://store.mp3car.com/Intel_D201GL..._p/mtb-053.htm
Jan Bennett
Old 11-04-2007, 02:42 PM   #44
Hey, yeah I can appreciate that, usually the smaller things are made the harder they are to make, meaning the more expensive they are. I'm just wanting to put on a dual core that I want to buy at a electronics store the day after thanksgiving(Black Friday Sales) so if I was able to buy a mini-itx that supports dual core and ddr2 that is not too spendy that would be amazing! That motherboard would work but I want to put on my own processor haha!
One thing I dont get, and I posted this before and I dont think they allowed me to post it but, their core 2 duo 1.66 ghz processor is selling on their site for $244.99: http://store.mp3car.com/Intel_Core_2..._p/cpu-007.htm
On sites like Newegg and Tiger Direct, they are selling for $75.00: http://www.tigerdirect.com/applicati...?EdpNo=3241565
This a price gouge or am I missing somethin?
Old 11-04-2007, 02:53 PM   #45
_
They includes me fwiw. I work for this company.
Posts made in the store forum are moderated. No one was preventing you from posting anything, it's a feature to cut back on spam.
Also, you really should think about turning on your instant notification of replies as there have been quite a few posts in response to your thread. No point in posting a complaint if you don't follow up on it to see how it turns out. If you don't follow up on it it just seems like you're posting to complain, not to solve anything.
http://www.mp3car.com/vbulletin/mp3c...erpricing.html
Jan Bennett
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 03:24 AM
mac mini core solo enough for bootcamp? replicant MacCar 6 06-27-2006 12:49 AM
Please read naked girls and Looking for good info on commell P4 itx and via boards. 8675309 Newbie 7 07-19-2005 06:24 PM
MINI atx or Itx JDTUNER General Hardware Discussion 1 06-01-2005 11:31 PM
Where to Purchase Jetway ITX boards? SuperMatty Classified Archive 10 05-26-2003 12:21 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
