11-09-2007, 03:49 PM
#46
Does anyone know how to go about getting those newer liantec boards in the US? I have been holding out for it in the store but nothing new seems to be there in terms of C2D. the Liantec 6965N was the board I was looking for I wasn't sure how people were going about getting these non US made board in the US.
Crazy all this time I been looking at these forums and picking up information, just realized this was my first post...oh well....boooyah
12-27-2007, 07:39 AM
#47
Raw Wave
Don't know why I didn't see this one before...
Epox - IP-ADE6050
Specifications
Device class: Mini ITX
Socket type: Socket M
Core Logic: Intel® 945GM & ICH7M chipsets
Processor: Intel® Core2 Duo, Core Duo, Solo, Celeron M
Max FSB: 667MHz/533MHz
Memory: 200pin DDR2 SODIMM x 2 up to 2GB
Form Factor: MiniITX
PCI: 1 X PCI 32bit, 1 X PCIe by 1
USB: 8 x USB 2.0 ports (4 for Opt.)
IDE: 1 x E/IDE Ultra DMA/100,66,33 model, 2 drivers max.
Network: Dual Marvell 88E8053 Gigabit LAN
Sound: AC97 Audio codec
Video: iGMA950 VGA/LVDS/DVI
Dimensions: 6.7
SerialATA: 2 x SerialATA ports supporting data transfers up to 300MB/s
Watch dog: 256 levels software programmable
Serial ports: 4 COM ports
Compact Flash: Type II Socket
Operating Temperature: 0°C to 60°C ( 32°F to 140°F )
Storage Temperature: -20°C to 80°C ( -68°F to 176°F )
Relative Humidity: 10% to 90% ( non condensing )
12-27-2007, 07:51 AM
#48
Raw Wave
And another...
Epox - ADE-6051
System
CPU
Intel®Core®2 Duo Mobile Processor - T7000, T5000 sequences (Merom/Socket M)
Intel® Core® Duo and Solo Processor - T2000, T1000 sequences (Yonah)
Intel® Celeron® M Processor - 400 sequences
FSB
800/533 MHz
BIOS Award BIOS
System Chipset
Intel® GME965 + ICH8M
I/O Chip Winbond 83627DHG I/O controller
System Memory
2 x 240-pin DIM sockets support dualchannel
DDR2 533/667 SDRAM
Max. up to 4 GB memory
Storage
1 x EIDE with UDMA, ATA/33/66/100 support, 3 x series ATA 300
Watchdog Timer
256 Levels software programmable
H/W Status Monitor
monitoring for CPU and system temperature, voltage and fan speed
GPIO
Onboard programmable 8 bits Digital I/O interface
Expansion
1 x PCI 32 bit slot
I/O
Internal 1 X RS232, 4 X USB 2.0
External 2 x USB 2.0, 1 x RS232, 3 x RJ45 ports,1 audio jack, 1x VGA, 1x KB/MS
Display
Chipset Intel® GME965 Integrated GMAX3100 graphics
Display Memory Intel® VMT 4.0 supports up to 256 MB video memory
Resolution
Analog display: up to 2048 x 1536 @ 75Hz (QXGA)LVDS: up to 1920x1200 @ 60Hz
VGA/LCD Interface
DSUB-15 & connectors
LVDS Dual channel 2 x 24bit LVDS
DVI Optional Chrontel CH7307 DVI transmitter
Audio
AC97 Codec
Realtek ALC8837 7.1audio interface
Audio interface
Mic in, Lin in, CD audio in, Lin out
Ethernet
Chipset Triple Marvell EC88E8053 Gigabit LAN controller
Ethernet Interface Dual 10/100/1000 Base-TX Ethernet
Mechanical & Environmental
Power Type 24 pins ATX power connector
Operating Temperature 0°C to 60°C ( 32°F to 140°F )
Relative Humidity 0% to 90% ( non condensing )
Form Factor
MiniITX
Dimensions (LxW)
6.7" x 6.7" (170mm x 170mm)
12-27-2007, 07:58 AM
#49
Raw Wave
And another...
Epox - ADE-6040
System
CPU
Intel® CoreTM2 Duo Desktop / Pentium® 4 / Celeron® D processor in the LGA775 package (E6000, 600, 500, 300 sequences)
FSB
1066/800/533 MHz
BIOS
Award BIOS
System Chipset
Intel® Q965 + ICH8
I/O Chip
Winbond W83627DHG
System Memory
2 x 240-pin DIMM sockets support dual-channel DDR2 533/667/800 SDRAM
Storage
4 X STAT
Watchdog Timer
H/W Status Monitor
Winbond® W83627DHG chip, monitoring for CPU and system temperature, voltage and fan speed
Expansion
1 x PCI-E x 16 slot
M I/O
External 4 X USB 2.0, 1 X RS232, 2 X LAN ports, 1X KB/MS
Display
Chipset Intel® 965GM Integrated GMA3000 graphics
Display Memory
Resolution
VGA/LCD Interface
DSUB-15 connector for VGA output
LVDS Optional Chrontel CH7308 LVDS transmitter
Audio
HDA Codec
Realtek ALC883 7.1 +2CH audio interface
Audio interface
Mic in, Lin in, CD audio in, Lin out, real out and center/subwoofer out
Ethernet
Chipset Dual Marvell EC88E8053 Gigabit LAN controller
Power Type 24 pins ATX power connector, 1 X 4pin ATX 12V
Relative Humidity
Form Factor
MiniITX
Dimensions (LxW)
12-27-2007, 08:05 AM
#50
Raw Wave
And one last one...
Epox - IP-I945GM-EID
System
CPU
Intel®Core®Duo and Solo Processor - T2000, T1000 sequences (Yonah)
Intel®Celeron®M Processor - 400 sequences
FSB
667/533 MHz
BIOS
Award BIOS
System Chipset
Intel®945GM + ICH7M
I/O Chip
ITE F8712F LPC bus I/O controller
System Memory
1 x 200-pin SODIMM sockets support dualchannel
DDR2 400/533/667 SDRAM
Max. up to1 GB memory
Storage
1 X EIDE channel, 2 X STAT and one CF socket support DMA model (optional)
Watchdog Timer
H/W Status Monitor
ITE?F8712F chip, monitoring for CPU and system temperature, voltage and fan speed
Expansion
1 x PCI-E by16 slot, 1 mini PCI slot
M I/O
Internal 2 X USB 2.0, 1 X LPT pin header,1 X 6 pins KB/MS extend pin header
External 4 X USB 2.0, 2 X RS232, 1 X RS232/485/422, 2 X LAN ports, 1X KB/MS
Display
Chipset Intel®945GM Integrated GMA950 graphics
Display Memory
Intel®VMT 3.0 supports up to 224 MB video memory
Resolution
VGA/LCD Interface
VGA DSUB-15 & DVI connectors
LVDS Dual channel ( 2x 18bit) LVDS
DVI Chrontel CH7307 DVI transmitter
Audio
AC97 Codec Realtek®LC 655 AC97 5.1CH, 3D audio interface
Audio interface
Ethernet
Chipset Marvell EC88E8056 Gigabit LAN controller
Power Type 20 pins ATX power connector
Relative Humidity
Form Factor
MiniITX
Dimensions (LxW)
12-31-2007, 01:43 PM
#51
I have to say this has been one of the most informative posts i have read on the subject, thanks all...
12-31-2007, 03:31 PM
#52
Liantec
I had to email the sales rep for the US at Liantec. I'm ordering two (2) of the 6965 board with expresscard daughterboards next week. We'll see how it turns out. Hope it doesn't take a million yrs to arrive from Taiwan....
UPDATE: I actually had to hold off til maybe first week of Feb cause of holiday shopping.
Reason: Update
01-03-2008, 01:41 AM
#53
I use intel dg965ss motherboard
Intel® Desktop Board DG965SS Features
Features Benefits
Form Factor microATX (9.60 inches by 9.60 inches [243.84 millimeters by 243.84 millimeters])
Processor
Support for an Intel® Core™2 Duo processor in an LGA775 socket with a 1066 or 800 MHz system bus
Support for an Intel® Pentium® D processor in an LGA775 socket with an 800 or 533 MHz system bus
Support for an Intel® Pentium® 4 processor in an LGA775 socket with an 800 or 533 MHz system bus
Support for an Intel® Celeron® D processor in an LGA775 socket with a 533 MHz system bus
View all supported processors
Memory
Four 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
Support for DDR2 800, DDR2 667, or DDR2 533 MHz DIMMs
Support for up to 8 GB of system memory
Chipset Intel® G965 Express Chipset
Audio 6-channel (5.1) audio subsystem using the SigmaTel* STAC9227 audio codec
Video Intel® Graphics Media Accelerator X3000 (Intel® GMA X3000) onboard graphics subsystem
I/O Control Legacy I/O controller for diskette drive, serial, parallel, and PS/2* ports
LAN Support Gigabit (10/100/1000 Mbits/sec) LAN subsystem using the Intel® 82566DC Gigabit Ethernet Controller
Peripheral Interfaces
Ten USB 2.0 ports
Two IEEE-1394a interfaces: one back panel connector and one front-panel header
Four Serial ATA IDE interfaces
One Parallel ATA IDE interface with UDMA 33, ATA-66/100/133 support
One diskette drive interface
One serial port via header
One parallel port
Expansion Capabilities
One PCI Express* x16 bus add-in card
One PCI Express x1 bus add-in card connector
Two PCI Conventional* bus connectors
Microsoft Vista* Premium Ready With a PC built with Intel® Core™2 Duo or Intel® Core™2 Quad processors, and the Intel® Desktop Board, you can experience a more responsive and manageable environment of Microsoft Windows Vista* including a new visual sophistication of the Windows Aero* interface.
Related Products
Processors
Chipsets Intel® G965 Express Chipset
01-03-2008, 03:40 AM
#54
Raw Wave
Features Benefits
Processor
Memory
Ten USB 2.0 ports
One parallel port
Related Products
Processors
That does look like a nice MB to use but this thread is for mini-ITX MBs not Micro-ATX.
01-11-2008, 03:00 AM
#55
Agreed. I was just researching for a decent Socket P mATX mobile-on-desktop board, and found that they're mostly Mini-ITX these days, and this thread has a wealth of info!
I'm glad google brought me back here, as it's been a few years since I visited the site often (around 2004). It was definitely a pleasant surprise to see C2D on Mini-ITX size boards, especially since I was used to seeing VIA C3 stuff on that size back then.
01-12-2008, 07:08 PM
#56
Hi rayjr13, I'm also trying to get hold of Liantec boards, so please could you let me know if you get a response from their rep, and prices etc.? I'm actually after their Geode board, but can't find their products in the retail/distribution chain anywhere...
cheers
01-13-2008, 04:11 PM
#57
Better picture of the MSI Fuzzy 945GM2:
01-14-2008, 04:48 AM
#58
i've found a site which tested couple of boards:
http://www.epiacenter.de/modules.php...id=233&page=10
why the hell is C7 processor so good compared to core duo on J9F2-extreme board? (when you look at the HD playback)
or am i missing something as i can't understand German?
i thought i'd go for J9F2, but after seeing the charts, i started to look for a better board :|
01-14-2008, 05:24 AM
#59
Fusion Brain Creator
When I read this I thought "crap"! I just bought a J9F2 and a nifty c2d chip to go with it too.
Then I thought, "self, this cant be right" so I looked at it again.
The J9F2, is the #1 board on almost everything there. It is CPU utilization. so maxed out at 100, means the CPU is 100% taxed compared to the J9F2's 30% at 1080i.
And I am pretty sure this entire paragraph is giving the "Jetway Main Board" high praise for not even flinching with a T7200 no matter what they did to it:
Auch hier wird das J9F2 mit den gestellten Anforderungen ohne Probleme fertig. Auch HDTV kann die Platine mit dem T7200 erwartungsgemäß nicht ins Schwitzen bringen. Beim VLC-Test weicht die CPU-Auslastung wieder einmal kaum von den vergleichbaren Boards ab. Es sei noch erwähnt, dass das Jetway J9F2 alle Formate ohne Probleme mit allen Playern wiedergeben konnte. Alles in allem liefert das Jetway Mainboard eine runde Performance bei der Videowiedergabe ab und die CPU-Last lag selbst bei 1080i mit keinem Player über 41%.
01-14-2008, 09:01 AM
#60
cool, thanks
that explains everything indeed
i thought i need to go through shtloads of motherboards now to find the best one
they all have nice names as well - something like FADJ8734aSDASD/&/ASD
| Thread Tools |
| Display Modes |
Linear Mode
