Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-25-2008, 07:01 PM   #106
galvitron's Avatar
galvitron is an unknown quantity at this point
Here's the Commell version:
Commell LV-67B
http://www.commell.com.tw/News/News/...912_LV-67B.htm
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
galvitron is offline   Reply With Quote
Old 11-25-2008, 08:48 PM   #107
bmw_car_pc is an unknown quantity at this point
do any of the boards support the core 2 quad processors?
bmw_car_pc is offline   Reply With Quote
Old 11-25-2008, 10:26 PM   #108
galvitron's Avatar
Here you go:
http://www.commell.com.tw/Product/SBC/LV-678.HTM
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 11-25-2008, 11:20 PM   #109
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Commell LV-67B
http://www.bwi.com/configure/865686
$446!!!!!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 11-25-2008, 11:28 PM   #110
SD beats everything. So there.
danielkh's Avatar
danielkh is an unknown quantity at this point
Quote: Originally Posted by RedGTiVR6 View Post
Plus CPU and RAM. lol
Still, that is one nice board. 10 USB ports, onboard video, 7.1 onboard audio, I bet it would kick butt. It's like the Kino on serious steroids. Bet you would have ZERO configuration or USB errors with that one.
My opinion is my own.
danielkh is offline   Reply With Quote
Old 11-25-2008, 11:41 PM   #111
galvitron's Avatar
You pay for what you get
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 11-26-2008, 12:57 AM   #112
_
It's not much different from my DG45FC, only it uses a mobile processor and has firewire.
Which are the two critical things making me want to change boards...lol
Wonder if you can underclock via the bios....
Jan Bennett
Old 11-26-2008, 10:34 AM   #113
rijk is an unknown quantity at this point
Are you having power isues? BEcause when i look to the voltmeter in the car, the cpc does't use that mutch you don't see the meter drop. But whe the amps swith on you do see a drop in volts. But still one heated seat uses more.
I ditched my commel because of the cold wheater problems i had with it and also the warrenty wasn't as long as the intel.
rijk is offline   Reply With Quote
Old 11-26-2008, 12:31 PM   #114
_
I'm not having power issues.
Keep in mind that what I use a CarPC for is extreme sound quality reproduction.
A desktop processor generates a lot more heat than a mobile processor does.
This means more current draw through the system AND the requirement of a louder fan than a mobile processor. To boot, with a mobile processor, I can actually underclock it (if the board allows for it) and can run it with only passive cooling for short periods of time (aka judging).
Extreme cold weather isn't so much of an issue down here. A few days will drop to the teens, maybe a single digit here or there, but nothing like what they get up north.
For me, HEAT is the main concern as 115 degree days during the summer can and have been the norm for a month straight.
Jan Bennett
Old 11-26-2008, 12:48 PM   #115
dangs is an unknown quantity at this point
Go for Intel ATOM
If you want a board that runs fast without generating much heat, you should go for Intel ATOM or Via Nano, then we talking 2-5 Watt for the cpu.
Kontron - ktus15mitx
dangs is offline   Reply With Quote
Old 11-26-2008, 05:09 PM   #116
I know, because of your ppost on the sound of this board i got it too. Even the U46mk2 (dj soundcard) didn't cut it) the sound of the dg45fc is like the head i had. Low on the dls fronts .
its a litle of topic, But i use a Zalman CNPS8000 cpu cooler with the lowest fan speed. It has 3 wires, so the dg45fc can't controle the fanspeed.
I did have to modify the X-bracket, but after that it works and fits like a charm.
(i'll update the worklog with the pictures, thought the X-braket is already on the forum in a dg45fc thread).
Old 11-26-2008, 06:15 PM   #117
_
That would be great and all....but they don't fit my needs. I don't just need a motherboard, I need a motherboard with certain features.
Don't have room for a full height CPU cooler. Must use a 1U cooler. I had to modify my X-bracket as well.
Jan Bennett
Old 11-26-2008, 06:36 PM   #118
_
So i requested a quote....this is pretty good:
Quote:
GLOBAL'S RESPONSE
Our Integrated mini-ITX Motherboard Assembly will consist of the following:
  • Our mini-ITX Motherboard P/N 2808100 - with Integrated 9V ~ 24V full range DC input DC/DC Converter on board, ATX power connector on board, 1-mini-PCIe socket, 1 X mini-PCI socket, 1 X PCIeX16 slot, etc., etc.
  • Cable Kit, I/O Shield and CD ROM Media with Manual and Drivers.
  • Intel MOBILE, Socket P, CORE 2 DUO, T9400, 2.53 GHz CPU with 6.0 MB L2 Cache and 1066 MHz FSB
  • Low Profile DEDICATED COPPER CPU Cooling Assembly.
  • 1.0 GB DDR3, PC3-8500 SDRAM
  • *The Assembly will be integrated , tested, stressed (PASSMARK BURNINTEST Version 5.3) and subjected to8 hours minimum of DYNAMIC burn-in and a Certificate of Compliance to test will be attached to each unit.
The unit carries 12 month warranty for all the components FROM JUST ONE SOURCE - GLOBAL AMERICAN, INC.
Quantity 1-9 -$ 1099.63 each
Quantity 10-99 -$ 1058.57 each
DELIVERY - ALL the Components are within 10 working days ARO (These can be expedited at an EXTRA CHARGE)
The Fully Integrated, Tested, Stressed and Burnt-in Assembly will be NLT 17 working days ARO (These can be expedited to NLT 10 working days ARO at an EXTRA CHARGE of NTE$ 50.00 for up to 2 Assemblies)
Jan Bennett
Old 11-27-2008, 04:34 AM   #119
The atum boards still have one problem. The chipset needs a lot of power.
In idle it just uses 10 wats las than the dg45fc with a E8500 processor lower processors use 5 watts less.
Yes with full load it will use more power. But full load for the atum isn't full load for the dg45fc.
Also the sound options for the atum boards was a little les than the dg.
Old 11-27-2008, 04:47 AM   #120
galvitron's Avatar
[/font][/b][/b][/color][/color]
That's Global for ya! They treated me pretty good and I can speak highly for their resident engineers (assuming they're still employed).
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 03:24 AM
mac mini core solo enough for bootcamp? replicant MacCar 6 06-27-2006 12:49 AM
Please read naked girls and Looking for good info on commell P4 itx and via boards. 8675309 Newbie 7 07-19-2005 06:24 PM
MINI atx or Itx JDTUNER General Hardware Discussion 1 06-01-2005 11:31 PM
Where to Purchase Jetway ITX boards? SuperMatty Classified Archive 10 05-26-2003 12:21 AM
