Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-27-2008, 04:50 AM   #121
galvitron's Avatar
galvitron is an unknown quantity at this point
Quote: Originally Posted by rijk View Post
The atum boards still have one problem. The chipset needs a lot of power.
In idle it just uses 10 wats las than the dg45fc with a E8500 processor lower processors use 5 watts less.
Yes with full load it will use more power. But full load for the atum isn't full load for the dg45fc.
Also the sound options for the atum boards was a little les than the dg.
This is true. Many Atom boards use the 945 chipset, which is ancient and was also designed before anyone cared about "green".
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
galvitron is offline   Reply With Quote
Old 11-28-2008, 02:12 AM   #122
LCat is an unknown quantity at this point
Trying to get difference between Global and LV-67B looks like same board and configured with same CPU/RAM COMMELL's is about $280 cheaper.
On the other hand - I need to find a board which could house full size PCI card(Lynx 22)but might get away with PCI-E Lynx AES16e. Then I needto find case which can host it .
BTW any opinion on VIA Nano chips/boards
LCat is offline   Reply With Quote
Old 11-28-2008, 02:33 AM   #123
galvitron's Avatar
Global sells rebranded Commells, so it is the same board.
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 11-28-2008, 10:14 AM   #124
SD beats everything. So there.
danielkh's Avatar
danielkh is an unknown quantity at this point
Quote: Originally Posted by RedGTiVR6 View Post
So i requested a quote....this is pretty good:
[/FONT][/B][/B][/COLOR][/COLOR]
That's a good number. If you go that way, I would love to know how it works. Can't justify it with having the Kino, but I would like to know for future reference. Especially interested in the ACL888 sound(you're not going to use that, are you. lol)
Do they still make the peltier coolers? That might work well for you if they do. Small strip that gets really cold on one side while releasing the heat on the other? The one I had back in the early 90's worked really well. Went between the CPU and fan and didn't add that much to the height. Not sure how they would work in a mobile environment though.
My opinion is my own.
danielkh is offline   Reply With Quote
Old 11-28-2008, 11:14 AM   #125
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Quote: Originally Posted by danielkh View Post
Plus CPU and RAM. lol
Still, that is one nice board. 10 USB ports, onboard video, 7.1 onboard audio, I bet it would kick butt. It's like the Kino on serious steroids. Bet you would have ZERO configuration or USB errors with that one.
Which KINO are you talking about? The KINO-690S1, or a INTEL version? The AMD version is really fast, uses laptop RAM (so doesnt take up space). It has 8 USB ports, but they are picky with what gets plugged into them, it took me a long time to finally get everything working good. Audio is so cr@ppy, for this being a suppossed highend multimedia board, only have a stereo line out and a mic in port is rather cr@ppy. Graphics wise this board is amazing, I love the graphics and how it renders 3D so easily (have arcade games on it). Bad thing is that they only put a passive heatsink, so the GPU overheats easily. I had to add a fan to it. This mobo runs on SATA, with 1 IDE port (which I dont use) and 4 serial ports (I use these for Sirius XM, OBD2 scanner, Amp_Ctrl, and HD Radio).
I love this board alot that I was willing to deal with the USB and overheating issues. The downfall is that it seems to be one of the only AMD boards I could find, and alot of sites are not carrying it anymore. I recently had to RMA the board from the GPU blowing out (was my fauly though, not from over heating). Im worried that in the future I wont be able to RMA it anymore, but I guess that happens with all technology.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 11-28-2008, 11:21 AM   #126
danielkh's Avatar
Kino-9452 with the 7.1 HD Audio. (Intel version with 6 back audio ports and 2 front)
I would put the audio on this board against any USB and most (Don't jump on me Jan, I said MOST! lol) PCI soundcards. Since it's onboard, there aren't any configuration issues that I have found and has extreme controllability.
Old 11-28-2008, 04:12 PM   #127
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
danielkh - you know I don't use onboard analogue outputs, right? Never have and never will. Don't even recomend them as they sound HORRIBLE.
Onboard optic is a different situation.
If I DO go that route, then I'll be running optic into the Alpine for the time being...hopefully that will change soon though.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 11-28-2008, 04:19 PM   #128
rijk is an unknown quantity at this point
For me, HEAT is the main concern as 115 degree days during the summer can and have been the norm for a month straight.
If you change boards this quickly, maybe my old position of the mobo is a solution for you. My board had to mutch cold on that position.
(engine bay see worklog for the pictures)
@ sh** forgot to test the boottime
rijk is offline   Reply With Quote
Old 11-28-2008, 04:36 PM   #129
_
I'm not sure I understand your post. Are you saying that I should consider putting a CarPC in the engine bay of my car?
Jan Bennett
Old 11-28-2008, 04:52 PM   #130
HiJackZX1's Avatar
What car is this for? The GTi or your Dodge? I know this is drastic, but maybe instead of having, whatever car its in, 5 seats, drop it down to 4 seats and build the middle seat into a center console that holds the PC. Mine is like this and has 2 large fans in the front that pull large amounts of air in and 2 in the back that pull the air out. My front console also has fans that pull the air in and out and by a thing of luck, when the A/C is on, the front console sucks in the A/C air, then blows it out the back of it, where then the second console gets that air, sucks it in, cools the P/C and then dumps the air out the back. It has worked very well so far.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 11-28-2008, 06:57 PM   #131
_
Guys - I'm not sure how this thread turned into a discussion about my car and my install, but that's not the intent.
My current solution works 100% fine. The ONLY reason I posted anything about heat was to say that a full size desktop processor isn't ideal for me considering I need to keep it a quiet as possible.
And thanks, but rebuilding the entire back seat of the GTi isn't going to happen. We have to keep the car in a state where we can pull the bottom cushions of the back seat out, throw a cooler, a pop-up tent, and all of our show stuff back there, then drive 16 hours to a show with the car when we need to.
Again, I want to stress...my current location and solution fits my needs very well. The ONLY reason I EVER brought up the heat issue was to explain why I was looking for a mobile processor motherboard.
Jan Bennett
Old 11-28-2008, 07:27 PM   #132
HiJackZX1's Avatar
WOW, you get so touchy lately. Well we UNDERSTAND, I am SORRY for putting my 2 cents in. It will NEVER happen again.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 11-28-2008, 09:38 PM   #133
I would not put this board against MAUSB based DACs - CA Datamagic, MF V300, Benchmark D1, Empirical Spoiler, WaveLength DACs, VAC Alpha, etc.....
I also would not put this board against many USB to optical card - for example Empirical Audio USB Off-Ramp is an absolute killer http://www.empiricalaudio.com/frComputer_Audio.html
But properly modifed Lynx with added Superclock 4 in properly tuned computer with a right software - is a best digital source in the world easly besting $20-50K dedicated CD transports - and doing it soo much better what it's not even funny.
Old 11-28-2008, 10:09 PM   #134
Well looks like I have a better set of requirements now - Penryn board(so Kino is out), PCI slot, do not care about onboard audio at all, but 2 display onboard video might be nice - Any suggestion - at any price
Old 11-29-2008, 08:33 AM   #135
_
I guess I should just ignore you then...maybe that would have been the better solution.
Perhaps my tone didn't come across correctly in text, imagine that.
I'm not sure what set you over the edge on it, but I wasn't being touchy, I was heading off the entire discussion before it happened...since it wasn't necessary.
Jan Bennett
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 03:24 AM
mac mini core solo enough for bootcamp? replicant MacCar 6 06-27-2006 12:49 AM
Please read naked girls and Looking for good info on commell P4 itx and via boards. 8675309 Newbie 7 07-19-2005 06:24 PM
MINI atx or Itx JDTUNER General Hardware Discussion 1 06-01-2005 11:31 PM
Where to Purchase Jetway ITX boards? SuperMatty Classified Archive 10 05-26-2003 12:21 AM
