Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-26-2007, 10:35 AM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
FAQ Core Duo / Core 2 Duo Mini-ITX boards
In my quest to update the stickey up top that lists off the various mini-itx motherboards avaliable, I'm looking for new core duo or core 2 duo mini-itx motherboards.
So rather than just list off the ones I know about, I'd like to hear from you all about what you know about.
Anyone care to chime in?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Advertisement Sponsored links
Old 07-26-2007, 12:53 PM   #2
_
Here's a short list of boards I've found so far:
Jan Bennett
Old 07-26-2007, 01:26 PM   #3
_
Commell LV-677
PDF link
  • CPU: Intel CoreTM Duo / Core 2 Duo processor ( Merom ) @ 533 / 677 MHz FSB
  • Memory: 2 x 240-pin DDR2 533/667MHz up to 3.0 GB
  • Chipset: Intel 945GME and ICH7M
  • Video: built-in Intel Graphics Media Accelerator (GMA) 950 technology
  • I/O: One UltraATA33 IDE interface supports up to 2 ATAPI Devices, 2 x Serial ATA interface with 150 MB/s transfer rate, 1 x IEEE1394 port, 2 x Mini-PCI socket and 1 x PCI-Express 16x slot (x1 compatinle), PS/2 Keyboard/Mouse , LPT , VGA , LAN , USB2.0 , Audio , SPDIF , IEEE 1394
  • Lan: 1 x Intel 82573L Gigabit Ethernet
  • Audio: Realtek ALC880 5.1 channel Audio
Commell LV-676
PDF Link
  • CPU: Intel Core 2 Quad / Core 2 Duo Desktop / Pentium D with LGA775 @ 533/800/1066 MHz FSB. ( Extreme Edition processor don't support )
  • Memory: 2 x 240-pin DDR2 533/667/800MHz up to 3.0GB
  • Chipset: Intel Q965 and ICH8DO
  • Video: built-in Intel extreme GMA 3000 technology
  • I/O: 6 x Serial ATA II interface with 300MB/s transfer rate.Support RAID 0,1,5,10, 2 x IEEE1394 port, Onboard 8-bit Digital I/O interface, 1 x Mini-PCI socket and 1 x PCI slot, LAN ports , RS232/422/485 ports , USB 2.0 ports , IEEE 1394 , IrDA , S/PDIF , Audio
  • LAN: 2 x Intel 82573L Gigabit Ethernet Controller
  • Audio: Realtek ALC888 High Definition Audio
Commell LV-674E
PDF Link
  • CPU: Intel Pentium D / Celeron D with LGA775 @ 533/800/1066 MHz FSB
  • Memory: 2 x 240-pin DDR2 533/667MHz up to 2.0GB
  • Chipset: Intel 945G and ICH7R
  • I/O: One UltraATA/100 IDE interface supports up to 2 ATAPI Devices, 4 x Serial ATA II interface with 300MB/s transfer rate.Support RAID 0,1,5,10, 2 x IEEE1394 port, 1 x Mini-PCI socket and 1 x PCI-Express 16x slot (x1 compatible), LAN ports , RS232 ports , USB 2.0 ports , IEEE 1394 , IrDA , S/PDIF
  • LAN: 4 x Marvell E8053 Gigabit Ethernet Controller
  • Audio: Realtek ALC880 7.1-CH High Definition Audio
  • Solid State Disk (SSD): IDE1 supports DiskOnModule with +5V power supply
AOpen i945GMt-FA
  • CPU: Intel Core 2 Duo (Merom) / Core Duo / Core Solo (Yonah) and Celeron M (4xx) Processor, 667MHz, Socket M
  • Memory: SO-DIMM DDRII 667/533/400 x 2 (256/512MB & 1GB) max 4GB
  • Chipset: Intel 945GM & Intel ICH7M
  • Video: Integrated VGA Engine in chipset (Intel GMA 950)
  • I/O: Mini PCI x 1, PCI Express (PCIe x1) x1, RJ45 LAN Port x 1, Line_In x 1, Speaker_Out x 1, MIC_In x 1, Center / Subwoofer x 1, Rear Surround x 1, Side Surround x 1, PS/2 Keyboard Connector x 1, PS/2 Mouse Connector x 1, AC Adapter Connector x 1, DVI Port x 1, S-Video Out Port x 1, COM Port x 1, USB 2.0 Port x 4, 1394 Port x 1, Serial ATA II Channel x 2, IDE ATA100 Connector x 1, 4-pin 5V Output Connector x 1 (for Hard Disk / Optical Drive), CPU FAN Connector x 1, System FAN Connector x 1, Front Panel Connector x 1, Front Audio Connector x 1, IEEE 1394 Connector x 1, CD_IN Connector x 1, USB Connector x 2 (supports USB port x 4), COM Connector x 1
  • LAN: Integrated Realtek Gigabit PCI LAN Chip
  • Audio: 7.1 Channel Realtek ALC882 HD Audio CODEC on-Board
AOpen i945GMt-FSA
  • I/O: Mini PCI x 1, PCI Express (PCIe x1) x 1, 1394 Port x 1, RJ45 LAN Port x 1, Line_In / SPDIF_In x 1. Speaker_Out x 1, MIC_In x 1, Center / Subwoofer x 1, Rear Surround / SPDIF_Out x 1, Side Surround x 1, PS/2 Keyboard Connector x 1, PS/2 Mouse Connector x 1, AC Adapter Connector x 1, DVI Port x 1, S-Video Out Port x 1, COM Port x 1, USB 2.0 Port x 4
  • Lan: Integrated Realtek Gigabit PCI LAN Chip
  • Audio: 7.1 Channel Realtek ALC888 HD Audio CODEC on-Board
AOpen i945GTt-VFA
  • Chipset: Intel 945GT & Intel ICH7M-DH
  • I/O: Mini PCI x 1, PCI Express (PCIe x1) x 1, DVI Port x 1, S-Video Out Port x 1, COM Port x 1, USB 2.0 Port x 4, 1394 Port x 1, RJ45 LAN Port x 1, Line_In / SPDIF_In x 1, Speaker_Out x 1, MIC_In x 1, Center / Subwoofer x 1, Rear Surround / SPDIF_Out x 1, Side Surround x 1, PS/2 Keyboard Connector x 1, PS/2 Mouse Connector x 1, AC Adapter Connector x 1, Serial ATA II Channel x 2, IDE ATA100 Connector x 1, 4-pin 5V Output Connector x 1 (for Hard Disk / Optical Drive), CPU FAN Connector x 1, System FAN Connector x 1, Front Panel Connector x 1, Front Audio Connector x 1, IEEE 1394 Connector x 1, CD_IN Connector x 1, USB Connector x 2 (supports USB port x 4), COM Connector x 1
  • Audio: 7.1 Channel and above, Realtek ALC882 HD Audio CODEC on-Board
Kontron 986LCD-M/mITX
PDF Link
  • CPU: Intel® Core™ 2 Duo Mobile, Intel® Core™ Duo, Intel® Core™ Solo and Celeron® M Processors (mPGA478 socket, mBGA479 prepared), Support Yonah and Merom CPU core, Front Side Bus 533/667 MHz
  • Memory: 3GB DDR2 memory support (2+1)
  • Chipset: Intel® 945GM + Intel® ICH7R Chipset
  • Video: Intel® GMA950 graphic controller on board
  • I/O: 1x 16x PCI-Express /SDVO external graphic card socket, 8x USB 2.0, 4x RS232C, 2x IEEE1394, 1x ATA100 and 4x SATA150/300 IDE Controller, 1x Compact Flash socket, 1x mini PCI-Express socket for easy expansion of i.e. wireless LAN, On board RAID 0/1/5/10 support with SATA harddisk
  • LAN: 3 x 10/100/1000 Mbps Ethernet
  • Audio: 7.1ch HDA / AC-97compliant audio output
MSI Fuzzy 945GM1
  • CPU: Supports Intel® Yonah (Intel® Core™ Duo/ T2000 Seqence) and Merom (Intel® Core™ 2 Duo/ T5000 & T7000 Sequence) processor up to 2.33GHz (Napa Platform) in PGA Package, 2MB L2 cache (Yonah) / 4MB (Merom), Supported FSB: 667/533 MHz
  • Memory: DDRII 533/667 SDRAM (4GB Max), 2 DDRII DIMMs (240pin / 1.8V)
  • Chipset: Intel® 945GM & Intel® ICH7-MDH (82801GHM)
  • Video: Mobile Intel® 945GM Express Chipset
  • I/O: 1 PCI v2.3 slot, 1 PS/2 mouse port, 1 PS/2 keyboard port, 2 serial ports (COM ports), 4 USB 2.0 ports, 2 LAN jacks 10/100/1000, 3 audio jacks (1 Line-In, 1 Line-Out, 1 Mic-In), 1 D-Sub Graphics Card port, 1 DVI port
  • LAN: Supports Dual Intel® 10/100/1000 LAN by two Intel® 82541PI Giga- LAN controller)
  • Audio: Chip integrated by Realtek® ALC658
MSI Fuzzy 945GM2
  • CPU: Intel® Core 2 Duo/Core Duo/Core Solo/Celeron M CPU in Socket M, Supported FSB: 533/667MHz
  • Memory: DDRII 533/667 SDRAM (2GB Max), 1 DDRII DIMM slot (240pin / 1.8V)
  • Chipset: Intel 945GM + ICH7M chipset
  • I/O: 3 RJ-45 LAN jacks, 2 USB 2.0 ports, 1 D-Sub Graphics Card connector, 1 serial port, 1 PS2 keyboard.mouse port, 1 Line-In/Line-Out/Mic-In stacked audio jack, 1 USB 2.0 pinheader (2 ports), 1 parallel port pinheader, 1 front audio pinheader, 1 LVDS connector, 1 Digital I/O pinheader (16GPIO), 1 RS232/422/485 COM port header for COM2~COM5 (optional), 1 front panel pinheader
  • LAN: Supports 3 PCI Express Gb Ethernet by Intel 82573L or one Intel 82562GZ 10/100 LAN (optional)
  • Audio: HDA Codec by Realtek® ALC888 7.1 channel
MSI Fuzzy 965GM2
  • CPU: Intel Socket P Core2Duo, CoreDuo & Celeron M @ FSB 667/800 MHz
  • Memory: 240pin DDR2 667/800 DIMM Socket X2 up to 4GB
  • Chipset: Intel GM965 + ICH8M
  • Video: Intel GMA 3100 (Share system memory up to 256MB)
  • I/O: CRT 9pin D-Sub x1, Dual Channel 24Bit LVDS, HDTV Out, Ultra DMA 66/100 Mode IDE 40 Pin x1, SATA x2, CF Socket x1, RS-232 x2, PS/2 (K/B x1, Mouse x1), USB 2.0 x8, PCI-E x16, 32-bit PCI, Mini-PCIE
  • LAN: Intel I82566 DC< Intel 82573L, 10/100/1000
  • Audio: 7.1/5.1 Channels HD Audio, 6 watt amplifier
IEI KINO-9455
PDF Link
  • CPU: Socket M Intel® Core™2 Duo, Core™ Duo/Solo with 667 MHz FSB, Intel® Celeron M 533MHz FSB (Yonah Core)
  • Memory: 2x240-pin dual channel DDR2 400/533/667 MHz up to 4GB
  • Chipset: Intel® 945GM + ICH7M
  • Video: VGA integrated in Intel® 945G
  • I/O: 8 x USB 2.0, 2 x SATA II, 1 x IDE, 3 x RS-232, 1 x RS232/422/485, 2 x PS/2 for KB/MS, 1 x Mini PCI Slot, 1 x PCI
  • LAN: Dual PCIe GbE BROADCOM BCM5787 M Dekete GbE chipsets with ASF2.0 remote control support
  • Audio: Realtek ALC883 with 7.1 channel HD interface
IEI KINO-9454-R20
PDF Link
  • CPU: LGA 775 Intel® Core™2 Duo, Pentium® D/4/Celeron® D with 533/800/1066MHz FSB
  • Memory: 2 x 240-pin dual channel, DDR2 400/533/667MHz up to 4GB
  • Chipset: Intel® 945G + ICH7
  • I/O: 8 x USB 2.0, 4 x SATA II, 1 x IDE, 3 x RS-232, 1 x RS-232/422/485, 2 x PS/2 for KB/MS, 1 x 20-pin LPC (TPM Module), 1 x PCIe, x16 (Support PCIe x1/2/4/8/16 PCIe add-on cards), 1 x Mini PCI
  • LAN: Dual PCIe BROADCOM BCM5787 M GbE chipsets with ASF 2.0 remote control support
  • Audio: Realtek ALC655 with AC'97 codec
IEI KINO-9452-R11
PDF Link
IEI KINO-9453
PDF Link
  • CPU: Socket M Intel® Core™2 Duo, Core™ Duo/Solo with 667MHz FSB, Intel® Celeron® M 533MHz FSB (Yonah Core™)
  • Memory: 2 x 240-pin dual channel DDR2 400/533/667MHz up to 4GB
  • Video: VGA Intgrated in Intel® 945GM, 18-bit dual channel LVDS, DVI by Intel® 945GM SDVO interface with dual display support
  • I/O: 8 x USB 2.0, 2 x SATAII, 1 x IDE, 3 x RS-232, 1 x RS-232/422/485, 2 x PS/2 for KB/MS, 1 x Mini PCI Slot, 1 x PCI Digital I/O
  • LAN: Dual PCIe Broadcom BCM5787M GbE chipsets with ASF 2.0
iBase MI910
PDF Link
  • CPU: Socket 478 for Intel® Core™2 Duo, Celeron M, up to 2.4GHz, 533MHz/800MHz
  • Memory: Two DDR2 sockets supports up to 4GB DDR2 SDRAM, 533/667 DDR SDRAM
  • Chipset: Intel® GM965 chipset & ICH8M
  • Video: Intel® GM965 built-in Graphics Media Accelerator X3100, supports CRT and LVDS
  • I/O: PS/2 Keyboard/Mouse, 2x serial (RS232) & Hardware monitor (3 thermal inputs, 4 voltage monitor inputs, VID0-4 & 2 fan headers), Built in ICH8M; One enhanced IDE channel supports, 2 IDE devices; supports UDMA33/66/100, 2 ports (1 port @ edge, 1 via pin header), Supports 6 USB ports (4 ports + 2 ports via pin header), 1 Mini PCI, 1 PCI, 1 PCIe
  • LAN: Primary LAN: Intel® 82566MC/DC Gigabit LAN (MI910 and MI910F), Secondary LAN: Optional, Marvell 88E8053 PCI Express Gigabit LAN (for MI910F, MI910F supports dual Gigabit LAN)
  • Audio: ICH8M built-in Intel® High Definition audio + AC97 Codec ALC885 w/ 7.1 channels
iBase MI900
PDF Link
  • CPU: LGA775, Supports Intel® Core 2 Duo processors, 533MHz / 800MHz / 1066MHz
  • Memory: Two DDR2 sockets support up to 4GB DDR2 SDRAM, PC533/667/800 DDR SDRAM
  • Chipset: Intel® Q965 chipset & ICH8
  • Video: Intel® Q965 integrated graphic sybsystem (GMA3000)
  • I/O: JMicron JM368 (PCI-e to PATA) supports 1 PATA channel, One RS-232 and one RS-232/422/485 COM ports, Supports 4 SATA II Ports, Supports 6 USB ports (4 ports + 2 ports via pin header), PS/2 Keyboard & Mouse ports, 1 PCI-e (x16) slot, 8x2 pin header for adaptor card: ID394 (2 or 4 serial ports)/ ID395 (TPM 1.2 function), PS/2 KB/Mouse Mini DIN, VGA CRT, COM1, 2x RJ-45, 4x USB, Triple jack for audio, 4x SATA, USB5/6, COM2, Digital I/O, 7.1 channel audio, IDE (40-pin), CPU fan, system fan, ATX power (24-pin + 4-pin)
  • LAN: Intel 82562V 10/100 BaseT Ethernet
  • Audio: ICH8 integrated audio with Realtek ALC888 codec
iBase MB899
PDF Link
  • CPU: Socket 478, Supports Intel® Core™ Duo processors Up to 2.33GHz, 533Hz / 667MHz
  • Memory: Two DDR2 sockets supports up to 4GB DDR SDRAM, PC400/533/667 DDR SDRAM
  • Chipset: Intel® 945GM chipset ICH7M
  • Video: Intel® 945GM integrated VGA for CRT/TV out
  • I/O: Built in ICH7M; One enhanced IDE channel supports 2 IDE devices; supports UDMA33/66/100, Onboard slim FDD connector, 2 x RSR232 ports, PCI, MiniPCI, PCI-E(1), Mini PCI, VGA CRT, PS/2 KB/Mouse Mini DIN, two RJ-45, 1394, SPDIF, four USB, RCA, S-Video, COM1, ATX power, COM2, Digital I/O, slim FDD, IrDA, USB5/6, IDE1, 2x SATA, FAN1/2, LAN Wakeup, LVDS1/2, Line out, Microphone, Speaker, CF socket (solder side), 1394, HDTV, Supports 6 USB ports (4 ports + 2 ports via pin header), 1394 Supports 2 ports (TI TSB43LV22)
  • LAN: Primary LAN: ICH7M integrated 10/100 BaseT Ethernet , Secondary LAN: Marvell 88E8053 PCI Express Gigabit Ethernet
  • Audio: ICH7M integrated audio with AC97 codec, board NS LM4950 amplifier
Radisys Endura-TP945GM
PDF Link
The Endura TP945GM mini-ITX delivers exceptional performance with Intel’s latest Core™ Duo T2500 2.0GHz embedded processor
  • CPU: Supports Intel® Core Duo™ and Celeron® M, LV, and ULV processors, Socket PGA-478 CPU socket and support for BGA-479 CPUs. FSB 667MHz and 533MHz system bus
  • Memory: Two sockets for DDR2-667, DDR2-553 and DDR2-400 DIMM modules, Up to 4GB of system memory (3.2GB approx available for system memory), Dual-Channel memory support
  • Chipset: Intel® 945GM Express chipset with Intel® ICH7M
  • Video: Intel® Graphics Media Accelerator 950 integrated video
  • I/O: x16 PCI Express graphics slot – supports x1 PCI Express cards, PCI Mini-PCI Type lllA card socket, Eight USB 2.0 ports – four on rear I/O panel and four on headers, GPIO 13-bit General Purpose I/O header with an additional PWM signal, Four RS232 serial ports – two on rear I/O panel and two on headers, IrDA IrDA compliant infrared interface with support for SIR and ASK, SATA Two SATA 1.5Gbps ports , IDE One Ultra ATA100 interface with 44-way slim type header
  • LAN: Single or dual Broadcom BCM5789 Gigabit Ethernet controllers
  • Audio: Intel® High Definition Audio using Sigmatel STAC9220 eight channel CODEC
BCM MX945GM
PDF Link
  • CPU: Intel® Core™ Solo/Core™ Duo/ Core™ 2 Duo/ Celeron M (65nm) Socket M with 533/667 MHz FSB
  • Memory: One DIMM up to 2GB DDR2 533/667 MHz SDRAM Non ECC System Memory
  • Chipset: Intel® Mobile 82945GM/GME GMCH + Intel® 82801GM ICH7-M
  • I/O: 1 x PCIe x16, PCIe x1, 1 x PCI, 2 x SATA, 5 x COM, 4 x USB, GPIO, 1 x K/B, 1 x Mouse, 1 x IDE (Ultra DMA 66/100), 1 x LPT, 2 x USB 2.0 ports (Rear I/O), 1 x USB pin headers for additional 2 USB, 1 x RS232 for COM1 (Rear I/O), 4 x RS232 for COM2~ COM5
  • LAN: Dual Intel® 82573L Gbit LAN
  • Audio: Realtek® ALC888 support 8 CH HD Audio , SPDIF
iGoLogix i399
  • CPU: Intel® Core™ 2 Duo, Intel Core™ Duo, Intel Solo processors 533/667MHz FSB
  • Memory: Two DDR2 sockets supports up to 4GB PC400/533/667 DDR SDRAM
  • I/O: VGA CRT, PS/2 KB/Mouse Mini DIN, two RJ-45, 1394, SPDIF, four USB, RCA, S-Video, two COM, ATX power, Digital I/O, slim FDD, IrDA, USB5/6, IDE1, two SATA, FAN1/2, LAN Wakeup, LVDS1/2, Line out, Microphone, Speaker, 1394, HDTV
  • Lan: ICH7M integrated 10/100 BaseT Ethernet / Marvell 88E8053 PCI Express Gigabit Ethernet (for dual LAN model)
  • Audio: ICH7M integrated audio with AC97 codec onboard NS LM4950 amplifier
Axiomtek SBC86831
PDF Link
  • CPU: Socket M for Intel® Core™2 Duo/Core™ Duo/Core™ Solo processor with FSB 533/667MHz
  • Memory: 2 x 240-pin DDR2 DIMM max. up to 3GB
  • Chipset: Intel® 945GME+ICH7M
  • Video: Intel® 945GME GMCH Gen 3.5 integrated graphic engine
  • I/O: 1 x PATA-100 IDE, 2 x SATA-150, 1 x 26-pin box-header for shared FDD/LPT, 1 x PS/2 K/B, 1 x PS/2 MS, 4 x COM (3 x RS-232, 1 x RS-232/422/485) with +5V/+12V powered
  • Lan: Dual RTL 8111B for PCI-E Gigabit Ethernet
  • Audio: AC'97 Codec Audio
Portwell WADE-8656
PDF Link
  • CPU: Intel® Core 2 Quad / Core 2 Duo and Pentium® 4/Celeron® D processor, FSB 1066/800/533 MHz
  • Memory: 2 x 240-pin dual channel DDR2 SDRAM DIMM 533/667/800 MHz supports up to 4 GB
  • Chipset: Intel® Q965 GMCH & 82801HB ICH8DO
  • Video: Intel® Q965 GMCH Integrated GMA 3000 Graphics device
  • I/O: 1x RS-232, 1 x RS-232/422/485 selectable, 1 x K/B, 1 x Mouse, 2 x GbE, 4 x USB 2.0 ports and 4 x USB 2.0 with header, 6 x Serial ATA connector high-speed data transfers at up to 3 Gb/s
  • Lan: IEEE 802.3 10/100/1000BASE-T Gigabit Ethernet compliant
  • Audio: Mic in, Line in, Line out
Portwell WADE-8556
PDF Link
  • I/O: 4 x RS-232, 1 x K/B, 1 x Mouse, 1 x GbE, 2 x USB 2.0 ports and 4 x USB 2.0 with header, 4 x Serial ATA connector high-speed data transfers at up to 3 Gb/s
Portwell WADE-8056
PDF Link
  • CPU: Intel® LGA775 Intel® Core™ 2 Duo and Pentium® 4 / Celeron® D processors, FSB 1066/800/533 MHz
Portwell WADE-8156
PDF Link
  • CPU: Intel® LGA775 Core 2 Duo and Pentium® 4 / Celeron® D processors (E6000, 600, 500, 300 series), FSB 1066/800/533 MHz
  • I/O: 2 x RS-232, 1 x K/B, 1 x Mouse, 2 x GbE, 4 x USB 2.0 ports and 4 x USB 2.0 with header, 4 x Serial ATA connector high-speed data transfers at up to 3 Gb/s
  • Audio: HDAC codec with Realtek ALC883 7.1 +2CH 3D audio interface
Portwell PEB-7603VG2A
PDF Link
  • CPU: Intel® Core 2 Duo, Core Duo and solo CPU 400,T2000,T1000,,T5000,T7000, FSB 667/533/400 MHz
  • Memory: 2 x 200-pin SODIMM 667/533/400 SDRAM socket supports up to 4 GB
  • Chipset: Intel® 945 GM + ICH7M, Marvell® 88E8053
  • Video: Intel® 945GM Integrated GMA 950 graphics, up to 224MB share memory
  • I/O: 2 x SATA, 1 x EIDE, 4 x RS-232, 1 x K/B, 1 x Mouse, 4x USB 2.0 ports at Internal I/O, 4 x USB 2.0 ports at Back Panel, 1 x Parallel ATA IDE UDMA 33, ATA-66/100 support, 2 x Series ATA ports, 1 x PCI-E x1, 1 x 32-bit PCI slot,
  • Lan: Dual Marvell® Yukon-EC 88E8053 PCI ExpressTM Ethernet controllers, IEEE 802.3 10/100/1000BASE-T Gigabit Ethernet compliant
  • Audio: Realtek ALC655 5.1CH audio codec
Liantec ITX-6965
PDF Link
  • CPU: Intel Core 2 Duo Mobile CPU @ 800 / 667 / 533 MHz FSB
  • Memory: Two 240-pin DDR2 DIMM sockets, Supports dual channel 3 GBytes DDR2 SDRAM
  • Chipset: Intel embedded GME965 Express GMCH and ICH8M chipset
  • Video: Intel GME965 GMCH built-in Intel GMA X3100 graphics core
  • I/O: One PCI slot supports two bus master PCI bus, One x1 PCI Express slot (riser with PCI slot), One 40-pin UltraATA100 IDE port, Three SATA-II 300MBps ports, 10 USB ports with 6 external and 4 internal USB ports, Dual RS232 serial ports with one external and one internal port, DB15 female VGA and DB9 male COM port, 7.1 channel and S/P DIF audio port, Four USB ports, Composite AV / S-Video TV-out, Dual USB ports, RJ45 Gigabit Ethernet port
  • Lan: Onboard PCI Express Intel 82573L Gigabit Ethernet interface
  • Audio: Intel Azalia HD audio with ICH8M & ACL888S codec
Liantec ITX-6945
PDF Link
  • CPU: Intel Core 2 Duo / Core Duo / Core-based Celeron M Mobile CPU @ 667 / 533 MHz FSB at uFC-PGA package
  • Chipset: Intel embedded 945GME Express GMCH and ICH7M chipset
  • Video: Intel 945GME GMCH built-in Intel GMA950 graphics core
  • I/O: One PCI slot supports two bus master PCI bus, One x1 PCI Express slot (riser with PCI slot), One 40-pin UltraATA100 IDE port, Two SATA-II 300MBps ports, Dual RS232 serial ports with one external and one internal port, DB15 female VGA and DB9 male COM port, 7.1 channel and S/P DIF audio port, Four USB ports, Composite AV / S-Video TV-out, Dual USB ports, RJ45 Gigabit Ethernet port
  • Audio: Intel Azalia HD audio with ICH7M & ACL888S codec
Advantech AIMB-253L
PDF Link
  • CPU: Supports Intel μFC-PGA 478 Core Duo/Core Solo/Core 2 Duo/Pentium M/Celeron M (Yonah Family) with 65nm process technology
  • Memory: One DIMM up to DDR2 533/ 667 2 GB SDRAM
  • Chipset: Intel 82945GM Express Chipset
  • Video: Intel Graphics Media Accelerator 950
  • I/O: VGA x 1, Ethernet x 2, USB x 2, Audio Mic in, Line in, Line out, Parallel x1, Serial 1 (RS-232), PS/2 2 (1 x K/B and 1 x Mouse, 1 channel EIDE (Ultra DMA 133), 150 MB/s x2, 1 x PCI 32-bit/ 33MHz, 1 xPCIe x16
  • Lan: 10/100/1000Base-T Intel 82573L LAN (via PCIe x 1)
  • Audio: Realtek ALC888 supports 7.1 CH HD Audio
DFI CT132-BR
  • CPU: Intel® Core Duo/Solo mobile processor, Core 2 Duo mobile processor, Core processor-based Celeron® M 65nm mobile processor, 667MHz/533MHz Front Side Bus , Processor socket:mPGA478
  • Memory: One 240-pin DDR2 DIMM socket, Supports 400MHz, 533MHz and 667MHz DDR2 SDRAM, Supports maximum of 2GB system memory using 256Mbit, 512Mbit or 1Gbit technology for x8 and x16 devices
  • Chipset: Intel® 945GM Express chipset, Intel® 82801GR I/O Controller Hub (ICH7R)
  • Video: Integrated Intel Graphics Media Accelerator 950
  • I/O: 1 mini-DIN-6 PS/2 mouse port, 1 mini-DIN-6 PS/2 keyboard port, 1 DB-9 serial port, 1 DB-15 VGA Port, 1 RJ45 LAN ports, 4 USB 2.0/1.1 ports, Mic-in, line-in, line-out, 1 connector for 2 additional external USB 2.0/1.1 ports, 1 DIO connector, 1 parallel connector, 1 connector for an external serial port, 1 front audio connector for line-out and mic-in jacks, 1 CD-in internal audio connector, 1 S/PDIF-in/out connector, 1 connector for IrDA interface, 4 Serial ATA connectors, 1 40-pin IDE connector, 1 floppy connector, 1 20-pin ATX power connector, 1 chassis open connector, 1 front panel connector, 2 fan connectors, 1 PCI Express x16 slot, 1 PCI Express x1 slot, 1 PCI slot
  • Lan: One Realtek RTL8111B PCI Express Gigabit controllers
  • Audio: Realtek ALC655 AC'97 audio CODEC
DFI CT132-B
  • CPU: Intel® Core Duo/Solo mobile processor, Core 2 Duo mobile processor, Core processor-based Celeron® M 65nm mobile processor, 667MHz/533MHz Front Side Bus, Processor socket:mPGA478
  • Chipset: Intel® 945GM Express chipset, Intel® 82801GR I/O Controller Hub (ICH7M)
  • I/O: 1 mini-DIN-6 PS/2 mouse port, 1 mini-DIN-6 PS/2 keyboard port, 1 DB-9 serial port, 1 DB-15 VGA port, 1 RJ45 LAN ports, 4 USB 2.0/1.1 ports, Mic-in, line-in and line-out, 1 connector for 2 additional external USB 2.0/1.1 ports, 1 DIO connector, 1 parallel connector, 1 connector for an external serial port, 1 front audio connector for line-out and mic-in jacks, 1 CD-in internal audio connector, 1 S/PDIF-in/out connector, 1 connector for IrDA interface, 2 Serial ATA connectors, 1 40-pin IDE connector, 1 floppy connector, 1 20-pin ATX power connector, 1 chassis open connector, 1 front panel connector, 2 fan connectors, 1 PCI Express x16 slot, 1 PCI Express x1 slot, 1 PCI slot
DFI G5C100-N
  • CPU: Intel® Core Duo/Solo processor, 667MHz/533MHz system data bus, Intel® Celeron® M processor, 533MHz system data bus, Processor socket: mPGA479M
  • Memory: Two 200-pin SODIMM sockets, Supports dual channel(128-bit wide) memory interface, Supports 400MHz, 533MHz and 667 MHz DDR2 SDRAM, Supports maximum of 4GB system memory using 256MBit, 512Mbit of 1Gbit technology for x8 and x16 devices
  • Chipset: Intel® 945GM Graphics Memory Controller Hub(GMCH), Intel® 82801 GBM I/O Controller Hub (ICH7M)
  • Video: Integrated graphics interface, Analog CRT, Integrated 400MHz RAMDAC, Analog monitor supports up to UXGA, LVDS interface, Panel support up to UXGA (1600x1200), 25MHz-112MHz single/dual channel @ 18bpp, TFT, panel type support, Internal graphics features, DVMT 3.0 support, Intel® Dual-Frequency Graphics Technology, Intel® Smart 2D Display Technology, Dual Independent display pipes, Intel Gen 3.5 Integrated Graphics Engine
  • I/O: 1 mini-DIN-6 PS/2 mouse port, 1 mini-DIN-6 PS/2 keyboard port, 3 DB-9 serial ports, 1 DB-15 VGA port, 2 RJ45 LAN ports, 4 USB 2.0/1.1 ports, Mic-in, line-in and line-out, 1 CompactFlash socket, 2 connectors for 4 additional external USB 2.0/1.1 ports, 1 connector for 1 external serial port, 1 LCD brightness control connector, 1 LVDS LCD panel connector, 1 LCD/inverter power connector, 1 LCD AUX power connector, 1 DIO connector, 1 front audio connector for line-out and mic-in jacks, 1 CD-in internal audio connector, 1 S/PDIF-out connector, 1 connector for IrDA interface, 2 Serial ATA connectors, 1 40-pin IDE connector, 1 floppy connector (FPC type), 1 20-pin ATX power connector, 1 front panel connector, 2 fan connectors, 1 PCI slot for PCI expansion card or customized riser card for 1,2 or 3 PCI slots expansion
  • Lan: Two Marvell 88E8053 PCI Express Gigabit controllers
Jetway J9F2-KHDE
  • CPU: Support Core 2 Duo, Core Duo, Core Solo Mobile Processor, Front Side Bus 667 / 533 Mhz, Package Type: Socket 479m
  • Memory: 2 x Dual Channel 240-pin DIMM Sockets for unbuffered DDR2 667 up to 2GB
  • Chipset: Intel 945GM Express Chipset and ICH7M Chipset
  • I/O: 1 x 32-bit PCI slot, 1 x Mini PCI, 2 x High Speed USB Connectors @ 480 M-bit / s for 4 USB 2.0 Ports, 1 x CPU Smart Fan Connector, 2 x DC Fan Connectors, 1 x CD / AUX Audio in & SPEAK Out, 1 x HDTV Output Connector, 1 x LVDS Connector, 1 x LVDS Inverter Connector, 1 x IEEE1394 Connector, 1 x PS/2 connector for Keyboard and Mouse, 1 x DVI-D Port, 1 x D-sub 15-pin VGA Connector, 1 x HDMI Port,2 x RJ45 Connector and 2 xSerial COM Ports, 1 x Mic-In connector, 1 x Audio input connector, 1 Audio Output connector.
  • Lan: Dual REALTEK RTL8111B 10 / 100 / 1000 PCI-E LAN
  • Audio: REALTEK ALC 888 6-Channel HD Audio CODEC
Jetway J9F2-DExtreme
  • I/O: 1 x 32-bit PCI slot, 1 x Mini PCI, 1 x Mini PCI Express x1 Slot, 2 x High Speed USB Connectors @ 480 M-bit / s for 4 USB 2.0 Ports, 1 x CPU Smart Fan Connector, 2 x DC Fan Connectors, 1 x CD / AUX Audio in & SPEAK Out, 1 x HDTV Output Connector, 1 x LVDS Connector, 1 x LVDS Inverter Connector, 1 x IEEE1394 Connector, 1 x PS/2 connector for Keyboard and Mouse, 1 x IrDA (CIR) (Need to purchase optional IR Receiver and Remote Control), 1 x DVI-D Port, 1 x D-sub 15-pin VGA Connector, 1 x HDMI Port, 2 x RJ45 Connector and 2 x Serial COM Ports, 1 x Mic-In connector, 1 x Audio input connector, 1 Audio Output connector.
Jan Bennett
Old 07-26-2007, 03:45 PM   #4
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
iGoLogic i3899
Axiomtek SBC86831
Portwell WADE-8056
LianTec ITX-6965 (Santa Rosa Platform)
LianTec ITX-6945
Advantec AIMB-253L
Defiler is offline   Reply With Quote
Old 07-26-2007, 05:57 PM   #5
_
Thanks Defiler. I'm going to watch Joe Rogan at the Improv tonight so I won't be able to update the list till tomorrow, but I'll do it tomorrow for sure!
Jan Bennett
Old 07-27-2007, 10:38 AM   #6
_
Quote: Originally Posted by Defiler View Post
Portwell actually has a number of boards. They also have a few that support the Core 2 Quad processors.
I'll add all of these to the list as well.
Jan Bennett
Old 07-27-2007, 11:23 AM   #7
_
ok - all listed by defiler (and then some) added.
Anyone else?
Jan Bennett
Old 07-27-2007, 02:04 PM   #8
Raw Wave
Defiler's Avatar
You might want to add to the LianTec boards about the "Tiny-Bus Modular Expansion Solution".
If you scroll down the page and look at the expantion cards, they have some pretty cool solutions including DC PSUs, Dual Mini-PCI Type-IIIA/B, and PCMCIA Modules, etc.
Old 07-27-2007, 05:10 PM   #9
Zoltan's Avatar
Zoltan is on a distinguished road
Itox G5C100-N-G
It doesn't specifically say Core 2, but I can confirm it works.
I'm running this board w/ a Core 2 Duo Mobile T5500.
'03 Escape 4WD:
-iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
-Transflective 8.4"
-XM, iG4, OBD-II (BR-3)
-Rearview camera with auto-switching (modified cheesbox)
-Slim Slot DVD+RW
-RR, DFX 4
Zoltan is offline   Reply With Quote
Old 08-02-2007, 07:53 PM   #10
AXm77 is on a distinguished road
DFI-ACP:
CT132-BR
CT132-B
G5C100-N
AXm77 is offline   Reply With Quote
Old 08-02-2007, 10:09 PM   #11
_
Quote: Originally Posted by Zoltan View Post
Quote: Originally Posted by AXm77 View Post
These appear to be the same boards, no?
DFI boards and other IEI boards added.
Jan Bennett
Old 08-04-2007, 10:01 AM   #12
_
Jetway boards added.
Jan Bennett
Old 08-04-2007, 11:11 AM   #13
_
Images added for boards where I could find images.
Jan Bennett
Old 08-04-2007, 11:47 AM   #14
_
updated to include PDF links where they existed.
Jan Bennett
Old 08-06-2007, 11:47 AM   #15
_
stuck!
Jan Bennett
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 03:24 AM
mac mini core solo enough for bootcamp? replicant MacCar 6 06-27-2006 12:49 AM
Please read naked girls and Looking for good info on commell P4 itx and via boards. 8675309 Newbie 7 07-19-2005 06:24 PM
MINI atx or Itx JDTUNER General Hardware Discussion 1 06-01-2005 11:31 PM
Where to Purchase Jetway ITX boards? SuperMatty Classified Archive 10 05-26-2003 12:21 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
