The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 08-05-2007, 10:36 AM   #31
knightmare007's Avatar
Vehicle: 2005 Subaru Legacy Limited
My Photos: (0)
Quote: Originally Posted by greatwhite View Post
A higher output amp is not really required on most stock to mild systems. It is nice to have a higher amp alt if you do a fair bit of traffic driving though. Not because it has a higher peak output, but because it produces more power at lower rpms.
And if the alt dies after "the big 3", it will be because it's on the way out anyways, not because of the improvement in the wiring.
But a bad alt will take out a battery. However, it doesn't "kill" the battery, it lets it die. The battery stays in a state of discharge as the alt can't bring it back to full charge, the plates sulfate, and the battery dies a slow and painful death.
Batteries need to be kept in a state of full, or near full, charge to get the full service life out of them.
Cheers
thats what i figured
Thanks, the ubernoob
knightmare007 is offline   Reply With Quote
Sponsored Links
Old 08-05-2007, 10:41 AM   #32
My Photos: (0)
Quote: Originally Posted by rijndael View Post
so what you're saying is that "The Big 3" upgrade will negate a need for a new alt or re-spun alt with a powerful sound system? did i catch that right?
i dont think so, prob just that its rare that the alt needs to be upgraded, you really really need to be using alot of power to require an alt upgrade.
id say that if you do the big three, and your lights still dim, then your prob going to need one soon.
the reason they were dimming before is becuase the alt couldnt feed the amp fast enough through the thin wires it had until it hit the 4 gauge at the batt, so the batt had to do the charging which drops the voltage down form like 14 to 12 so the lights dim, now that there is equal wire gauge from the amp to tbe batt and then the batt to the alt, the amp can just take it from the alt and the batt doesnt get involved, so the lights stay at 14 v.
if the alt wasnt up to snuff, you could add wire all day, and the amp will still have to jump on the batt reserve power because the alt cant give the amp what it needs and so your lights dim again as the voltage drops from the normal 14v to the now batt provided 12v.
Sponsored Links
vB code is On
Trackbacks are Off
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 11:28 AM
For Sale for all you aussies. Complete mp3 car pc Holden__V8 Classified Archive 20 04-09-2005 05:30 AM
PC audio too low Alphared General Hardware Discussion 4 11-17-2003 06:59 PM
FS: HP iPAQ Pocket PC h1910 w/ Stereo Earpiece astral Classified Archive 0 08-03-2003 01:18 PM
How to hook up PC to stereo... Telek General Hardware Discussion 11 10-28-2002 09:23 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
