The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 08-01-2007, 02:28 PM   #1
Moneyfink's CarPC Specs
Moneyfink's Avatar
Vehicle: 2004 Infiniti G35 Coupe
My Photos: (93)
Dual hard drives
I have a working car computer, its been running very well for just over 2 years. Currently I have a 320 GB hard drive in the system, and its full! I am wondering how dumb it would be to add a second hard drive into the system.
My options:
1) keep the 320 and add a 500 GB as well
2) Replace the 320 with dual 500 gb
3) Replace the 320 with a single 500 GB drive
4) be smart and leave everything as is
My thoughts are, dual drives create many more possibilities for errors in an already unstable environment.
I don't want to go with just a larger drive because, i have much more data than would fit on a single 500 GB drive
High data density drives are more likely to fail.
high density drives create more heat
Single platter drives are the most reliable and coolest
a single 750 or 1TB drive is too expensive / hot and can have up to 4 platter internally
Has anyone done anything like this? are there things that I haven't considered? Advice?
I guess 53,000 songs, 1500 tv shows and 250 movies is overkill?
My OLD carputer page
My NEW carPC
Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
Moneyfink is offline   Reply With Quote
Sponsored Links
Old 08-01-2007, 03:34 PM   #2
the415's CarPC Specs
the415's Avatar
Vehicle: 2005 Mazda 3
My Photos: (0)
I'm using 2 hard drives in my carputer. Although I haven't actually run it in the car (damn m2-atx was DOA), I don't see why a 2nd hard drive should create any further problems. Especially if it's purely for storage.
2005 Mazda 3 Hatch
TWM | Cosworth | HKS | AutoExe | Rev | Kumho | Tein | AWR | EBC
Carputer Specs: 98% Completed
Dell Optiplex GX270
P4 2.6GHz
120GB 2.5" HDD
512MB RAM
DS-ATX
BU-353 GPS
XM Direct Universal Tuner
7" Xenarc 700TSV
the415 is offline   Reply With Quote
Old 08-01-2007, 05:01 PM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
The major issue with multiple hard drives would be power consumption.
If power consumption could possibly be an issue, then go with a single physical drive.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 08-01-2007, 07:11 PM   #4
Moneyfink's Avatar
My Photos: (93)
Does the power consumption on these large capacity drives differ much from the power calculators available on this site? I mean if you hold a 500 gb in one hand and a 120 gb in the other there is a VERY signifcant weight difference, the heavier platters have to use more energy? Does anyone have any figures?
My NEW carPC
Old 08-01-2007, 07:17 PM   #5
nammertat's CarPC Specs
nammertat's Avatar
My Photos: (0)
I'm an overkill guy myself, and run one internal 250 maxtor as well as one external drive. I'm a big advocator for the external, because it makes everything easier to transfer files. Also with the help of an inverter, you can put as large of drive in as you want!
nammertat is offline   Reply With Quote
Old 08-01-2007, 07:28 PM   #6
Vehicle: '95 Eclipse GSX
My Photos: (0)
Personally, I would clean out some of the TV shows and movies, not like you can really watch them while driving
As far as the drives we us the laptop drives which use less power and produce less heat, though one on USB as a removable and be done with it. when that one fills up, upgrade to a larger one.... USB disks are growing fast in size, I just saw a 20G usb disk!!! maybe wait till they hit the half TB and use one of them
'95 Mitsubishi Eclipse GSX
CarPuter [Under Development]
EQNish is offline   Reply With Quote
Old 08-02-2007, 02:16 AM   #7
My Photos: (0)
I'd go external. How do you even transfer your stuff from you desktop to your car? I guess you could do it through a network, but that seems like it would be annoying and take forever.
elimenohpee is offline   Reply With Quote
Old 08-02-2007, 05:17 AM   #8
My Photos: (26)
Typically hard drives all draw roughly the same amount of power. The major factor in power draw is spindle speed.
Considering most desktop HDDs are 7200rpm anymore... A 500GB drive would draw about the same amount of power as an 80GB drive.
However, two drives would draw twice as much power. If you're close to the edge of your power consumption limit, then go with the single, larger drive, plain and simple.
Wifi, baby.
If transferring across a network is slow for you, then there's something wrong. Granted, moving a 2GB movie file is gonna take a while, but there's nothing you can do about that.
My Worklog
Old 08-03-2007, 10:33 PM   #9
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
Yeah the major difference between different hard drive sizes of the same form factor is data density (and number of platters). But all in all they take the same amount of power. A physically smaller hard drive (2.5" vs. 3.5") requires less power to spin the platters.
Darque: Do you use network attached storage for wifi? I never considered that. Wires wires everywhere.
crooper is offline   Reply With Quote
Old 08-05-2007, 05:14 PM   #10
gokee2's CarPC Specs
gokee2's Avatar
Vehicle: 2001 Infiniti I 30
My Photos: (1)
moneyfink,
I personally recommend option 1. lol I just got a hold of mo-co-so 's casing, quite similar to vroom 2. Just like the vroom, only support 2.5". Bro, I would too if I could use 3.5" HDD. men, my music video collection is 1/2 TB. lol and im stuck with only 120gb in the car. So, im saying if you can accomodate per power consumption and space, do #1.
my $0.02 Good luck bro.
gokee2 is offline   Reply With Quote
Sponsored Links
Old 08-05-2007, 06:37 PM   #11
My Photos: (26)
You're adding layers of complexity that don't need to be there, methinks.
I have my server in the house with a share for my music. I use WiFi in the truck to transfer music.
Nice & simple.
My Worklog
Old 08-05-2007, 07:05 PM   #12
myzhi's Avatar
Vehicle: 06 Nissan 350Z
My Photos: (0)
1) If you have plenty of power, go with 2 HDD.
2) If getting close to max power, go with 1 HDD.
3) Delete stuff. Out of 53,000 songs, 1500 tv shows and 250 movies, how many of them do you actually access? I am betting <10%.
CAR:06 350Z | LCD:Xenarc 700TSV | PS:M2-ATX | CPU:2.0GHz Turion 64 | MB:GA-K8N51GMF | RAM:1GB PC3500 DDR | HDD:WD 250GB SATA | USB1:Zoom 140M WiFi | USB2:iOne Scorpius Keyboard | USB3:Logitech Wingman | SERIAL:GPS BR-355
myzhi is offline   Reply With Quote
Old 08-05-2007, 07:20 PM   #13
maxgtr2000's CarPC Specs
maxgtr2000's Avatar
My Photos: (1)
It's funny, when I got my desktop it came with a 200gb hdd. i thought I'd never fill it up. 2 years later I only have about 30 gbs left. I plan on putting movies which seem to take up the most space (almost 1 gb a flick) on dvds, 4-5 movies on 1 dvd will free up a little. You can also try and get the highest memory flash card an go with a flash drive for mp3s only. just a thought.
maxgtr2000 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Hard drive shock / vibration thoughts S11D336B General Hardware Discussion 60 09-26-2006 11:40 PM
New hard drives for cars from Hitachi Magician General Hardware Discussion 23 09-06-2006 01:24 PM
(UK based) For Sale: 2x 2.5" notebook hard drives SamDude Classified Archive 2 03-25-2005 11:04 AM
Cheap external hard drives FishPony Off Topic 6 03-07-2005 05:27 PM
Cheap laptop hard drives baef Classified Archive 17 03-02-2005 05:52 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
