The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 08-05-2007, 11:00 PM   #1
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
FSB vs. Memory speed
I have my AMD Barton underclocked by lowering the FSB speed from 400 to 266. Does this affect the memory access speed? Or is the memory speed independent of FSB?
crooper is offline   Reply With Quote
Sponsored Links
Old 08-05-2007, 11:18 PM   #2
myzhi's Avatar
Vehicle: 06 Nissan 350Z
My Photos: (0)
Usually, FSB controls memory speed. From little info you provide, guessing you are using DDR ram which means 400/2 = 200 mhz ram. Since you are underclocking, your ram will be running 266/2 = 133 mhz.
CAR:06 350Z | LCD:Xenarc 700TSV | PS:M2-ATX | CPU:2.0GHz Turion 64 | MB:GA-K8N51GMF | RAM:1GB PC3500 DDR | HDD:WD 250GB SATA | USB1:Zoom 140M WiFi | USB2:iOne Scorpius Keyboard | USB3:Logitech Wingman | SERIAL:GPS BR-355
myzhi is offline   Reply With Quote
Old 08-06-2007, 02:26 AM   #3
crooper's Avatar
My Photos: (0)
Yes that's what I meant. 200x11 = 2.2 gHz to 133x11 = 1.4 gHz underclock. I couldn't figure out how to unlock the multiplier so I did it that way.
Sponsored Links
vB code is On
Trackbacks are Off
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 80 07-16-2008 12:42 PM
Software that write GPS speed to TXT file? der_mof GPS 1 06-22-2007 12:44 PM
StreetDeck pegs the CPU and System Memory UV7 StreetDeck Bug Reports 3 05-31-2007 11:03 PM
Core Duo/Core 2 Duo processors RedGTiVR6 General Hardware Discussion 42 02-06-2007 08:00 PM
Feature request: speed camera notifications based on current speed surfatwork Map Monkey 2 08-31-2005 06:01 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
