03-14-2008, 09:09 PM
#31
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
03-14-2008, 09:34 PM
#32
Quote: Originally Posted by LinuxRacr
I would try setting the line for Sirius to the one you have it plugged into, if you audio is not working as it should be muted when not being used. Just my thoughts on your config.
2004 Sport Trac PC Project.
03-14-2008, 10:09 PM
#33
It works now. Turns out that's all it was. I needed to have the Line for Sirius Audio set for SPDIF IN. Thanks for your help.
Current build! Here
03-14-2008, 10:16 PM
#34
Your welcome
03-15-2008, 10:50 PM
#35
I have a new issue now. My computer keeps crashing with this going after about 15-20 minutes..
Current build! Here
03-17-2008, 01:01 AM
#36
linuxracr, make sure RR version is up to date!!
also make sure u have the latest USB drivers for siralp interface
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
06-03-2008, 08:07 PM
#37
Ok,
I went dormant for a while on this, but I am wanting to get RR working correctly, so I can actually use it. I went and got the new drivers, how do I install them? Looking for the answer, but not found..
Current build! Here
06-04-2008, 07:02 AM
#38
You install them through the device manager. The device will be listed under "ports (com & lpt)". Right click, select properties, got to the driver tab, select the update driver button, and then select Install from a specific location, etc.
06-04-2008, 09:01 AM
#39
I figured it out last night. It told me that I already had the latest driver for my device. I must have installed it a few months back, and forgot, because I have version 2.
I'm happy to report that this morning on the drive into work, I had no crashes, and good tunes from Sirius.
Current build! Here
06-12-2008, 01:10 PM
#40
Ok, I crashed again last night while listening to Sirius, using the DigitalFX 3.0 skin. I'll try to re-create the issue later. What do you think it may be?
Current build! Here
06-13-2008, 06:57 AM
#41
Mine has never crashed ever, so I have no clue.
06-17-2008, 08:35 PM
#42
Haven't had anymore crashes. May have been a jumping voltage thing due to a frayed wired I fixed today.
Current build! Here
| Thread Tools |
| Display Modes |
Linear Mode
