Thanks for your input.
What I ended up doing was cutting a couple of holes in the plastic around the center console under the din radio unit and hvac controls. I placed two switches. A momentary push button for the pc's power, aswell as a rocker switch for the 12volt power. I ran one ground from the lighters port directly to a 1light adapter to 2 Y splitter. Next I ran a power wire from the lighters power line to the rocker switch, then to a 10amp fuse to the Y splitter. I cut the second adapter off of the Y splitter and soldered it to the pc's power supply. Then I use the adapter slot for the cigarette lighter socket power of the lcd touch screen monitor.
So now basically I throw the rocker switch to ON and my lcd screen comes on and my PC's PSU gains power... hit the push button to power on the pc and in about 15 seconds I have Centrafuse running
My only complaints at this point is the limited amount of space naturally. The fact that I have to use the AUX audio input on my factory DIN stereo. I have no idea where to mount the monitor. And at somepoint I killed the other cigarette lighter slot. No fuses are blown, and I checked it with a multi-meter... no power... *yikes*
Anyone know if this has voided the warranty on my 2007 Cobalt? I'll get some screen shots up soon to show you guys, I think this isnt a half bad installation(atleast for the mother board)
-Scott
