The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 09-28-2007, 09:37 PM   #1
0okami's CarPC Specs
0okami's Avatar
Vehicle: 2001 Mitsubishi Eclipse Spyder GT
My Photos: (0)
carry case for carputer / fan placements sugestions? / work in progress...
So, i decided to re-do my carputer setup...
I want something that i can take out of the car quickly. Weatherized to prevent stray rain drops / snow flakes but with good control over temp.
im planning on adding a thermostat switch of some sort to activate or shut off fans if temp falls over/below a certain threshold.
More info coming later.
for now im wanting opinions of the subject. ^_^
At open air, the the temps are currently at
CPU 95F.
mobo 85F.
Asus P5L-MX
CPU: intel e4300 duo core 1.8ghz.
2gb ram.
...dont ask why.
~0okami.Digital
Anime. that's my excuse. What's yours?
2001 Mitsu Eclipse Spyder GT http://ookami.n2-network.com/
MSN Messenger and Gmail: ookami.digital@gmail.com
0okami is offline   Reply With Quote
Sponsored Links
Old 09-28-2007, 09:48 PM   #2
Phatsacks's CarPC Specs
Phatsacks's Avatar
Vehicle: 2007 Corolla S
My Photos: (0)
What case is that?
Phatsacks is offline   Reply With Quote
Old 09-28-2007, 10:30 PM   #3
0okami's Avatar
My Photos: (0)
some cheap case i found at the local walmart in the gun / pistol / riffle section.
Camo ridge Model WM01149
~0okami.Digital
Old 09-28-2007, 10:39 PM   #4
Phatsacks's Avatar
My Photos: (0)
how do you plan to secure it so it doesn't slide in your car?
Old 09-28-2007, 10:46 PM   #5
0okami's Avatar
My Photos: (0)
velcro. on the underside of the case / Stands. (rough part of velcro sticks ANYWHERE in the trunk of my car) its as if the whole thing came from factory with velcro. ^_^
~0okami.Digital
Old 09-28-2007, 10:48 PM   #6
0okami's Avatar
My Photos: (0)
i decided on setting the second fan over near where the chipset heatsink would be.
~0okami.Digital
Old 09-28-2007, 11:09 PM   #7
Phatsacks's Avatar
My Photos: (0)
So is the the chipset is an intake, and the cpu one is exhaust?
Old 09-29-2007, 12:15 AM   #8
0okami's Avatar
My Photos: (0)
the other way around.
~0okami.Digital
Old 09-29-2007, 03:27 AM   #9
My Photos: (0)
pun intended, lol
ironfinger is offline   Reply With Quote
Old 09-29-2007, 05:46 AM   #10
DodgeCummins's CarPC Specs
DodgeCummins's Avatar
Vehicle: 96 Dodge Ram 2500 Cummins Diesel (turned up)
My Photos: (20)
For the record...I didn't run any fans on my mini-itx board...but yours I am sure is quite a bit hotter. I think you have the right idea...just watch the temps while you are testing it out....
My home computer runs at 50C for comparison.
...I got that same case at Walmart...it is labeled as a pistol case...
There is a foam piece that fits in between the one in the lid, and the one at the bottom...it is cut in small cubes, so you can make custom cutouts for all your gear. I have 2 small camcorders and all their accessories in it, each piece in its own little compartment...as opposed to before when they were all thrown in the bottom of the backpack.
current projects
DodgeCummins is offline   Reply With Quote
Sponsored Links
Old 09-29-2007, 11:41 AM   #11
Phatsacks's Avatar
My Photos: (0)
At open air, his is cooler than your's.
I'm betting with both fans, that it will remain the same temps (in doors at least).
Old 09-30-2007, 10:38 PM   #12
0okami's Avatar
My Photos: (0)
update! gun-Case carputer.
update! it is somewhat done... now I just need to get it out to the car and set proper wiring for the power and such.
air flow is great! i have not seen CPU go above 120F as of yet. I have been playing full screen video 1280x720 divx within Centrafuse front end. CPU usage is around 8% most of the time.
Temps average: (asus seems to have them backwards? ...)
Closed case - CPU 116F / mobo 88F
open case - CPU 118 / mobo 90F
Looking good so far... ^_^ I go put it in the car after work tomorow.
...forgot to mention, the cpu's heatsink+fan are held down bolted gently and slip prevention in place. I did away with the push pins. more info on that later.
~0okami.Digital
Old 09-30-2007, 10:47 PM   #13
Phatsacks's Avatar
My Photos: (0)
So you added a 3rd fan? Is that an intake to blow air across a bridge and ram? It's what it looks like in the pic.
Edit:
Never mind, I saw in the earlier pics, you have that hole there as well (no fan in it).
Old 09-30-2007, 10:54 PM   #14
0okami's Avatar
My Photos: (0)
ah yeah that hole is in the back for the wires. ^_^
~0okami.Digital
Old 03-29-2008, 07:56 PM   #15
0okami's Avatar
My Photos: (0)
yay new gps arrived. Holux GPSlim236 loving it. By the time the carputer is booted, a fix is locked and everything is ready to go.
~0okami.Digital
Sponsored Links
vB code is On
Trackbacks are Off
FS / Carputer in lexan custom case. NDelMoore Classified Archive 31 11-28-2004 11:49 PM
My work in progress carputer case kmkestell Fabrication 12 06-20-2004 09:54 PM
Consider not building a case for Carputer antimatter Fabrication 6 05-20-2004 12:00 AM
Built me a new carputer case (See pictures) Bergetun General Hardware Discussion 10 04-14-2004 09:18 AM
mini-itx carputer any case ideas??? acornstu General Hardware Discussion 6 11-04-2003 03:18 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
