Sata connectors are the same 7 pin thick flat cables regardless of whether you are using it with a 2.5", 3.5", or an optical drive. The standard power connector is the same 15 pin cable for each as well. Your mobo won't care what size the drive is.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
