Quote:
Can you explain a little why that would help much? As I said when the car is off the whole system is fine. only when the engine is running I get interference
Many cars are built cheap so they'll use the minimum thickness wire for every element. Adding a car stero + carputer creates a significant amount more current draw than the factory wiring was designed for.
As you "overload" the wiring you experience voltage drops. As the voltage drops your alternator works harder. I won't pretend to know why a stressed electrical system is more prone to noise, but it happens and I've solved many audiable wine issues through good grounding practises (that includes upgrades of major factory grounds) and is something I'd recomend to everyone getting a stero system installed practises.
Quote:
I can only think of bad grounding but I have tried several ground points in the boot of the car yet all give me the same result.
Your boot groundings may well be fine (I presume your using suitable large cable, sanded back the paint and used a solid bolt point). It may well be your battery to chassis gorund or alternator to chassis gorud that the issue.
Quote:
And if bad ground is the case wouldnt there be interferance when the car is off also? but I only get interference when the car is on.
Poor grounding doesn't tend to be as noticeable with the car off as there are less electical devices operating, and there's no alternator running.
