Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Notices
Old 12-09-2007, 04:23 PM   #1
speedycheater's Avatar
M-Audio Fast Track Pro: 2.1 Output Possible?
I'm looking at options for a USB external card for my M10000-based CarPC.
Originally, I had planned to use an external 5.1 card. I realized that this was overkill for what I need, since all audio I will be playing is only recorded in stereo (MP3's/Lossless formats). The only advantage I can see for a 5.1 card would be control over fade from the computer. Not a big issue.
My next thought was just to use a M-Audio Fast Track card, with two output channels, and let my amps (MB Quart Premium series) handle the crossover points. With this setup I would lose the ability to control the subwoofer level from the computer (which I would like to be able to do).
My option now is a M-audio Fast Track Pro card, with 4 output channels. I'd like to use channels 1 & 2 for stereo output to the front and rear speakers, then use channel 3 as a mono output to the subwoofer (the high-pass filter on the amp could still be used).
Here's my question. Is it possible to independently control the volume or level of channel 3 from the PC with this setup?
Thanks for the help.
<--- My other car
speedycheater is offline   Reply With Quote
Old 12-10-2007, 01:09 PM   #2
Nobody?
<--- My other car
Old 12-10-2007, 02:07 PM   #3
I tried this setup a month or so ago. I only tired it for a few because it was not exactly what I was looking for. While I was testing, the hardware pretty much took over the volume and I was unable to control the volume through the pc. Now I would be willing to bet with a minimal amount of work, there would be a way to use the pc.
On a side note, if you want to try it, I have the unit and it has only been plugged in for an hour or so. If you want, make me an offer as I have no use for it.
dettlej is offline   Reply With Quote
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
Music track fast forward bug Bootbox CF Bug Reports 4 12-06-2004 11:22 AM
