The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 12-10-2007, 08:01 PM   #1
My Photos: (0)
New Plan--New MB, Used HD
I'm narrowing down what I want/need to purchase. I'm now thinking that can get a new via MB (MII12000) and pulling the hard drive from a spare PC that I have.
I'm seriously considering mounting the MB, HD etc on a piece of plexi and then mount the plexi on my TBlazer's frame. My thought is to remove the large trim panels in the back and fabricate (with fiberglass) to go over the PC. The new panels would be covered by carpet to match the existing.
Is there anything that I should be concerned about that might suggest changing this plan?
The other possibility is to go ahead and get a small form factor case. There MAY be room under the back seat. I'll have to look tomorrow (sorry I just now thought of this possibility as I started to post this).
doni49 is offline   Reply With Quote
Sponsored Links
Old 12-10-2007, 08:52 PM   #2
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
it doesn't seem worth it to go to all that trouble just for the motherboard.
for an extra hundred bucks you could get this, takes all of 5 mins to assemble and is small enough to fit under almost any seat, in a glove box, or in the dashboard (behind your monitor).
FusionFanatic is offline   Reply With Quote
Old 12-10-2007, 09:34 PM   #3
My Photos: (0)
Yes--I was just looking at the size of one of them. They're a LOT smaller than I realized. Even when I was thinking of buying a new system, I thought I'd have to put it in the back. Then I figured that if I was going to mount it in the back, I'd have to find a way to conceal it. If I was going to do that work anyway, I might as well lose the case.
It just doesn't make sense to spend all that time/money fabricating a new enclosure when I can buy a case for $75.
But now I'm back to using a case.
Sponsored Links
vB code is On
Trackbacks are Off
Someone here has be be able to crack this HDRadio for the car! Kamakazie2 Hardware Development 243 09-20-2007 08:04 PM
Cold Weather may have killed HD Smitty0881 Newbie 30 02-16-2007 01:28 PM
Is this HD failure? matt11601 General Hardware Discussion 8 02-06-2007 04:16 PM
IDE EXTERNAL HD Pt-2 PaCMaYNE General Hardware Discussion 1 01-23-2005 02:43 AM
Why does my HD stops??? nl4jy General Hardware Discussion 1 02-05-2004 10:53 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
