Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Notices
Old 12-22-2007, 08:22 PM   #1
Boot XP off Microdrive?
I have a magicstor 4 gig ata/ide microdrive and I was wondering if this would be ok to boot XP off of. I wanted to use a CF but I read that you can't boot xp off of flash memory. Is this true???
"Who run Barter Town?"
2L_SS is offline   Reply With Quote
Old 12-22-2007, 10:33 PM   #2
No it's not true. Both microdrives and CF can be used to boot XP.
Last i checked microdrives were prety slow though.
pokki is offline   Reply With Quote
Old 12-23-2007, 03:10 AM   #3
How slow is slow? Slower than a regular disk type HDD?
Old 12-23-2007, 03:19 AM   #4
The last time I checked 2gb microdrives were about 1-3rd to 1/2rd the speed of standard HDD (could be wrong) and about 1/4th the speed of the fastest CF.
Old 12-23-2007, 04:56 AM   #5
Raw Wave
Rob Withey's Avatar
Microdrives are really slow, even compared to old laptop drives. I use an 8Gb microdrive for the maps and music storage in my setup.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 12-23-2007, 12:24 PM   #6
I originally wanted to use a CF to boot off of but then I looked at the price. I thought that the Microdrive would be a decent substitute but I don't want something that slow. What about a USB flash drive? Has anyone tried that with XP?
Old 12-23-2007, 02:36 PM   #7
USB flash drive requires bios support to boot.
Where as CF in an IDE adapter is supported by all PCs.
I'll be surprised if going the USB route saves you more than $10 over the CF card route when buying similar speed products.
As a rough guide i'd estimate drive speeds as follows:
266x CF = 40 MB/sec
150x CF = 25 MB/ec
7200 RPM hdd 25 MB/sec
5400 RPM hdd 18 MB/sec
Microdive 10MB/sec
Speeds will vary between manufacturers so check before you buy anything.
Old 12-23-2007, 05:02 PM   #8
I think I may have go with the normal style hdd. The speed of the CF would be great but my budget says no. How would a 10,000-15,000 rpm hdd compare to the 266 CF?
Old 12-23-2007, 05:30 PM   #9
SFiorito's Avatar
I've used USB flash storage...prior to the new UDMA CF drives it was the best, but the configuration issues aren't worth it compared to these new drives.
SFiorito is offline   Reply With Quote
Old 12-23-2007, 06:46 PM   #10
Will any CF card work as a HDD? I found this one here, thats a lot cheaper than the other ones I saw.
Old 12-23-2007, 11:02 PM   #11
SFiorito's Avatar
you'll want a CF card that supports UDMA. you'll have to do some research on these forums for more details of compatibility and installation issues.
Old 12-25-2007, 07:39 PM   #12
Prety close, but be aware high RPM HDDs consume more power than slower HDDs.
Yes I believe any card will work, but per the above for best/acceptable preformace you want one that supports UDMA mode.
That Adata one is prety slow. Adata's line is:
Speedy - slowest
Super - medium speed (80x)
Turbo - fastest (120x - 266x)
Old 12-25-2007, 09:02 PM   #13
Thanks for all the help, I think I may just go the easy rout and stick with a regular disk type HDD. The CF sounds like it could be a lot faster/durable but this is my first carputer, and I don't want to get in over my head. :-P
Old 12-25-2007, 11:23 PM   #14
Good choice.
I'd recomend installing your OS/applications on a small partition (2 or 4GB), and use the rest of the space partioined off as a drive for storing media. This is so if/when you make the swicth to CF for your OS, you should be able to simply clone the partition and be up and running again with minimal downtime.
Old 12-30-2007, 07:24 PM   #15
My seagate st1 8GB drive has a sustained rate of 8MB/sec. I boot from hibernate from a litely trimed version (nlite) of XP-SP2 in 30sec. Not bad....my 2.5 seagate 100GB 5400rpm boots from hibernate in 25sec.
AcuraTLFan is offline   Reply With Quote
Thin Client setup help. How to boot over LAN? 2k1Toaster Software & Software Development 0 08-16-2006 02:37 AM
Run WinCE & XP together ShawJohn Software & Software Development 12 11-07-2005 06:09 PM
Windows XP boot on CF card Uconnputer General Hardware Discussion 2 12-14-2004 07:43 PM
windows xp scandisk at boot Alives Software & Software Development 0 05-24-2003 12:39 AM
boot times with XP Alives General Hardware Discussion 2 11-15-2001 01:42 PM
