The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 12-31-2007, 03:37 PM   #1
My Photos: (0)
Question Custom USB/Firewire Mounting
I decided NOT to put this in fabrication, as I'm not looking for 'that' customized of a solution, but one that allows me to mount a USB and/or Firewire (Female) into my ashtray so I can get that 'on-the-go' type of file-sharing, ipod-connecting, whatever without having to go to the trunk.
The only problem is I've spent several hours on several different occasions trying to find a solution that allows me to simply cut-out (drill) a precise hole and 'plug' in an adapter to give it that flush-mount feeling while still looking natual and professional.
I have an '02 325Ci and I think this would be a great addition to my CarPC -- having it mounted in the ash-tray.
The problem is I can't seem to find what I want -- has anyone done this, or know what keywords I should be using to find such items?
I've searched for:
USB, Firewire, Resessed, Flush Mount, Panel Mount, DIY, Housing, Mounting
I'm at the point now where I think it may just be simpler to litterally do this from scratch -- buying the raw USB/Firewire hardware, running wire, saudering, etc... but I just feel that there has to be something that can 'click' into place.
I would prefer the item be a Femail connector, with a standard male tail on it so I can plug it (them) into a hub behind my monitor, get it's power and be done. But something tells me I'm going to have to run it back to an internal motherboard attachment...
Am I alone here?
house98 is offline   Reply With Quote
Sponsored Links
Old 12-31-2007, 04:41 PM   #2
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
I've seen a bunch of threads here. I think frontx was mentioned a few times.
Here's another one: http://www.datapro.net/products/usb-...all-plate.html
You can always chop up the plates and paint.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 12-31-2007, 06:32 PM   #3
My Photos: (0)
I've traveled all over that site and for some (stupid/idiotic) reason I didn't find that particular one -- or if I did, I dismissed it because of the 'screws'...
Either way, that should workd, provided I have a thin mount, and possibly super-glue it to the back. :-)
Thanks for the heads up. And, if someone else knows of something more specific to a 'plug-in' option as I mentioned, please feel free.
Thanks again Curiosity.
Old 01-01-2008, 02:56 PM   #4
Strgazr's CarPC Specs
Strgazr's Avatar
Vehicle: 2004 Honda Element
My Photos: (0)
You might also look at Frontx as mentioned above. I ordered some of their parts to do the same thing in my glovebox. Looks very stock. http://www.frontx.com
Strgazr is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Advice Request: Mounting components in my Custom Carputer Box long.1 Fabrication 9 07-09-2007 12:25 PM
mounting a gps system (Custom fiber glass mount) killians31 Fabrication 1 11-16-2006 05:40 AM
Mounting Xenarc 700TSV in custom bezel blackflux Fabrication 28 09-11-2005 07:13 PM
Xenarc 700TSV / custom e46 bezel mounting zaid175 Fabrication 1 06-13-2005 06:05 AM
Mounting hardware in a custom case. Amateur night. Bailey Fabrication 5 05-09-2005 11:09 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
