Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-05-2008, 10:52 AM   #31
-zip-'s Avatar
-zip- is on a distinguished road
http://crave.cnet.com/8301-1_105-9824874-1.html
Waiting on the 80GB version, Toshiba has announced ETA March 2008.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 01-05-2008, 04:50 PM   #32
greatwhite's Avatar
greatwhite is an unknown quantity at this point
70g of useable space is no good either. I'm just over 80g as it stands now (got alot of stuff on there, yes, it's backed up).
Thanks anyways.
Cheers
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 01-05-2008, 04:55 PM   #33
Lithoss is an unknown quantity at this point
Thanks anyways.
Cheers
but since its a small 2.5" laptop style drive, you could easily fit 2 in there. maybe? either way, i can, and i'll be watching for this HDD's release
Lithoss is offline   Reply With Quote
Old 01-05-2008, 05:00 PM   #34
greatwhite's Avatar
Sure, that's an option. Albiet, an expensive one.................
Leonardo Da Vinci
Old 01-05-2008, 09:53 PM   #35
Scruit
How about a thermostatically controlled CCTV Camera Heater? Maplin has one - turns on at 5c, off at 16c, I think. Draw is 13w while it's heating. If the heater is left to cycle constantly then the device temp never gets low enough to worry about thermal shock form sudden rewarming.
Or how about... Adding a thermostaically controlled relay that will turn on your CarPC when the temp gets to the bottom end of the operating temp, then off again when the CarPC naturally warms itself up.
I'm experimenting with this for the DVR in for my Dashcam - the DVR will keep itself warm while it's running, but it has a built-in cold-protection that will not try to spin up the HD below 0c (even if you have a HD rated for -30 ). The DVR has a home-made power controller that is triggered by the ignition turning on, something bumping the car or someone opening a door/hood/trunk. I can easily add a thermostat that turns on at --1C and off at +3C, for example. The plan is that DVR will them fire up and warm itself up again and then shut down.
Tmep never really gets below 10F here - usually high teens is the coldest we get.
Scruit is offline   Reply With Quote
Old 01-13-2008, 05:52 AM   #36
toyotatyrant's Avatar
toyotatyrant is an unknown quantity at this point
Try one of these. http://www.jcwhitney.com/autoparts/I...D:100000220256 They are used to defrost windshields when the car heater is not yet warm due to cold weather conditions. It might do the trick and I am sure they can easily be hacked to be run remotely. And they are dirt cheap.
toyotatyrant is offline   Reply With Quote
Old 01-13-2008, 09:15 AM   #37
jontz's Avatar
jontz is an unknown quantity at this point
That heater from J.C. Whitney is exactly what I was thinking for you cold weather folks. I live in Northern Indiana, so I understand the whole cold weather thing. It seems like the real solution is to buy a heater and install a second deep cycle battery with a isolator. Connect the heater (and your car PC if you like) to the deep cycle and put the heater in your trunk with a thermostat. All you would need to do is keep your trunk at 20-30 degrees. Insulating your trunk lid and walls would definitely help as well. Just a thought...
jontz is offline   Reply With Quote
Old 01-13-2008, 12:28 PM   #38
Crazy_Cabbie is an unknown quantity at this point
Lightbulb Trailer Park Boy Solution - RELIABLE mobile networking
Maybe I'm stating the obvious here, but why not just use a laptop?
I've driven transport a bit, and worn out (newbie) trucks jump around as much as or MORE than riding a horse (from bumps-I can shift). Before these 'toughbooks' and whatnot came out the thinkpads were the only ones that got old enough that the keyboard letters wore off...just a thought...
To maintain seamless integration, run cables from dash-mounted input/peripheral plugs to the docking station that's PERMANANTLY mounted in the trunk (or wherever)...
(Usb cables crap out over 15-25ft depending on the peripheral current draw.)
Then ya can just take it out on extreme weather days (or in seedy neigbourhoods) rather than KILL IT warming and cooling, or loose it with the car...
PLUS you can REMOVE it & hook it up to OTHER computers (mp3players? PVR's?).
(without a 50 foot cat-5 cable from yer car to the server that is, although those are good for fer car-to-car network sharing; make a break-away connector, haha)
In a taxi, you'd want the usb plugs and stuff UNDER the dash, OUT OF SIGHT, so there's no indication of high-value electronics to the criminals ya may commonly drive around...maybe invest in a secondary monochrome screen, haha...
[Keep in mind I'm broke, with a rusty 1994 car, a beat up Thinkpad, a soldering iron and a box of parts...I've got my cell tethered to my laptop, strapped under the dash of a car (or wherever really... internet in a tent always freaks people out, haha) with a mismatched drivetrain and a 'dollar-store bucket' air ram so I can afford to drive it...(36mpg) anyone else usin tethered cell internet, peer-to-peer internet or lan on the road? if we met up to share files imagine the RIAA would send the swat team after us but experiments like wi-fi relaying & stuff would be cool...sorry for the long message it's my first post just wanted to mention what info I might be good for.]
BTW ya need to hack a bit to get decent speed from cell-net.(hosts file, cached/no images, firewall, registry hacks to firewall for stupid auto update etc...)
Crazy_Cabbie is offline   Reply With Quote
Advertisement Sponsored links
Old 01-13-2008, 02:45 PM   #39
nobb will become famous soon enoughnobb will become famous soon enough
Well, my impression was that greatwhite's system actually worked in the cold before his upgrade to the bigger drive. It seems like such a hassle to have to unplug/plug a laptop from the trunk at the end/start of a day. So greatwhite, maybe you can go back to your old system with your old drive as the master? You can always put the new drive in a usb external enclosure and simply take that drive with you indoors when the weather gets cold.
nobb is offline   Reply With Quote
Old 01-13-2008, 03:11 PM   #40
jontz's Avatar
Another thought I had was using a compact flash to IDE adapter with your OS and some MP3s on it. It would give you startup in any weather, and something to listen to until the rest of your computer (hard drive) wakes up. All in all I think the best thing is just to find components that work and stick with them. Maybe we can post a "cold weather parts" sticky of components that are cold weather tried and tested...
Old 01-14-2008, 03:01 PM   #41
Mr_Hobbit is an unknown quantity at this point
How about something like this?
http://www.chromalox.com/products/prodinfo/en/slb.html
I've used this before on jobs where I've had to place LAN equipment in exterior enclosures. If you could combine the "timer" idea and this, it could heat up the components.
Mr_Hobbit is offline   Reply With Quote
Old 01-16-2008, 11:54 PM   #42
Not2Swift's Avatar
Not2Swift is an unknown quantity at this point
Here's my 2 cents.
This is my first winter of having a car computer.
A month or so ago the hard drive wouldn't spin up (too cold).
My solution is: I have to plug in the car so it will start so why not split the plug in cable and use an interior heater.
I don't need the interior to be hot, but warm enough that I'm not doing damage to the computer when it starts.
I put in a simple in car heater, plugged through a "thermo cube"
http://www.smarthome.com/7142.html
Keeps the interior at zero (32F) even through the -30 to -40 days.
Cost is $20 plus the heater and some cord splitters.
works for me. Hope it helps for you.
Cheers
Mike
(Calgary)
Not2Swift is offline   Reply With Quote
Old 01-18-2008, 10:30 AM   #43
Maheriano will become famous soon enoughMaheriano will become famous soon enough
Not2Swift, good to see a fellow member from Calgary! I just moved out of there in August, been running a carputer for 1.5 years in Calgary prior to that.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 01-18-2008, 10:40 AM   #44
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Quote: Originally Posted by TruckinMP3 View Post
-17 C is about 1 F
SNIP
In another thread I was asked how cold my system has booted. The coldest I recall seeing in the morning was an air temp of 9 F (about -13 C) no issues. Mostly i do not look at the temp though.
SNIP
I can now say 1 F or -17 C and my set up still boots. I guess I am lucky. The LCD seems to be fine as well.
** note I am not dismissing cold boot issues, just indicating that some hardware does better than others.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 01-18-2008, 11:56 AM   #45
Lovecraft is an unknown quantity at this point
Hey GreatWhite, I'm in Calgary.
Depending on your enclosure, what about just wrapping a battery blanket around the case and plugging in. Won't get hot enough to damage anything, safe, cheap and 1-2hours on a timer should be more than enough to raise the temp to safe boot levels.
*Edit: I see others have suggested this already:
My other thought was to use one of those 12V heaters that Canadian Tire sells. Like this: http://www.12vheaters.com/?gclid=CNC...FSosagodM0lhGw
To warm the enclosure (faster) or trunk. while the car is warming up in the morning.
Lovecraft is offline   Reply With Quote
M10000 mobo in cold weather (-40C)? Any problems? nobb General Hardware Discussion 2 02-19-2008 07:55 PM
cold weather and my motorized touchscreen. skywise LCD/Display 12 12-12-2006 10:58 PM
Carputer and cold weather... very cold! Topper General MP3Car Discussion 3 07-14-2005 08:41 PM
Anyone else having any issues with Cold weather? bry21317 General Hardware Discussion 21 01-25-2005 10:42 PM
Cold weather +LCD Adragontattoo LCD/Display 4 10-13-2004 11:25 AM
