Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-22-2008, 03:54 PM   #91
rizaydog's Avatar
rizaydog is an unknown quantity at this point
I am starting to have issues with the cold now. Its been getting below frezing hear, and my puter wont boot until I get the cabin warm. I have my laptop mounted in the trunk. For now, I have just been dropping the back seat and letting the heater blow warm air into the trunk. This does take a long time and is kind of anoying. I thought about adding a 12v heater in the trunk that would turn on with the car. However, that is even more draw, and, as others stated, temp shock to the pc. I have been searching for a better HDD for my lappy that is more suitable for in-car use. Still no luck. My second idea was not to shut down the pc, and just leave it in standby all the time. My idea was to add a battery in the trunk. Something small, like a riding lawn mower battery. Then run a wire from my cig lighter (only carries current when car is on) to the battery. Then I could wire the laptops dc power cord to that battery. Then the laptop could stay in standby until the laptops battery, and the aux battery where both drained. Since the ignition is off, it wouldn't be able to draw power from the cars battery.
Im not sure how this will work, or exactly how to wire in the battery. Any thoughts on this would be appreciated.
rizaydog is offline   Reply With Quote
Old 10-22-2008, 04:07 PM   #92
Salmizar's Avatar
Salmizar is an unknown quantity at this point
Hey,
I did the 12v heater thing last year. And it sucked for a few reasons I wont get into here.
The battery in the trunk would be useless. Standby mode is fine, but not all motherboards cut power to the usb devices, and those can drain your battery in a matter of hours. I use stand by, but have to use hibernate in the winter because my battery cannot take it. I have a yellow top optima (deep cycle battery) and I still only get about 48 hours of standby power. The cigarette lighter idea is also no good because of the draw that would be required to charge the battery would probably blow the fuse.
I would recommend getting this http://store.mp3car.com/2_5_inch_Sea..._p/hrd-010.htm Its a automotive HD. I am using it now instead of my Mtron SSD. Its rated down to -30c.
Salmizar is offline   Reply With Quote
Old 10-22-2008, 04:27 PM   #93
rizaydog's Avatar
Thanks. I'll take a look at the drive.
Old 11-15-2008, 12:50 PM   #94
Jeff D.'s Avatar
Jeff D. is on a distinguished road
slower HDD maybe...
How about trying first gen 4500 rpm HDD's. I have one in my system and although I have some minor cold issues it's never been the HDD.
Possibly because the slower spin rates of the older drives make it easier to acheive 4500rpm when cold, rather than the 10,000rpm new hot rod HDD's selling today. Probably when cold it's easier to get to 4500 than to get to 10,000 as far as I can see.
I have a SFF Dell in my trunk. When I apply power to it from a switch on my dash I see the activity light flicker very slowly when extremely cold. At normal temps this flicker described above is so fast you almost don't see it. These SFF Dells have a different type of MB than regular pc's. Seems there is a pre-startup power cycle that happens before you actually boot up, it happens when voltage is applied to the MB, but before the you push the start up button. If I apply power to the Dell and let it sit for a min. or so, then push the start button it boots everytime no issues with cold, at least down to 5 degrees F.
So my issue is not with the HDD but the initial power up of the MB.
2004 Galant & it's about to become something....more.
2004 Galant, 1.8gig P4, 512mb ram (in trunk), 7" indash VGA monitor, Sirius RS232 upgrade, wireless internet, remote start carpc and inverter, 2500+ mp3's.
Jeff D. is offline   Reply With Quote
Old 11-30-2008, 08:40 PM   #95
bemenaker's Avatar
bemenaker is on a distinguished road
Has anyone tried ssd hdd's?
Has anyone tried one of the newer solid state (flash ram) hard drives instead of a rotating platter? This would seem to me to be the ideal situation here. Flash ram shouldn't be effected by the cold and with no moving parts, the viscosity and shrinking clearances become irrelevant. I know they cost a little more but it should solve the problem.
Option two, is boot the system off of USB thumb drives and run it purely off of that. I am currently researching my first carpc, and that is what I had in mind so far. Booting the OS off of a smaller 2 or 4 GB thumb drive, and then having an 80GB or larger thumb drive for holding my media. And you can swap them out with some simple file system structure. Not all motherboards will support this and it's a more difficult option to do because XP doesn't support this out of the box, but a few secs on google will have you to modern methods to do this.
Looking forward to starting my equipment purchases and getting going. I will document and share all as I'm building and/or finished.
bemenaker is offline   Reply With Quote
Old 12-15-2008, 05:25 PM   #96
steferfootballd is an unknown quantity at this point
I know this post is a bit late, but I saw no one suggest a water "cooler."
Here is an example kit: http://www.thermaltakeusa.com/Produc...C=1160&ID=1618.
What you could do is mod something like a teakettle to replace the radiator, and reduce the kettle's power usage to heat less. (minimize boiling )
here after much searching is a hard drive water cooler. http://www.koolance.com/water-coolin...product_id=678
But it would be critically important to include several fail safes (automatic and manual) in this system to ensure it doesn't over heat.
Also, due to often excessive vibrating of cars, some sort of liquid absorbing fail safe should be used, making this a more difficult mod than i initially planned.
Last edited by steferfootballd; 12-15-2008 at 05:34 PM. Reason: Realized a Problem
steferfootballd is offline   Reply With Quote
Old 12-15-2008, 11:57 PM   #97
trader007 can only hope to improve
i am planning to run a deep cycle battery off a solenoid and also have a small rooftop solar cell to help the battery when the car is off. even if i only get 2 days of sleep mode time, thats ok with me. ill be using vista and it can do hybrid sleep where it writes to the disk in sleep anyway- just in case the power gets cut. best of both worlds.
trader007 is offline   Reply With Quote
Old 12-16-2008, 12:51 AM   #98
RONBO0314 is an unknown quantity at this point
If you have a secondary battery in the car then you could use an inverter to convert the power to 120vac and plug in a temp controlled heat lamp. I have one in my well house to keep the pipes from freezing up. Just have to make sure your bulb doesn't burn out. Set the temp on the thermostat and you don't have to worry about the pc getting too cold. Just an idea.
RONBO0314 is offline   Reply With Quote
Old 12-16-2008, 12:55 AM   #99
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I can't imagine that would last very long on battery power.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 12-16-2008, 01:08 PM   #100
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Not to mention, that sound dangerous. My solution would be that if you know its going to be cold, keep your heater on, then buy a autostart solution to start your car remotely and heat up the inside. Then maybe you can tie the PC into the security system also and when you think your car is warm enough, hit a AUX button to activate the PC. Although I live in Florida, I plan on doing this for the opposite reasons, i want the car to be cooled off then the PC turns on.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 01-24-2009, 05:08 PM   #101
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
My M10000 and CF embedded OS setup booted no problem last winter on a -15F day. Took the media drive (3.5") a few minutes before the PC recognized it though.
blk02si is offline   Reply With Quote
Old 01-24-2009, 08:29 PM   #102
whatever heater setup you might come up with, its probably going to draw more power then the pc itself. it would likely be best to figure out a battery system that is capable of running the pc for at least 48 hours at idle while engine not running. in other words, just use the pc as a heater.... or just have a a/c plug sticking out your bumper like most people do in cold climates, for battery or block heaters...
Old 01-24-2009, 11:38 PM   #103
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
The best and most reliable answer is let the car and PC warm up, then start the PC. The car heater is a better answer than any solution an individual is likely going to come up with. Slowly warming the PC will limit damage as well.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 01-25-2009, 12:14 AM   #104
nobb will become famous soon enoughnobb will become famous soon enough
Letting the PC warm up from the car's natural heat might work when it's only -10C, but as you start hitting lower temperatures it will take forever. Especially if your system is in the trunk like mine.
The most reliable setup Ive tested is my current system. M2-ATX, Jetway J7F2WE2G (100% solid state capacitors), 80gb Seagate EE25 (extreme edition), and Lilliput EBY701. Not a single cold weather related issue so far, down to -30C. Hoping it'll get under -40C this winter, so I can test...
nobb is offline   Reply With Quote
Old 01-25-2009, 02:54 AM   #105
but if you have an intelligent power supply, its going to start the pc when the car starts....
M10000 mobo in cold weather (-40C)? Any problems? nobb General Hardware Discussion 2 02-19-2008 07:55 PM
cold weather and my motorized touchscreen. skywise LCD/Display 12 12-12-2006 10:58 PM
Carputer and cold weather... very cold! Topper General MP3Car Discussion 3 07-14-2005 08:41 PM
Anyone else having any issues with Cold weather? bry21317 General Hardware Discussion 21 01-25-2005 10:42 PM
Cold weather +LCD Adragontattoo LCD/Display 4 10-13-2004 11:25 AM
