01-25-2009, 09:16 AM
#106
North of the land of Hey Huns
My carpc is under the passenger seat, and when it hit 10F the other week it took about 15-20 minutes for the car to warm it up enough for the hard drive to be recognized. Maybe using a low power peltier directly on the center of the hard drive to keep the bearings warm?
01-25-2009, 09:30 AM
#107
Quote: Originally Posted by trader007
but if you have an intelligent power supply, its going to start the pc when the car starts....
unless u specifically included a switch in your set up that cuts off the 12v car on signal when u dont want it booting
01-25-2009, 11:19 AM
#108
Self proclaimed spoon feeder
Quote: Originally Posted by nobb
Letting the PC warm up from the car's natural heat might work when it's only -10C, but as you start hitting lower temperatures it will take forever. Especially if your system is in the trunk like mine.
The most reliable setup Ive tested is my current system. M2-ATX, Jetway J7F2WE2G (100% solid state capacitors), 80gb Seagate EE25 (extreme edition), and Lilliput EBY701. Not a single cold weather related issue so far, down to -30C. Hoping it'll get under -40C this winter, so I can test...
Sure, but your set up is not really the topic of the thread... neither is mine. It does not require any heat to boot either.
TruckinMP3
Read the FAQ!
01-25-2009, 11:48 AM
#109
i got a new setup, its now under the the seat, no problems jet
Forum name..., mobo
..............., temp startup, temp malfunction, age board..., power-supply..., harddrive.......,suspected failer
Rijk
........, Commell 673NS
........., +9C
......., +4C
, 17 moths...., M2 / DSX12VD.., SSD 8 Gb......., mobo
andrewb........, EPIA-5000.................., -30..........., -42..................., 0 months ?., M2.................., ?.................., mobo
andrewb........, EPIA-M10 /k..............., -35..........., -42..................., 0 months ?., M2.................., ?.................., mobo
andrewb........, EPIA-MII-10K.............., -15..........., -42..................., 0 months ?., M2.................., ?.................., mobo
cartft..........., Jetway 7F2WE-1G-OC..., ?.............., -40..................., 0 months ?., M2.................., ?.................., mobo
cartft..........., Jetway 7F2WE-1G3-OC., ?.............., -40..................., 0 months ?., M2.................., ?.................., mobo
cartft..........., Jetway 7F2WE-1G5-OC., ?.............., -40..................., 0 months ?., M2.................., ?.................., mobo
Maheriano....., Via Epia M10000..........., -17..........., -17..................., 24 months.., M1 ATX............, Toshiba 5400 RPM, Hard Drive
nobb............, Via Epia M10000..........., -35C........., -35C................., 2 months..., M2-ATX........, Seagate EE25 ST940814AM (automotive grade, aftermarket model).......,...Hard drive wont spin fast enough[/quote]
Rijk
........, intel dg45fc+E8500
..., -15C
, 4 months...., M4 ................., SSD mtron 7500 (16Gb),
01-25-2009, 01:28 PM
#110
how does that work with remote start? i guess it could still be done... more complicated though.
01-25-2009, 02:17 PM
#111
This will only work if you have your mobo on a second battery. Cold doesn't only effect the cpc, but also your battery.
I have the mobo hooked-up to the car-alarm, and its just on for like 20 seconds and in the -10°C I already notice the difference.
01-25-2009, 02:22 PM
#112
i dont have remote start... if thats what the topic of the discussion was about i apologize, i didnt realize.
but ya it could be done. the easy route would be if you know your car will be cold soaked when u come back just flip the switch before you get out.
the complicated way would be adding extra signals to your remote and having your remote starter controller know the difference somehow...
another thought would maybe instead of it being a switch, make it a relay that is controlled by a thermostat. this would obviously need a override switch but doesnt sound too complicated. hmmm. i might look into this (im sure its been done many times).
the biggest problem with my carpc in the cold is the screen. it is really unhappy and dim at temperatures where my hard drive etc is perfectly fine (ive never tried it below about 10F though so...)
08-14-2009, 10:31 PM
#113
Just a tip but you can try putting this in a table format as it would be easier to read and type/update
| Forum name | mobo | temp startup | temp malfunction | age board | power-supply | harddrive | suspected failer |
| Rijk | Commell 673NS | +9C | +4C | 17 months | M2 / DSX12VD | SSD 8 Gb | mobo | | andrewb | EPIA-5000 | -30 | -42 | 0 months? | M2 | ? | mobo | | andrewb | EPIA-M10/k | -35 | -42 | 0 months ? | M2 | ? | mobo | | andrewb | EPIA-MII-10K | -15 | -42 | 0 months ? | M2 | ? | mobo | | cartft | Jetway 7F2WE-1G-OC | ? | -40 | 0 months ? | M2 | ? | mobo | | cartft | Jetway 7F2WE-1G3-OC | ? | -40 | 0 months ? | M2 | ? | mobo | | cartft | Jetway 7F2WE-1G5-OC | ? | -40 | 0 months ? | M2 | ? | mobo | | Maheriano | Via Epia M10000 | -17 | -17 | 24 months | M1 ATX | Toshiba 5400 RPM, Hard Drive | | | nobb | Via Epia M10000 | -35C | -35C | 2 months | M2-ATX | Seagate EE25 ST940814AM (automotive grade, aftermarket model) | Hard drive wont spin fast enough | | Rijk | intel dg45fc+E8500 | -15C | ? | 4 months | M4 | SSD mtron 7500 (16Gb) | |
Forum name..., mobo
Rijk
........., +9C
......., +4C
Rijk
..., -15C
__________________[/QUOTE]
2006 Mustang with indash CarPC
| Parts list | | | | D945GCLF2 | 2GB RAM | 20GB HDD | | Opus 120W PSU | Lilliput 8" | Directed HD | | RideRunner | nLite XP | iGO8 |
| Thread Tools |
| Display Modes |
Linear Mode
