Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Notices
Old 01-20-2008, 08:48 PM   #46
jontz's Avatar
Quote: Originally Posted by Sonicxtacy02 View Post
the xm IS always pushing audio.... but i can control its volume with the pc independently of the line-in's volume in xp's mixer. So that being said if i have a splitter (2 3.5mm female into 1 3.5mm male) i could theoretically:
-play xm thru the line-in. HD radio is not powered unless i'm listening to hd radio
-play hd radio by first muting the xmd1000 then powering on the hd radio
my only fear is that using a splitter will cause some kinda voltage issue. I dont want the voltage on the line from the xm goin back into the hd radio tuner. My original question was will that happen.
Ahhh...I gotcha. I really don't think that you are going to have a voltage issue. I have hooked up two devices in the manner you are describing with no problems at all on several different occasions.
Honestly though, I would just use a switchbox and be on the absolute safe side. I know it isn't as automated as you want, but it will work, and no questions about voltage problems...either that or the uber-expensive sound card option...
jontz is offline   Reply With Quote
Old 01-22-2008, 09:38 AM   #47
MySQL Error
Sonicxtacy02's Avatar
ok here's another sound card option (i think)
http://www.compumusic.com/p31235.htm
maya 44 usb, has 4 inputs and 4 outputs.. i've been reading reviews and basically the only negative i can find is that it doesnt use 24-bit dac's. I dont even know if the sb live i have does that though. I only wonder if the 4 outputs are made for 5.1/7.1 sound. Notta HUGE deal to me either way but i just wonder how it will hook up to all speakers in my setup.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
Developer of: RRFusion, MovieTimes, (new)RRMail, & RR Plugin Manager
Coming Soon:RRChrome, & CentraFusion
Is Your RR Plugin Managed?
Old 01-22-2008, 08:04 PM   #48
jontz's Avatar
I don't believe that the inputs are made for 5.1/7.1 at all. In fact the inputs aren't even stereo, they are mono, so you REALLY only get 2 inputs stereo. This really looks like more of a recording card than a sound card, I don't know how that will end up working out with your setup. If you kept your current soundcard and just used this for the inputs, I think your'd have something....
FAQ: Installing XM Radio on Your Carputer, a Tutorial Bugbyte The FAQ Emporium 8 03-14-2008 01:36 AM
Listening on XM radio stations via internet directly in Centrafuse - is it possible? urosbe Centrafuse 2 08-22-2006 12:06 AM
Got XM to work, then it took a dump DuDs StreetDeck 3 05-06-2006 06:42 PM
XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer Will Albers General MP3Car Discussion 2 03-27-2006 09:49 PM
xm and radio tuner at the same time n8scstm Car Audio 3 04-02-2005 01:13 AM
