check your system volume and turn your main volume all the way up and your wave volume all the way up as well..
for eq files, look up king willy's realm through google or the new microsoft live search engine and grab some of his EQF files. load them into your winamp, and adjust to your hearts content...i use his "allround" eqf and i have modified it a little lower on the highs, and up on the lows to compensate, cause i had the same problem when i first installed my carpc...
hopefully that works...if not you can pm me or whathave you and i will do my best to help you out since i had and have since fixed this same problem...
Cheers
Rij
EDIT: just reread and noticed you are using Windows Media Player...those .eqf files are for winamp just FYI...
also, adjust which speakers you have set as default on your computer...it does make a difference believe it or not...
