The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 01-27-2008, 03:43 PM   #1
My Photos: (0)
Why so slow?
Ok i dont think my setup should be laggy and slow.
Specs.
Epia M10000
512 ram
4gb Dane elec 133/xs CF CARD (OS and Front end only)
Home PSU for testing.
OK the only things installed on it are Tiny Xp ,Win amp mapmonkey,RR,And Digital FX 2.0 Transparent skin.
For some reason doing anything has great amount of lag.....
Would it be the CF card bottle necking me?
Would i be better off with a 40gb 3.5 HD and jus have everything installed on that.
I would have thought this mobo would be good enough.
chvybeatsford is offline   Reply With Quote
Sponsored Links
Old 01-29-2008, 09:46 AM   #2
Vehicle: 1996 Buick Regal
My Photos: (0)
I have the same issue and I used a P4 with a gig of ram, NLite and CF card. I believe the slowness is caused by the CF card or IDE adapter. I havent completely solved the issue yet, it is still slow but I got the system a lot faster by enabling UDMA in BIOS and ensuring that the CF card is running in UDMA mode... device manager > CF card > properties.
Still tinkering though, my setup was a lot faster with the HDD. But why?
Oh also I know that cheap CF cards can cause issues. I am using a SANDISK ULTRA II and an IDE adapter that was recommended by SFiorito, our resident CF booting expert. I've also tried different types of IDE cables (40 and 80 pin).
Ripcord is offline   Reply With Quote
Old 01-30-2008, 06:32 AM   #3
My Photos: (0)
u need to run a seek/read test on the card. I suggest finding a benchmarking program on the net. You can run a test on the card and compare the result to a standard hdd (the program should be able to show you in a graph) that will tell you if its the drive or whatever. Sisoft sandra I believe can do this for u
Alfredbra is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Jetway J7 really slow for some reason Hosferatu General Hardware Discussion 0 08-30-2007 08:53 PM
Ep 13000 slow bios problems Philhop General Hardware Discussion 7 06-24-2006 09:34 AM
SLOW WiFi Curry Newbie 9 05-12-2006 08:01 AM
Slow Problem Goose PhoneControl 10 03-22-2005 12:13 PM
ML8000... Slow? POS? some help please bmo Newbie 3 03-13-2005 06:38 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
