The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 01-28-2008, 03:09 AM   #1
My Photos: (0)
Hard drives
My car pc is a motherboard (standard mini ATX) screwed into a custom made mdf housing in my boot....all fine.
My SATA hard drive needs some form of soft housing. I seem to be screwing up and having to rebuild my system with a new hard drive every 3-4 months.
Sound becomes crackly, songs keep sticking like a scratched record. and the system doesnt always shut down.
Can anyone suggest how the best way to fix the hdd is. currently mine sits ontop of the boot carpet to keep cooler....and hopefully absorb some of the shock, but it just isnt working long term
astrapc is offline   Reply With Quote
Sponsored Links
Old 01-28-2008, 04:55 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Mount the HDD to something solid.
A body panel r mounting board would be your best bet. Mount it SECURELY.
If you feel the need for additional shock absorption, mout it using rubber grommets or washers between the HDD and the solid surface.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-28-2008, 08:33 AM   #3
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
if you're buying a new one every 3-4 months then you should consider investing in an SSD instead of a HDD. I use the term investing because although SSDs are expensive, it will not fail do to vibration, and will pay itself off vs. replacing a HDD every few months.
if you require more storage space than an affordable SSD can provide, then get a small SSD big enough for the OS and some programs (4GB-8GB) and use a HDD to store all your media files (it will still fail, but you won't have to reinstall the OS and programs again, just restore your media files).
you could also use a CF card for your media files (you can get them up to 32MB). CF cards are not robust enough to run a regular OS on it because they cannot handle as many writes/erases as an SSD but they are perfect for storing MP3's, videos, etc where it's primarily being read from, not written to. you can get IDE > CF adapters that will make the CF into a permanent drive.
good luck
FusionFanatic is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Hard drive shock / vibration thoughts S11D336B General Hardware Discussion 60 09-26-2006 11:40 PM
New hard drives for cars from Hitachi Magician General Hardware Discussion 23 09-06-2006 01:24 PM
(UK based) For Sale: 2x 2.5" notebook hard drives SamDude Classified Archive 2 03-25-2005 11:04 AM
Cheap external hard drives FishPony Off Topic 6 03-07-2005 05:27 PM
Cheap laptop hard drives baef Classified Archive 17 03-02-2005 05:52 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
