The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 02-01-2008, 10:44 PM   #1
quantum's Avatar
My Photos: (4)
Electrical people - relocating pressure switches in a climate control unit???
Hi all,
This is the first time I have come across this, a little help please?
This climate control unit is out of a 2002 Deville (my future car). I took apart the whole thing, and found out that they are just pressure switches mounted to a thin PCB film. The big switches that work the controls actually press into a rubber plate with a dimple on the back, which in turn "presses" the switch.
If there is a way to relocate the buttons and still control the climate, it opens up some possibilites for me with regards to monitor size. So, I was wondering, with the exception of mini linear actuators, is there any other way to send a signal to the switch?
*NOTE* to TurboCad, look familiar?
TY!
COMPLETE! - 2002 Cadillac DTS - Summer 2008
http://www.mp3car.com/vbulletin/show...-complete.html
quantum is offline   Reply With Quote
Sponsored Links
Old 02-02-2008, 03:08 PM   #2
blk02si's CarPC Specs
blk02si's Avatar
Vehicle: '06 Triple Black Mustang
My Photos: (0)
You just need to close the circuit path.
Easiest way I can think of is soldering some leads to that printed circuit film and put monetary switches on the leads.
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Old 02-06-2008, 11:52 PM   #3
quantum's Avatar
My Photos: (4)
Thanks for the info blk02si. Any other suggestions from the masses?
Now, the big question...this looks a little out of my league, some of those traces are REALLY thin. Plus, I've only soldered big stuff, never a film like this.
Maybe some of you skilled individuals with the right tools can offer some guidence or even want to make a few bucks??
Thanks!
Old 02-07-2008, 03:11 AM   #4
FordNoMore's Avatar
Vehicle: 2008 Subaru Impreza WRX
My Photos: (29)
The masses say: blk02si is correct!
See the squiggled bare traces on the board where the switches are? All the "pressure switch" is is a conductive piece of rubber (or plastic with conductive paint underneath, or something like that) that mashes against the circuit board and bridges between the two contacts when you press on it. Nothing more magic than that.
If you end up doing the soldering yourself, rather than try to solder onto the tiny little squiggly traces that are much too close together for comfort, try scraping off some of the green soldermask a little farther back where the traces are bigger and more accessible, and solder wires there.
Good luck!
(And if you're around San Diego, I may be able to help.)
FordNoMore is offline   Reply With Quote
Old 02-07-2008, 03:20 AM   #5
FordNoMore's Avatar
My Photos: (29)
Oh, and another tip if you didn't already know: Each switch has two contacts - one that's specific to that switch, and one that's common to all of the switches. (You can tell by following the traces on the board, or checking continuity with a multimeter.) You only need to connect one wire to the board for the common - so that cuts your soldering job about in half if you were thinking you had to connect two wires to the circuit board for each switch. (From the picture, looks like 12 buttons, so you'll need 13 wires soldered to the board.)
Old 02-11-2008, 11:14 PM   #6
quantum's Avatar
My Photos: (4)
Thanks for the tips, FordNoMore, greatly appreciated!
I just may take you up on your offer one day in the near future.
Old 03-04-2008, 09:12 AM   #7
My Photos: (10)
Film solder...
I would not solder to the film, but to where the film plugs into the car or other PC board. Hang on to the film. for when you trade your car in. :-)
pir8radio is offline   Reply With Quote
Old 03-19-2008, 10:17 AM   #8
MindDrive's CarPC Specs
My Photos: (0)
what your doing is very similar to what ive done with a keyboard circuitboard... and yes an ohm-meter is the ONLY way to do it without loosing 99.3% of your hair
if you look in the fantabulous paint pic i made up, youll see that if anyone uses a keyboard circuit in this manner, there are LOTS of "shared" circuits, not just a single common but many, dunno how caddy's have the climate control, but the work you did on your caddy has definately given me some great ideas good to see people not afraid to rip into luxury cars ^_^
*edit*
i just noticed that the circuit you have shown there has surface mount resistors on it, which means that they might not only have a common signal, but the amount of voltage might also play a role with making aftermarket connections/buttons etc.... if thats the same as the finished dash console as in your sig, i'd keep an eye on it and the fuses real close like, replacing that film and/or the board it connects to probably wont be a nice thing to try and find
'97 Seville STS
'91 GMC G2500
MindDrive is offline   Reply With Quote
Old 07-02-2008, 09:46 PM   #9
My Photos: (0)
Why not try to interface the buttons of your climate with a serial/usb port of your pc so you can control everything via touch screen. For the times when you PC is not running you can have a back up remote. So you can relocate your original climate anywhen and then not have to deal with finding a space to mount your buttons. I say this with confidence since I have done it myself. This is the most "cleanest" way i think. The only problem is that i have not much experience in making applications.
Civic Modz is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Climate control through pc SweetLikeChutny Hardware Development 9 04-06-2007 10:36 AM
control climate control via PC? GuessWhosBack General MP3Car Discussion 41 09-15-2006 10:54 AM
Help with Climate Control..... map_auto General Hardware Discussion 1 06-07-2006 05:07 AM
PC climate control? daPyr0x Hardware Development 2 01-29-2006 10:03 AM
AIMEE Climate Control POLL Danceheaven Software & Software Development 19 08-21-2005 06:19 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
