The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 02-04-2008, 05:20 PM   #1
bes51659's CarPC Specs
bes51659's Avatar
Vehicle: 01/BMW/325ti
My Photos: (6)
USB DVD connection problem with XP
I have problem with my USB DVD. I have many times though problem solved, but it has always reappeared.
My system is an MII12000, a panasonic USB DVD and also a Huawei200 3G modem (with internal mass storage device meant for installation that I have disabled in control panel. This device will still often 'pause' the system at boot so that it has to be disconnected for the boot to continue).
DVD is connected via CIB-650 monitor, but I beleive that it just passes on USB straight thru. I power DVD separately from my own 5V DC/DC.
I have tried this:
- connected DVD directly to USB port, avoiding hub
- flashed latest bios 1.37
- updated usb drivers
- there is no powersave option enabled
- patch KB892050 from microsoft
Most of the time the DVD starts if I disconnect/reconnect the power to it, but it is not enough to disconnect/reconnect USB.
Please help. I'm out of ideas and don't even know what to google next.
bes51659 is offline   Reply With Quote
Sponsored Links
Old 02-04-2008, 05:41 PM   #2
galvitron's CarPC Specs
galvitron's Avatar
Vehicle: 2006 Evo MR
My Photos: (0)
See if removing all other USB devices fixes it.
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 100%
Installation/Fab/Assembly (Revised):
[----------] 60%
galvitron is offline   Reply With Quote
Old 02-05-2008, 04:56 AM   #3
bes51659's Avatar
My Photos: (6)
Well, not really a solution but I will try it as a way to get a handle on the problem. Have you had (/solved) USB problems?
Old 02-05-2008, 11:41 AM   #4
galvitron's Avatar
My Photos: (0)
If that fixes your issue you know that one of the other USB devices is screwing it up and you can, through trial and error, find which one it is.
The computer I'm on right now is a nice, new, fast system but will not boot at all with a USB mouse plugged in. Took me forever to figure it out, but that's USB for ya!
USB devices share a root hub on your PC. If one of the devices is screwing up the hub, the other devices on it may have problems. BTW, I am not talking about what most people think of as a USB hub. I mean a hardware chip in the PC controlled by a root hub driver.
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 60%
Old 02-05-2008, 05:57 PM   #5
bes51659's Avatar
My Photos: (6)
You were onto something! the DVD came up straight away when that was the only USB device. At least once :-) Well, now I've just got to corner the bogus device.
Thanks. (I'll update thread when done)
Old 02-05-2008, 06:00 PM   #6
galvitron's Avatar
My Photos: (0)
That's good news. Find the culprit!
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 60%
Old 02-06-2008, 02:24 AM   #7
bes51659's Avatar
My Photos: (6)
Not again. It worked a couple of reboots but not anymore... I don't know how many times I've thought problem solved. What I will do now is to make sure it comes up every time I power it up when PC has booted....
Well, at least I now know its not one of the other USB devices :-)
Any more idees?
Old 02-06-2008, 11:30 AM   #8
galvitron's Avatar
My Photos: (0)
Do you use it all the time? In my system I am leaving the DVD drive disconnected until I need it. I don't use CDs/DVDs that often. I don't know if this is an option for you.
You may want to try and upgrade the firmware of the drive. Check with the manufacturer for that.
Is the drive fully powered by USB or is there an external DC in? If it is powered by USB you may want to try running a dedicated 5V to it from your PSU.
And of course, make sure all your BIOS and drivers are up to date.
EDIT: Sorry, looks like you covered a lot of these already in the first post.
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 60%
Old 02-06-2008, 02:11 PM   #9
bes51659's Avatar
My Photos: (6)
Thanks Jeremy
Yes, I tried to put all the tips that I've found so far on the first post :-)
But, I did not know I could update firmware of drive. I will check with Panasonic.
Also I have found an interesting tool that could help. A command propt device manager. devcon
In case the problem is solved by power on when I need it I can solve that with my 8051 power controller. I just need some more hours on the clock :-) Trying to fix this now when its warm.
BR, B-O
Old 02-06-2008, 04:33 PM   #10
galvitron's Avatar
My Photos: (0)
Well its tricky but it looks like the problem is with USB somehow, either the USB connection itself or the 5V power...
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 60%
Sponsored Links
Old 02-07-2008, 08:06 AM   #11
My Photos: (0)
you need to be specific on what boot means. before windows at the BIOS post screen or during windows is about to load? If at the post screen disable boot from other device, if present. ensure the HDD is the first bootable device in the boot sequence. remove the dvd drive in the boot sequence. If all comes to worst put the computer in s3 standby rather than completely turning off. It will use a little power though while turned off but will last over 2 weeks in a standby state on battery with the car not starting during that time.
This way the computer will resume instantly and resume to the last online state skipping any startup, post screens or the booting of windows..
hope that helps. cya
Alfredbra is offline   Reply With Quote
Old 02-10-2008, 11:15 AM   #12
bes51659's Avatar
My Photos: (6)
Thanks guys.
I've been playing around abit and it seems like its the HQCT USB connection that is giving me problems. I will however continue to try the system out before I say to much..
For now everything seems to be working when HQCT is disconnected.
Standby is not an option. It can get cold at wintertime in sweden and I do need all the mAh I can get...
When the 3G modem halts the boot it can be during scan of HDD before postscreen(?) is complete or when the progressbar at hibernation load or at the blank blue screen right after. It always manages to break free, but it can take as long as 30 minutes. If I unplug the 3G modem is continues right away. But this is really my second problem.
I have disabled USB keyboard as well as other bootable devices than the primary HDD.
I have also tried to disable USB all together in case win drivers were sufficient. They were not :-)
I think I can live with this problem as long as it is rare.
Sponsored Links
vB code is On
Trackbacks are Off
KZL K300 series LCD Touchscreen USB problem. dmaudio4life LCD/Display 0 07-27-2006 06:47 AM
Slot Load DVD -> USB Problem Ritalin Kid General Hardware Discussion 1 11-03-2005 09:52 PM
WTB: USB slot-load DVD, USB card reader, USB hub, USB 2 laptop card taylor192 Classified Archive 2 09-26-2005 09:59 AM
help diagnose dvd drive problem tsai General Hardware Discussion 0 03-06-2005 09:34 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
