The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 02-13-2008, 04:51 PM   #1
My Photos: (0)
Im so ****ed
I finally finished my enclosure for my laptop and xbox, ran the power switch for the laptop and its all good to go, i tested the xbox before i did the enclosure and everything was working great, now when i go to turn on the xbox i get a blank screen and it the circle on the xbox is flashing, it flashes either green/orange or green/red i cant tell which. I tried hooking up a new connector to the lcd because the orange/green means there is a bad connection. So now i have to try and get my enclosure back apart and see what is the problem! Just wanted to rant, dont know if anyone has any thing they can do to help. On the bright side i got my laptop all in, i just have to figure out where i am going to put my external DVD player.
tacobandit is offline   Reply With Quote
Sponsored Links
Old 02-13-2008, 05:01 PM   #2
My Photos: (0)
okay i looked at it and its definetly red/green, so i am thinking is that while i was wiring up a 5v usb hub i might have got a small piece of solder on the m2-atx, i will have to pull it off tonight and see if i can find a small piece, otherwise i have no idea what i need to do.
Old 02-13-2008, 05:06 PM   #3
Raw Wave
kickercivic1's Avatar
Vehicle: 07 Jetta
My Photos: (0)
IF the xbox is modded then bad chip or bad bios image, and IF its screw on chip it might have came loose.
07 Jetta
Carputer:
Voompc-2, Intel 1.33, 1GBram, 60gb HD, Dynamix 8"
Audio:
front Qsd 216
Rear QSD 213
Rockford (2) p2 10" subs
JL 500/1
JL 300/4
Audigy 2 nx
kickercivic1 is offline   Reply With Quote
Old 02-13-2008, 06:29 PM   #4
My Photos: (0)
okay i was able to get the xbox out, now i need to know it looks like the xcutioner chip is a little loose, would that be the problem, is there a way to fix it?
Old 02-13-2008, 08:14 PM   #5
Raw Wave
Vehicle: 07 Jetta
My Photos: (0)
with the cover open just keeping messing with the chip, and turn it on and see if the light goes away.
07 Jetta
Carputer:
Audio:
front Qsd 216
Rear QSD 213
JL 500/1
JL 300/4
Audigy 2 nx
Old 02-13-2008, 09:16 PM   #6
My Photos: (0)
i messed with it some with 0 results, i will try again, if that doesnt work i will probably just take my old un-modded xbox and put that one in there, i have a few games but not what i had on the other one.
Old 02-13-2008, 11:47 PM   #7
My Photos: (0)
okay i messed with the switches on the front of the xbox and now i am getting this screen
What do i need to do from here?
what should i have the switches set to?
Old 02-14-2008, 07:21 AM   #8
Raw Wave
Vehicle: 07 Jetta
My Photos: (0)
Just go on google and put in your problem there is tons of links that pop up.
07 Jetta
Carputer:
Audio:
front Qsd 216
Rear QSD 213
JL 500/1
JL 300/4
Audigy 2 nx
Old 02-14-2008, 07:33 AM   #9
jumbodogs's CarPC Specs
jumbodogs's Avatar
Vehicle: 97 Dodge Ram
My Photos: (12)
If there is something wrong with your chip you could always just software mod your xbox. I run XBMC on my xbox and never even opened it up. You might want to check around this site. You should be able to find a lot of answers there.
My RAMPUTER
jumbodogs is offline   Reply With Quote
Old 02-14-2008, 04:36 PM   #10
My Photos: (0)
YESSS well after reading around i figured out that my switches were off, it needed to be on, on, off, off, off and it loaded like a champ.
Sponsored Links
Old 02-15-2008, 03:46 AM   #11
FC3S's Avatar
My Photos: (0)
from what i remember, you dont even need the pcb attached for it to work
FC3S is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
