Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 08-02-2000, 02:33 PM   #1
jasmar
Post I need another parallel port
I want to use my extra lcd in the house to show winamp info while I am working. The problem is that my machine is the print server for the home network so the parallel port is being used. What is the best solution: 1. get a new parallel i/o card with two ports or 2. get one of those ethernet adapters that serves as the print server. I have several old i/o cards out of the 486's we had over the years. Could I just pop one of those in and use it for the lcd. Will it be fast enough for the lcd? thanks, Jason
jasmar is offline   Reply With Quote
Advertisement Sponsored links
Old 08-02-2000, 02:35 PM   #2
Old El Paso
Post
As long as the cards support EPP (I think that it's EPP) there should be no problem.
OEP
Old El Paso is offline   Reply With Quote
Old 08-02-2000, 02:36 PM   #3
Chris Snyder
Post
One of those old cards should be fine. Just make sure to disable the other interfaces on it so that you don't get conflicts, and be sure to tell it to be LPT2.
Chris Snyder is offline   Reply With Quote
Old 08-02-2000, 07:53 PM   #4
jasmar
Post
Well, I found four I/O cards. Two of them were VLB so that left two. One I could not disable the IDE interface on and the other one locks the system up even though I have it jumpered correctly. I guess I need some reccomendations brand wise. Anybody using one of the Parallel PCI boards from SIIG?
Old 08-02-2000, 07:58 PM   #5
Callahan
Post
I have a ISA LPT port card made by Lava.. it works great in every system I have used it in so far.. might be worth looking into.. it only cost me $17CDN...
MP3 Cavalier - http://www.mp3cavalier.com
MP3 Grand Prix - http://www.mp3gp.com
Callahan is offline   Reply With Quote
Old 08-03-2000, 01:55 AM   #6
Machs_FueL
Post
How do you turn on EPP?
[SIZE=1]'91 Nissan Stanza
[XXXXXXXXXXXXXXXXXXXX] XX% Completed -
Car Totaled and i bought a 20G mp3 player
http://machs-fuel.tk
a DIY video projector page
Machs_FueL is offline   Reply With Quote
Old 08-03-2000, 08:50 AM   #7
ToxicPoison
Exclamation
Check your bios to turn on EPP
its not hard at all
ToxicPoison is offline   Reply With Quote
Old 08-03-2000, 11:13 AM   #8
fjmedinaa
Post
Once I did just that. Used an old multi I/O board froma a 486 to add 1 parallel port to a new mobo. Using the I/O card to be the LPT2: just put the machine to dream. What I found to be usable, was to use the old card as LPT1: and the mobo port as LPT2: and that did the trick. BTW the second port was used to connect an old laptop via laplink, so EPP should work fine. Hope it helps.
Quote:
fjmedinaa is offline   Reply With Quote
