The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-14-2008, 05:48 PM   #1
Jistari's CarPC Specs
Jistari's Avatar
Vehicle: 2001 Chevy Corvette
My Photos: (0)
Three position switch for white (accessory) lead?
Any reason I couldnt place a switch on the white and red leads before the pc in the car that would have three positions as follows :
Pos 1 : Red passes through white passes through
(would act exactly as it does without the switch, power on white line signals pc to start up when car is started and shut down when car shut down)
Pos 2 : Red passes through white interrupted
(would shut power on white lead, could be used to restart pc through psu seeing white interrupted, or if left in this position would prevent pc from starting when car starts)
Pos 3 : Red passes through on red line and is also connected to white lead
(bear with me on this)
(this would be used in the case when the car and pc are running, and you want to shut the car off but keep the pc running)
Yup, I realize pos 3 would drain the battery, and I aslo realize you can set the MTX 3 to do this for a programmable amount of time, but I think I might prefer to have the M3 set as I have it (start in 5 seconds and shut down in thirty seconds) most of the time, I would just use pos 3 occaisionaly when I want to stop for a few minutes, but dont want the pc to shut down.
So, ignoring my thickheadedness, just on a factual level, is this a simple thing to wire up? I have a three position switch but havent tried it yet, not sure if I have the right one.
I'm guessing I will have to:
Leave the red line alone
Have one side power the white line from accessory fuse (like it is wired now)
Have the other side power the white line from the red line
And when the switch is in the middle position, have white disconnected
That work?
PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
Jistari is offline   Reply With Quote
Sponsored Links
Old 03-16-2008, 07:57 AM   #2
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
what are these red and white "lines" connected to? is one of them power and one ACC / IGN?
it's hard to figure out if it will work when you don't say what the red and white wires are.
FusionFanatic is offline   Reply With Quote
Old 03-18-2008, 03:21 AM   #3
Jistari's Avatar
My Photos: (0)
Dont know what I was thinking, I usualy over explain.
Sorry, yes, red is positive from a fuse tap on a 20 amp fuse that is always powered and white is positive from a fuse tap on a 20 amp fuse that is only powered when the ignition is on.
Old 03-20-2008, 12:30 AM   #4
Jistari's Avatar
My Photos: (0)
Kill this.
Works great the way I described.
Old 06-09-2008, 06:20 PM   #5
My Photos: (0)
Im trying to do the same thing... and was planing doing the same thing you did but I have a question... if I have the car runnig (carpc is on) and I want to Leave it on.. so I move the switch from position 1 to position 3 the carpc its going to think the power button was press since I have to go through pos 2 am i correct?
thanks
Felix
a2carat is offline   Reply With Quote
Old 06-09-2008, 08:29 PM   #6
tigergibb's CarPC Specs
tigergibb's Avatar
Vehicle: 2003 Nissan Xterra
My Photos: (0)
You want a "SPDT Center-Off" switch. Here's how mine is setup:
Switch Position
Up: CarPC On (12V connects to white)
Middle: CarPC Off (Center is off, so nothing is connected to white, thus CarPC off)
Down: CarPC turns on/off with car IGN (IGN connects to white)
And here's the one I have:
http://www.allelectronics.com/make-a...WITCH/-/1.html
Here's other switches from them that should work too:
http://www.allelectronics.com/make-a...-SWITCH/1.html
http://www.allelectronics.com/make-a...DIODE/-/1.html
http://www.allelectronics.com/make-a...-HANDLE/1.html
If I'm leaving for 5-15 minutes to go in the store or something I just flip the switch up so the computer is still on when I get back. If I am just moving the car in the driveway and don't want the computer to come on I put the switch in the middle position for off. Any other time the switch is down so the computer turns on/off with the vehicle.
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 06-09-2008, 09:16 PM   #7
My Photos: (56)
here are some diagrams I made to help another member. maybe it will help you too
the diagrams show an M2-ATX, but the wiring will be the same for any PSU with a turn-on/trigger wire.
this one is for a simple override switch. it uses a 3-lead SPDT (center-off) switch.
this one is the same thing, but includes an LED to indicate when the switch is in position#3 (always-on). it uses a 6-lead DPDT (center-off) switch.
you would be correct if the PSU reacted that quickly, but it probably won't (the M2-ATX doesn't ). with a center-off toggle switch you can switch it fast enough (from #1 to #3, or vise-versa) that the PSU will not even know you switched it.
good luck
Old 06-09-2008, 11:41 PM   #8
My Photos: (0)
Thank you both
I think im going to wire that led too, because I want to hide the switch but at the same time put it somewhere easy to get to, in other words not visible, making it also like a valet switch
Thanks again
Felix
Sponsored Links
vB code is On
Trackbacks are Off
computer shuts off when I go from car in accessory position to on ultraz Newbie 4 09-11-2006 08:27 AM
Need clairification on wiring on/off switch syclone477 Newbie 9 03-23-2004 04:59 PM
4 pole push button switch, in on or off position johnny010 Power Supplies 2 04-15-2003 07:01 PM
Help With Extending Laptop Docking Station's Power Button JeffesonM General Hardware Discussion 10 04-14-2003 01:13 AM
ATX power switch mtmsol Power Supplies 5 05-13-2001 12:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
